Paddle tires with 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DSMJRV, Nov 25, 2014.
  1. Nov 25, 2014 at 9:12 AM
    DSMJRV
    DSMJRV [OP] Well-Known Member
    justin
    Corona, CA
    i want to get some paddles for the rear of my truck to run in the dunes, however i want to be able to run 4wd at the same time.. if i run normal 31s on the front, what size do i need for the back? do i need a 31 inch core which would make the tire about 33 inches including the scoops/paddles? or do i need more like a 29 inch core with the total diameter including scoops to be 31 inches?
    Im not too keen on running 2wd out there on a nose heavy 4wd truck, and i go pretty hard out there, so i don't want to worry about any drive train bind even though its just sand..
  2. Nov 25, 2014 at 9:42 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If you don't have fiberglass fenders, keep the outer diameter including scoops 31" to avoid rubbing.
    If you must run conventional tires in the front, pick one that has the same "revs per mile" spec as the paddle tires. This accounts for all the differences in loaded diameter, scoop compression on pavement, etc.
  3. Nov 25, 2014 at 11:11 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    We have enough power to turn them but maybe not enough power to spin them and/or use as designed. I don't think miniscule differences in outside diameter will hurt anything in the sand so long as you don't have anything hard to drive on to get there. If you do throw a set of paddles on the rear post a picture because I don't think I have seen that before.
  4. Nov 25, 2014 at 12:06 PM
    DSMJRV
    justin
    Corona, CA
    thats some sound advice.
    my truck is supercharged so that will help me a bit. plus i think its more about what paddle tires you use, like how many paddles and how large each paddle is.. im looking at some with 16, 1 inch scoops and they only weigh 26lbs vs your normal AT tire that weighs 40-60lbs.. its not like im daft enough to throw something on there that is built for a 700hp 2000lb sand rail, with 30 x 3 inch scoops :/
    im on a 3 inch ome lift, and im not ready for full long travel yet as it is my DD, i don't think my wallet is ready yet either lol...
  5. Nov 25, 2014 at 12:21 PM
    ChiefManyWrenches
    Florida
    But that is how all the cool kids do it. :cool:
  6. Nov 25, 2014 at 12:31 PM
    DSMJRV
    justin
    Corona, CA
    i was thinking the same thing, especially just farting around... but at 80+ mph i don't just wanna guess at it ya know..
  7. Nov 25, 2014 at 1:44 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If anything, run a slightly smaller in the rear to avoid plowing of the front tires
  8. Nov 25, 2014 at 2:10 PM
    DSMJRV
    justin
    Corona, CA
    ^ ya i was thinking that too, paddles work better when throwing sand.. i'd rather drag them at high speeds when i cant get stuck than dig them at low speeds...
    thx for the help guys i think ima go with the 29 core plus 1 inch paddles... ill report back
  9. Nov 25, 2014 at 2:58 PM
    KenLyns
    Belly of the Beast
    Correct. In the sand, the non-paddle front tires will just slip as necessary to prevent driveline binding. On hard surfaces, the OP could always just drive in 2Hi.
  10. Nov 25, 2014 at 3:33 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I was going to say something... but why? LOL
  11. Nov 25, 2014 at 3:39 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    interesting... I may have questions for you before my next trip out to Glamis.. :cool:
  12. Nov 25, 2014 at 3:48 PM
    KenLyns
    Belly of the Beast
  13. Nov 25, 2014 at 7:53 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I've found a decent set of MT's will get you anywhere you'd like to go in the dunes, and that I run out of motor long before I run out of traction. They sure do look cool though.
    This dude runs out of traction before he runs out of motor. Paddles are a prudent choice.
    http://youtu.be/YQGg1pprZCg
  14. Nov 26, 2014 at 8:36 AM
    DSMJRV
    justin
    Corona, CA
    MTs are a little heavy, but a nice wide AT aired down to about 12 has gotten me really good results.. i have been in plenty of situations in glamis where i was traction limited and not power limited.. ever find yourself at the bottom of a "witches eye" of basically sinking sand? ever try to climb china wall?
    another member here just hooked these up:
  15. Nov 26, 2014 at 8:40 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thats what I air down to.. 12.. with AT's.. although i do have 4wd.. I usually cruise in 2hi locked.. more fun that way. :)
