Paint Wrinkles on 2nd Coat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Apr 19, 2022.
  1. Apr 19, 2022 at 6:12 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    ok so paint question help!
    Can someone please please tell me what I did wrong? Put on first coat a day ago and going to put second coat on but started to wrinkle up.
    Sprayed with highly diluted spic and span and wiped and dried off the area before applying 2nd coat.
    I tried to wipe wrinkles with tac cloth which well only made it worse but it was wrinkled anyway before.
    I don't understand why it did this the first coat of spray paint looked great but the second is a disaster :/
    VXEric likes this.
  2. Apr 19, 2022 at 6:18 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  3. Apr 19, 2022 at 6:26 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    xxTacocaTxx likes this.
  4. Apr 19, 2022 at 7:25 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I've had high humidity cause that with can paint spray paint, I don't have any experience using automotive paint though.
    Dry and recoat timing could be another factor.
  5. Apr 19, 2022 at 7:42 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    If we get any paint experts here to chime in it may help to provide some more details (i.e. type of primer, paint, prep, shop/ambient conditions, spray times, etc.). The coating looks thick. Also, is this being painted outside or under a carport exposed to ambient temps/humidity?
  6. Apr 19, 2022 at 10:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That could be an issue.
  7. Apr 19, 2022 at 11:33 PM
    burrito782
    08 TRD Off Road
    I originally thought the same thing as well, but when I read OP's post in its entirety it wasn't completely clear to me when the wrinkles were noticed in the 2nd coat process (i.e. before or after applying the Spic and Span).
  8. Apr 20, 2022 at 5:11 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    This is absolutely the issue.
    wi_taco and Mayak1957 like this.
  9. Apr 20, 2022 at 5:38 AM
    guyfromky
    guyfromky Well-Known Member
    Should not have used that cleaner to go over the first coat. Wax and grease remover is your best bet for something like that. Also, as others have said, it's best to paint multiple coats in the appropriate flash time, when the first coat is still wet. Waiting a whole day between coats complicates things to some degree. Contaminants can land on the paint, the paint may not be fully cured enough for a second coat, need to fine-grit sanding or scuffing if the paint is a single stage, a lot of variables at play.
  10. Apr 20, 2022 at 5:44 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Use minerals spirits or denatured alcohol to clean a paintable surface. Alcohol drys faster.
  11. Apr 20, 2022 at 5:49 AM
    TXTaco211
    TXTaco211 Well-Known Member
    Corpus Christi, Tx
    13 Pyrite Mica TRD Sport DCSB
    Kicker Speakers, 5100's with HS coils and HS AAL, Caliraised 30" LED light bar
  12. Apr 20, 2022 at 6:05 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    What kind of paint did you use for the first and second coats? Same manufacturer and type? I've seen that effect when the paints in different layers are incompatible. For instance, if the paint / thinner used on the second coat is significantly "hotter" than the one used in the first coat, it will actually dissolve the first coat. I've also seen it when the second coat was applied too heavily - which causes the solvents in the second coat to dissolve the paint in the first coat.
    Sadly, no matter what the cause, you're going to have to go back to square one and start all over again. This is why painting at home - although it looks easy - generally isn't worth the time or effort.
  13. Apr 20, 2022 at 8:24 AM
    TacoBell07
    Four door 2wd Taco
    Well first off this stupid Rustoleum paint was still tacty when I added 2nd coat even though it was next day before I added 2nd coat. Second after actually reading instructions it said sand the area lightly with 400 grit before applying a 2nd coat. Third even though I cleaned the surface before adding 2nd coat with water kitchen cleaner mix instead of mineral spirits or a de-greaser.
    Also even though Rustoleum using is for metal it was not the automotive rustoleum enamel.
    I guess my main question now is if you're spray painting truck. If you are adding another coat on top of factory coat do you need to sand it before painting it or can you just clean factory paint and then add the next coat (provided the factory clear coat and paint are still good).
    I dont know why you could not just clean mineral spirits or de-greaser the factory paint then spray the aftermarket paint/ new coat on top of that, I am not a paint expert though.
  14. Apr 20, 2022 at 8:37 AM
    TacoTimbo
    TacoTimbo Well-Known Member
    South Denver
    2015 Tacoma TRD
    Automotive painter here, hopefully I can help. The wrinkling is a reaction typically caused when the solvents on the top coat reactivate the solvents on earlier coats. Often happens when an additional coat is applied to heavily. If you post up the material you intend to apply, Im happy to review and offer tips. Also, it is really important to always read the tech sheet for any refinish material.
    wilcam47 and Too Stroked like this.
  15. Apr 20, 2022 at 8:42 AM
    TacoBell07
    Four door 2wd Taco
    I applied spic and span to clean the first coat of rustoleum before applying the 2nd coat. Should have probably used degreaser instead or mineral spirits.
