Paint Codes Listed/Explained
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WHPLSH3, Jun 1, 2013.
  1. Jun 1, 2013 at 9:59 AM
    WHPLSH3
    WHPLSH3 [OP] Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    There seems to be a need for a list like this, so I researched all the paint books in the shop and compiled one.
    On the bottom left corner of the sticker in your doorjamb that has the serial number is the paint code. It is always under the bar code. "C/TR" stands for Color/Trim. Color is the exterior color, trim is the interior color. Beside those codes are "A/TM", which are axle and transmission codes.
    The sticker below is from a 2013 Sequoia, and is common in most other Toyotas:
    As you can see, the code is still bottom left. Just the axle/trans codes have moved. (1D6 is Silver Sky Metallic, available on Sequioas, Siennas, and Tundras)
    In the world of Toyota, the colors are grouped according to color family. All the whites start with 0, silvers start with 1, blacks start with 2, reds start with 3, etc. There seems to be no rhyme or reason as to what combination of characters the engineers use to name these codes. All automakers code their colors with some system that is unique to them, that seemingly makes no sense to anyone else!
    So, here's what was, and is, available on 2nd gens.
    040 - Super White - 2005-13
    202 - Black - 2005-13.
    -Limited availability 2008-12, Full availability 2013
    209 - Black Mica/Metallic - 2005-06.
    -Renamed Black Sand Mica 2007. Renamed Black Sand Pearl 2008-09. Discontinued 2010
    1E7 - Silver Metallic - 2005-06.
    -Renamed Silver Streak Metallic 2007-13
    1G3 - Magnetic Gray Metallic - 2009-13
    3L5 - Radiant Red - 2005-08.
    -Reintroduced 2011. Discontinued 2012
    3P1 - Red Mica/Metallic - 2005-06.
    -Renamed Impulse Red Metallic 2007. Renamed Impulse Red Pearl 2008. Discontinued 2009
    3R3 - Barcelona Red Pearl - 2009-13
    4Q2 - Beige Mica - 2005-06.
    -Renamed Desert Sand Mica 2007. Renamed Desert Sand Pearl 2008. Discontinued 2009
    4T3 - Pyrite Pearl - 2009-13
    6T8 - Timberland Pearl - 2009-11. Discontinued 2012
    6V4 - Spruce Mica - 2012-13
    8P1 - Blue Metallic - 2005-06.
    -Renamed Speedway Blue 2007-08. Renamed Speedway Blue Pearl 2009. Replaced by 8T7 for 2010 only (supplier problem?), back for 2011, discontinued 2012
    8P4 - Dark Blue Mica - 2006.
    -Renamed Indigo Ink Mica 2007. Renamed Indigo Ink Pearl 2008. Discontinued 2009
    8S6 - Nautical Blue Pearl - 2012-13
    8T7 - Blue Streak Pearl - 2010 only. Replaced Speedway Blue for this model year.
    Enjoy!:cheers:
    SR-71A and Benzdriver81 like this.
  2. Jun 1, 2013 at 11:44 AM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Nice list, but not fully correct.
    8p4 was available in 2005 as indigo ink pearl...
    I know, as there is one in my garage...
    Edit to add...the color was always known as indigo ink pearl through out it's run from '05-'08...
    Nautical Blue metallic is a similar color released in 2012 as code 8s6
  3. Jun 1, 2013 at 11:53 AM
    WHPLSH3
    Vance
    Alberta
    I should have put a disclaimer at the bottom! This is the info my PPG books told me. There's always model year overlap with colors that are introduced... Nice catch, though!
  4. Jun 1, 2013 at 11:54 AM
    jmg256
    Al Tonter
    TRD Offroad
    I made edits above...
  5. Jun 1, 2013 at 12:05 PM
    WHPLSH3
    Vance
    Alberta
    I should also mention that automakers and paint suppliers seem to interchange "pearl" and "mica" freely. Pearl is actual crushed pearl. Mica is a color coated metallic, and metallics are ground aluminum of various sizes.
  6. Jun 1, 2013 at 12:08 PM
    jmg256
    Al Tonter
    TRD Offroad
    Some 'metallics' are actually plastic as well...
    And the original mica comes from actual mica, the mineral :thumbsup:
  7. Nov 19, 2013 at 7:59 PM
    Volfiretaco
    Volfiretaco Member
    Tuftonboro,NH
    11 Tacoma Doublecab
    3" lift, reinforced front bumper from road armor, plastidiped rims and badges
    umm 4t3 with a 2011 tacoma is not pyrite pearl its pyrite mica its a bronze color
  8. Sep 23, 2014 at 10:19 PM
    rcbaughn
    rcbaughn Member
    Cory
    Lynn, AL
    FJ Cruiser
    Fierce Attitudes, 3" Toytec
    I was only able to find 1F7 at my local Autozone in the Duplicolor Perfect match paint. Anyone know if this is the same as the 1E7, or maybe a mislabeling?
  9. Jun 16, 2015 at 7:14 AM
    Kysport
    Kysport Well-Known Member
    Louisville, Kentucky
    2020 Silver Sky Metallic Limited
    8T5 is Blue Ribbon Metallic
  10. Jun 16, 2015 at 12:58 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    From what I have been able to gather 040 Super White II is actually many similar but slightly different shades of white. That's one reason it's such a crapshoot getting a good match when buying a can of touchup paint off the shelf. The answer is to take our Super White trucks to an automotive paint retailer/wholsaler and have them match and mix. They can provide aerosol cans or paint for traditional spraying. The second problem with matching is the color is one of the very few single stage paints (no second stage clear coat) still in use by any auto manufacturer. Since that's the case don't apply a clear coat even if it says to do so on the can or website. It will change the color (generally to something slightly yellower) and the gloss resulting in an unsatisfactory match.
  11. Jul 22, 2015 at 8:45 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Steelhd, have you used any of the single stage 040 spray paints? I have a couple of spots that I'd like to touch up but I want to know what kind of finish they give without the clear. All the mfgs suggest clear even though the existing paint is single stage, and their other colors look matte before the clear.
  12. Jul 22, 2015 at 9:38 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Single stage paint was called paint. Its been many years but I sprayed hundreds of gallons of enamels, laquers, and urethanes. We didn't use clear coats on every job, especially with the enamels if I remember correctly, and they polished up and shined just fine.
    Just stop by your local automotive paint dealer and see what they say. Am betting they will set you up with a can of properly matched paint and instructions on how to prep, apply, and polish it.
  13. Jul 23, 2015 at 6:56 AM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    The only place near me willing to mix and fill a can is Sherwin Williams (the auto supply side) and the guy told me 1) I'd have to buy 3 cans (~$65) and 2) they mix based on the code, not the truck...so it wasn't going to be a match. Yes, he outright told me it wasn't going to match.
    I guess my plan B should've been my plan A...prep/paint a piece of scrap metal and see what the finish looks like with/without clear.
