Packout Bed Slide
Discussion in 'Garage / Workshop' started by BronzeOxide, May 4, 2024.
  1. May 4, 2024 at 10:18 AM
    BronzeOxide
    BronzeOxide [OP] Well-Known Member
    Huntingdon County PA
    2024 TRD Sport
    I started this today. I’m waiting on drawer slides. I’m picturing a 2” angle frame to mount the tray in. I think I want to weld on tabs and use the truck bed bolts to tie it to the truck. I don’t want to drill holes in the bed unless I have to. This frame is 1” box and angle. Plus .125 flat steel. I’m posting pics of the process in case anyone is interested
    Steves104x4 and soundman98 like this.
  2. May 6, 2024 at 5:02 AM
    BronzeOxide
    2024 TRD Sport
    Slides and low profile bolts on the way
  3. May 10, 2024 at 2:47 PM
    BronzeOxide
    2024 TRD Sport
    Stainless 1/4 20 riv nuts installed. First time using an actual tool. It works better than an impact for stainless
  4. May 10, 2024 at 2:57 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Why don't you put a wood platform under this in you truck bed and bolt the slide to the wood frame? As long as the frame is well fitted between the two sides of the bed, it won't slide around.
    BronzeOxide[OP] likes this.
  5. May 11, 2024 at 1:47 PM
    BronzeOxide
    2024 TRD Sport
    I am trying to stay away from wood. I picked some 1.5” angle for the bottom frame. I want to add tabs and bolt it down using the factory bed bolts. I’m concerned that it will want to tip forward when I pull the slide out. I’ll have slides soon too
    sdsurfer likes this.
  6. May 14, 2024 at 2:15 PM
    tacomeat123
    tacomeat123 New Member
  7. May 15, 2024 at 4:55 AM
    BronzeOxide
    2024 TRD Sport
    That’s nice. I also saw a couple made with plywood and 2x4s. I’m copying their ideas. I will have about $100 in steel, $65 for drawer slides and $60 for 2 pack out plates. About 230 total with paint and hardware
  8. May 15, 2024 at 5:06 PM
    BronzeOxide
    2024 TRD Sport
    A little more progress. 10-32 bolts going in. Now that the slides are mounted in the rails, I’ll weld in cross pieces to set the width of the rails. Hoping that will eliminate any bind
  9. May 15, 2024 at 5:09 PM
    BronzeOxide
    2024 TRD Sport
    Tray installed
    soundman98 likes this.
  10. May 17, 2024 at 12:22 PM
    BronzeOxide
    2024 TRD Sport