    Jimmyh likes this.
  16. Apr 20, 2022 at 8:46 AM
    TacoBell07
    Four door 2wd Taco
    Im using spray paint that is rustoleum. I applied this to factory coat which was fine just faded with a few flaking spots of clear coat but I sanded the clear coat down before adding rustoleum paint.
    From my research videos etc, I know if I am painting to sand it down like if its rusty or something.
    However I am merely trying to change the color of vehicle, so if the factory paint is ok meaning the clear coat is ok theres no rough spots but the paint is faded. In this case cant I just clean the factory paint with degreaser or mineral spirits and then apply the rustoulem spray paint ?
    Why would i need to sand it down if the factory paint is just faded but not rough or anything?
  17. Apr 20, 2022 at 9:00 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Paint manufacturers specify a surface condition or preparation to promote adhesion of their coating - for example, abrasive blast bare metal with 120 grit media. Or, lightly sand with 220 grit between coats. This is to give the surface some tooth for the next coat to properly bond.
    Prep is 90-95% of a good paint job. The other 90-95% is coating thickness, time, clean dry air, humidity, temperature, etc. Think you shot yourself in the foot by applying a second coat with the wrong timing AND by wiping down the first coat for some reason. Best to follow manufacturer recommendations down to the letter in these cases, since paint usually has a "recoat within X hours or after Y hours." If you recoat after X but before Y the surface of the paint won't bond but is still curing beneath and the second coat prevents proper curing and doesn't adhere properly either.
    photogr4x4 and Too Stroked like this.
  18. Apr 20, 2022 at 9:08 AM
    TacoTimbo
    South Denver
    2015 Tacoma TRD
    Paint bonds to the substrate in one of two ways, chemical or mechanical adhesion. Chemical adhesion is when the molecules in the substrate bond with the molecules in the paint and lock together to create adhesion. This is typical with base coat over sealer, or clear over basecoat. What youre doing requires mechanical adhesion, aka sanding. An OEM finish being fully cured means that a new top coat will not adhere to the surface without sanding scratches which offer the paint something to "bite" into.
    You mentioned that your clear is flaking in some spots and the paint is fading. It is well known that these trucks often experience a top coat break down due to UV exposure. A paint job is only as good as what is underneath it, so if your substrate is failing, your new paint wont last either. You will need to sand down and degloss any panel you intend on repainting, and you will need to "feather out" any areas where the clear is flaking. Flaking paint means its not sticking anymore, so your new paint wont stick to those areas either.
    Painting a vehicle is easy in theory, but there are many details that must be accounted for during the process to achieve a successful, durable paint job. There are also many, many things that can go wrong along the way, and of you dont have a thorough understanding of the process and your material and equipment, it can be an exhaustive, frustrating, expensive endeavor.
    I always appreciate the DIY spirit, but at the risk of sounding like a dick, there are some things that ought to be tackled by a professional. Your rustoleum will clean up with lacquer thinner, and youre going to need to start over with proper abrasion and prep. Happy to answer any other questions for you. Good luck my man!
    photogr4x4, burrito782 and Musubi3 like this.
  19. Apr 20, 2022 at 9:10 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Sanding helps prepare the surface for better adhesion. Paint will stick better to a roughed up surface better than a smooth surface. Of course this is a general concept. Sanding isn't ALWAYS necessary in every situation. Sometimes you sand before painting and/or between coats, sometimes not. Depends on what you're painting and what kinds of paints you're using.
    Additionally, if you're dealing with a car with damaged paint already you may need to remove the top layer of damaged paint before applying new paint. Not saying you need to go down to metal but if you apply fresh paint over paint that is already compromised and deteriorating you're basically applying paint to an unstable surface that could cause a sub-par finish and poor adhesion as the unstable layer underneath continues to degrade.
  20. Apr 20, 2022 at 11:06 AM
    TacoBell07
    Four door 2wd Taco
    So
    [QUOTE="TacoTimbo, post: 27219043, member: 232763"
    You mentioned that your clear is flaking in some spots and the paint is fading. It is well known that these trucks often experience a top coat break down due to UV exposure. A paint job is only as good as what is underneath it, so if your substrate is failing, your new paint wont last either. You will need to sand down and degloss any panel you intend on repainting, and you will need to "feather out" any areas where the clear is flaking. Flaking paint means its not sticking anymore, so your new paint wont stick to those areas either.}
    Whatever clear coat parts that were flaking I sanded but I didn't sand the entire fender or roof if it did not have any flaky areas.
    So hypothetically even if my factory paint was faded but the clear coat was not flaking then I would still need to fine sand it at least 300-400 otherwise the paint wont stick?
    So basically any coat you add has to have some type of sanding done (via mechanical application) so a coat on top of factory paint will thereby never really bond correctly with a new coat you add?
