Painting aluminum rims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woodman, Apr 11, 2017.
  1. Apr 11, 2017 at 5:07 PM
    woodman
    woodman [OP] Member
    Berlin, Connecticut
    2011 4x4 automatic (black)
    Hi all any ideas on painting aluminum rims, I want looks and durability thanks everyone
  2. Apr 11, 2017 at 5:08 PM
    Clearwater Bill
    Billy
    Largo Florida
    Are you speaking of stock alloys?
    It can be done. Proper prep and correct primer is the key.
  3. Apr 11, 2017 at 5:12 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    It would be easier to just take them to a powder coater. Most places I have seen will do the wheels for around $250-300. Pretty cheap for something that is going to look better and have much better durability than painting.
    Usually you can tell when people paint their wheels. It tends not to look as nice and they almost always end up chipping and peeling. I think for a couple hundred bucks save yourself the time and hassel and just powder coat.
  4. Apr 11, 2017 at 5:14 PM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    Take a 3m Scuff pad and scuff the entire wheel; that'll create a good enough surface for the paint to adhere to. Get some wax&grease remover or rubbing alcohol and wipe the wheels down; Get a can of Self-etching primer and spray that on; about 1 coat is good enough; let that dry for 10-15 minutes then start painting. Put on 2-3 coats of paint(Dupli-color wheel paint is recommended) with at least 10-15 minutes of drying in-between then 2-3 coats of clear coat and you should be good. I recommend Du-pont Automotive clear coat; this stuff is a little pricey but it'll protect the paint and finish for a long time. You can get it in a pre-mix spray can.
    I use these steps on all the wheels I spray; no chipping; no peeling. I use to do body-work and paint for a living.
    TRDSport10 likes this.
  5. Apr 11, 2017 at 6:21 PM
    TX444
    TX444 Did you tell them they were the Lord's chips!
    Diego
    victoria,texas
    Silver '11 DCSB 2wd Pre Runner
    You'd have to blast the stock aluminum wheels because they have a clear coat on them, I've painted mine over a year ago and they're still holding up great! I paint for a living, used base coat/clear coat. I'll try to post a pic manana.
  6. Apr 11, 2017 at 6:23 PM
    TX444
    Diego
    victoria,texas
    Sandblast them to powdercoat I believe, I went over the clear coat with adhesion promoter and sealer, then bc/cc.
  7. Apr 12, 2017 at 6:01 AM
    mikaymusic
    mikaymusic Well-Known Member
    07 Tacoma 4x4 SR5 TRD
    I have a story about that. Several of my friends and I bought a used school bus years ago (1994) to make into a camping/party bus. We painted it with rollers and brushes, using gallon buckets of green and white tractor paint purchased at Fleet Farm. The bus had yellow wheels, of course. When someone started painting the wheels, I tried to stop them and got into a big argument where I was ultimately over-ruled on painting the wheels. My thoughts were exactly the ones above...that the paint would peel and then there'd be hideous yellow patches sticking out of green wheels. And being that this is Green Bay Packer country and part of the bus's planned usage was to go tailgate at Lambeau, a green and white bus with yellow wheels would look about right.
    Today the bus is non-operational, sitting behind a barn. After 23 years there's no peeling on the wheels whatsoever and I've been ribbed about my "Don't paint the f'ing wheels" tirade ever since.
    UnloadedRex likes this.
  8. Apr 13, 2017 at 11:24 AM
    Tamburrini
    Tamburrini Well-Known Member
    Jamie
    Boston, MA
    SR5 4x4
    Stock now, but planing on upgrading audio system, proguard rack, rear work lights and tow hitch.
    I had a set of old American Racing wheels I got of Craigslist for $120 and had them powder coated satin black for $300. Look like brand new. And din' t chip or peel wjen new tires were installed on them.
    TRDSport10 and PackCon like this.
  9. Apr 13, 2017 at 11:24 AM
    Tamburrini
    Jamie
    Boston, MA
    SR5 4x4
    Oh, they are aluminum too.
  10. Apr 15, 2017 at 3:43 PM
    TX444
    Diego
    victoria,texas
