Paint or Wrap?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zinjhor, Jun 18, 2019.
  1. Jun 18, 2019 at 7:27 PM
    zinjhor
    zinjhor [OP] Active Member
    2018 Tacoma Double Cab TRD Off-Road
    Hello everyone, my Tacoma has multiple scratches on both sides from off-roading, recently I tried to remove it using scratch removers, but to no avail. I tried several different brands of scratch removers and it barely worked. 80-90% of the scratches are still visible. I'm looking at 2 options to remove the scratches: Get a paint job or wrap the truck.
    I was wondering if you guys can help me out which option I should pick. If you guys don't mind sharing your experience about it: How much will it cost? Which option would be durable in the long run? What to ask for/look for when talking to auto body shops?
    Thanks, I look forward to your response.
  2. Jun 18, 2019 at 7:28 PM
    tcjacado
    tcjacado Well-Known Member
    :worthless:
    I would go with a wrap.
    tacotroy17 and Junkhead like this.
  3. Jun 18, 2019 at 7:32 PM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    I’m glad you posted this as I’m thinking of having my truck wrapped also and have been trying to find out if it would hold up to the vicious mesquites we have in this area. It’s easy to identifying the trucks that are used off road around here due to the number of “pinstripes”.
  4. Jun 18, 2019 at 7:32 PM
    zinjhor
    Thanks for the reply.
    Should I post photos of my scratched up truck?
    tcjacado[QUOTED] likes this.
  5. Jun 18, 2019 at 7:33 PM
    Sparky.
    Sparky. Bought, built, totaled
    Dawson
    Enumclaw Washington
    ‘14 AC 6MT -R.I.P, ‘08 cummins
    1.) go Offroad
    2.) wear scratches with pride
    3.) repeat steps 1&2
  6. Jun 18, 2019 at 7:33 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I would paint it. Lowe's has black spray paint for 99 cents a can FWIW
  7. Jun 18, 2019 at 7:34 PM
    Sparky.
    Dawson
    Enumclaw Washington
    But black shows scratches :facepalm:
  8. Jun 18, 2019 at 7:42 PM
    Mayonayze
    Mayonayze Well-Known Member
    Wrap it! I’d go that way once my paint got bad enough. You can get some awesome stuff done on a wrap, and when you get tired of it or of it gets too beat up, peel it and get it re-wrapped!
  9. Jun 18, 2019 at 7:43 PM
    Wulf
    rock raisin
    Yeah, but at 99 cents a can it's easy to touch up.
    What happens when you scratch a wrap? You have to rewrap that whole panel/section
    shane100700 and whatstcp like this.
  10. Jun 18, 2019 at 8:12 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Wraps are expensive. Paint jobs are expensive. Neither are scratch resistant so it will happen again unless you never go off road. Ever.
    Chew and alexplb like this.
  11. Jun 18, 2019 at 8:18 PM
    SoCalTaco8
    SoCalTaco8 Active Member
    Jerry
    Pomona
    2017 White Tacoma Sport TRD 4X4
    MBRP 3 inch Cat Back Exchaust, TRD Pro Grill, Speaker Upgrade, Plastic Dip Sport Wheels, Red TRD badge, Painted Red front Brake Calipers, Door sill Vinyl Letters, Tailgate vinyl letter inserts, Cabin LED Bulbs, Headlamp/Fog Light LED upgrade
    check out goattruckarmor its like a magnetic armor you apply to your truck when you hit the trails
  12. Jun 18, 2019 at 9:08 PM
    sparechange
    sparechange Well-Known Member
    Snoqualmie, WA
    2016 DCSB OR
    second hand lift, fuzzy dice
    depending how bad your scratches are you might be surprised how much a good detail shop can get out. Might be worth taking her in to one and talking to them, could save you a pile of money
    suaveflooder and Chew like this.
  13. Jun 19, 2019 at 10:37 AM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Have you considered Plasti-dip?
    You can get large cans when painting the truck, and rattle cans for touch ups if you scratch it. Won't solve gouges though.
