Painting an OEM grill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lerxst, Nov 15, 2018.
  1. Nov 15, 2018 at 1:20 PM
    Lerxst
    Lerxst [OP] Active Member
    2018 SR5
    I have a brand new 2018 Tacoma SR5. Midnight black. It has the stock SR5 grill with TSS.
    I purchased this grill below at a decent price, it is the whole grill plus bezel and insert with TSS.
    I would like to paint the entire thing Midnight black, except the center badge (just the oval).
    I have noticed that "DupiColor" offers paint colors that match Toyota paint codes. So that's what I plan on using for the topcoat.
    Does any one have advise on :
    Methods to prep the grill ?
    Any sort of primer I can be using ?
    Should I separate and paint parts separate, or together (id prefer together)
    If this is even a good idea ?
  2. Nov 15, 2018 at 4:59 PM
    Trail Limo
    Trail Limo Well-Known Member
    Mountain2018 likes this.
  3. Nov 15, 2018 at 6:30 PM
    Lerxst
    2018 SR5
    Thanks Trail
    This super helpful. It also reminds me that I have a friend who works out of his garage, and has an HVLP gun with clear coat and hardener on hand. I don't like to burden him much, but if I show up with a grill all painted he would help me out.
    If he's busy I will use the Eastwood.
    Thanks.
  4. Nov 15, 2018 at 6:34 PM
    Lerxst
    2018 SR5
    Anyone have any thoughts on prep or Prime?
    Separating parts?
  5. Nov 15, 2018 at 7:08 PM
    Trail Limo
    I would recommend separating the parts before painting. If you don't you will likely end up with tape lines.
    Prep is pretty easy. Since the factory paint is in good shape all you have to do is scuff. Go to an auto parts store and they have some scuff pads that look like large scotch Brite pads that work pretty good. Alternatively you could sand lightly with iirc 600 or 800 grit sandpaper. Clean with a tack pad then a paint prep degreaser (auto parts store or Eastwood should have them). Once the old paint is scuffed and cleaned you should be good to paint.
  6. Nov 15, 2018 at 7:40 PM
    Lerxst
    2018 SR5
    Prep notes taken.
    As for separate parts.... I want then all the same color .... black.
    Except the inner badge/sensor
  7. Nov 15, 2018 at 7:48 PM
    Trail Limo
    Might be able to paint them together. Not really sure. If it were me and there isn't a risk of breaking things I would separate them. Less chance of issues.
    The one thing I'm not 100% sure on is the chromed bits. I haven't worked with chrome so I don't know how well the paint will stick to it.
  8. Nov 15, 2018 at 7:56 PM
    Lerxst
    2018 SR5
    Cool
    I got the whole setup for $85
    Hopefully it'll look good enough to bolt on to the new ride.
    It had TSS which is the major reason for going with a OEM and trying to paint it the way I like.
    Treading lightly on the project and appreciate the advice.
  9. Nov 15, 2018 at 8:02 PM
    Ar’s and pickups
    Ar’s and pickups Active Member
    Kevin
    Chantilly Va
    04 Tacoma access cab 4x4 trd off road
    Bone stock
    As a professional collision repair painter, if you paint anything over that chrome, you will be painting it every year. NO paint will adhere to chrome, no matter what anyone says. I know from experience with an old motorcycle of mine. I took the time and prepped and painted all the chrome “properly” just to sell the bike a year later when it started to bubble up. Clean it well, and Plasti dip it, or soak the chrome in bleach (and be prepared to change the bleach regularly, it may take weeks) until the chrome plating is dissolved and it is a plastic part. Then treat it as a raw plastic part. Especially being on the front end, the first rock chip will start the peeling process. My two cents....
    wood714, Slick Taco and Trail Limo like this.
  10. Nov 15, 2018 at 8:13 PM
    Lerxst
    2018 SR5
    Is a OEM grill real chrome ?
    Really asking cuz I don't know
    Is it plastic wirh chrome coated?
    With this grill can I plasti dip it and paint the plasti dip?
    Not an expert on painting chrome like Trail said.
    This being the grill I bought what's the best I could do?
    Leaning toward all black
    Maybe paint the gray black and leave the chrome chrome
    Or paint the gray Black. Plasti dip the chrome
  11. Nov 15, 2018 at 8:16 PM
    Lerxst
    2018 SR5
    I do significant highway travel
  12. Nov 15, 2018 at 8:17 PM
    barretta
    barretta -
    San Clemente, CA
    '18 White TRD OR 4x4
    Welcome to TW!
  13. Nov 15, 2018 at 8:26 PM
    Lerxst
    2018 SR5
    Looks like plasti dip the chrome parts.
    Paint grey parts is the way to go.
  14. Nov 15, 2018 at 8:48 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I would recommend separating the parts, I did just the grille with vht and 10 months later there are a few tiny chips where chrome shows through. Next spring I will plan for another coat.
    Lerxst[OP] likes this.
  15. Nov 15, 2018 at 9:30 PM
    Lerxst
    2018 SR5
    Really cool example!
    Mines all black, so I'd want the bezel piece black too.
  16. Nov 16, 2018 at 4:27 AM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    From the picture it looks like the only chrome piece that you need to paint is the bezel. Why don't you just order the SR black bezel and then you don't have to worry abou the the chrome. Just something to think about
    Slick Taco likes this.
  17. Nov 16, 2018 at 4:32 AM
    DeltaBravo
    DeltaBravo Do you know what nemesis means?
    Waste Management's residential dumpster rental allows you to quickly find the right size dumpster for your project, schedule delivery and pay, all in just a few steps.
    The vehicle commonly referred to as "The War Rig" is a 78 foot 18 wheeler based on a Tatra T815
    Take all the pieces apart, be careful with the clips. Use tape to cover the stuff you don’t want painted.
  18. Nov 16, 2018 at 5:10 AM
    Ar’s and pickups
    Kevin
    Chantilly Va
    Bone stock
    It’s going to be chrome plated plastic. The bleach trick works, but is time consuming and after buying a tub big enough to fit the grill, and filling with bleach multiple times, it gets pricey. I’m doing a Gm grill now and I’ve been through $100 in bleach. (And remember proper disposal!) And no to painting over plasti dip. It’s a rubberized coating. But if you clean the chrome properly the plasti dip will last a really long time!
    Norsemanvike likes this.
  19. Nov 16, 2018 at 5:11 AM
    Ar’s and pickups
    Kevin
    Chantilly Va
    Bone stock
    Thanks! Been reading on here for a while, took the plunge and finally joined you fine folks!
    barretta[QUOTED] likes this.
  20. Nov 16, 2018 at 5:16 AM
    Mountain2018
    Mountain2018 Well-Known Member
    Harpers Ferry/Leesburg VA
    2018 4x4 SB gray
    I would second Eastwood recco on their two stage rattle can paint and clear. Have used number of times on motorcycle parts and truck trim. With right prep holds up really well.
