P2757 transmission code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CorrosiveTendency, Oct 27, 2020.
  1. Oct 27, 2020 at 11:08 AM
    CorrosiveTendency
    CorrosiveTendency [OP] When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Late last night the truck sprung a leak after some highway running. ATF leaking from the plastic cover on the bell housing and the P2757 code. Nursed it 120 miles home. The only thing I noticed is that 5th slips a bit, otherwise shifted normal.
    233k miles with one full fluid swap over a year ago.
    So my dilemma...do I let a shop diagnose and repair it? Swap for a salvage transmission or just unload the truck as it?
    It has been good to me but is starting to nickle and dime me and the head gasket is a time bomb.
    Has anyone had luck having the TCC solenoid replaced and most likely front seal?
    Time for a Tundra?
  2. Oct 27, 2020 at 12:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That code is for the TQ converter either not locking up, or is staying locked up.
    One of the problem areas to check is line pressure. And a leak can/will cause pressure issues.
    Either way, it sound like more a job than I’d want to.
    I understand your situation, that heat and that many miles.
    I’d be tempted to let it find a new how.
    But I don’t think you’ll get much for it with the current problem it has?
    Sorry brother:fingerscrossed:
  3. Oct 27, 2020 at 12:11 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
  4. Oct 27, 2020 at 12:16 PM
    gearcruncher
    Canadain bumper technician
    Probably a false code due to the front seal leak .
    12TRDTacoma and TnShooter like this.
  5. Oct 27, 2020 at 12:44 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That feeling of 5th gear slipping could be the torque converter struggling to achieve lockup. I'd happily pay someone to diagnose it correctly before i dumped the truck
    12TRDTacoma likes this.
  6. Oct 27, 2020 at 12:50 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Drop the pan, change out the screen, add some maxlife atf along with lubegard. The head gasket is one of those things that may go. You can always pressure test the cooling system. If everything holds why waste money on another truck unless you want something else.
  7. Oct 27, 2020 at 12:56 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Probably low on fluid... fix leak and fill it properly....
    TireFire likes this.
  8. Oct 27, 2020 at 1:09 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    I wouldn't trade it in, sell it as it for whatever I could get.
    My concern is having a vehicle that I am not 100% confident in anymore. Another concern is effective diagnosis and repair. Transmissions are so damn complicated.
  9. Oct 27, 2020 at 1:13 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Surely low now
  10. Oct 27, 2020 at 1:14 PM
    TnShooter
    Deogee
    STOCK
    I hear you there, I couldn’t fix the transmission myself.
    (Or at least I don’t have the knowledge to do it “right”)
    So I’d likely have to have someone do it for me.
    Which, like you say, puts a lot of money into a truck that’s known to have HG problems.
    I guess it depends on your financial situation.
    If I could afford too, I’d sell it “as is” and look for another truck.
  11. Oct 27, 2020 at 1:30 PM
    gearcruncher
    Dont drive it low on fluid as you will roast the transmission
    How much fluid is leaking from the front of the bellhousing ? Does it leak more when the truck sits overnight or when the truck is moving ?
    https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
    Are you planning to tackle this job yourself ?
    Take transmission out , investigate the leak , fix the leak , then re-install ? Parts are cheap if its just seals
  12. Oct 27, 2020 at 1:54 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Definitely not doing this myself. Going to take it in to work and let our mechanic see if it is the seal or what.
    It leaks when it's running. Several drips every 10 seconds or so.
  13. Oct 27, 2020 at 1:59 PM
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Most likely the torque converter seal. R&R trans. Remove torque converter to inspect and replace seal if that’s all that’s leaking.
  14. Oct 27, 2020 at 1:59 PM
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Nothing up top leaking as like the trans cooler lines on the passenger side? Just making sure
  15. Oct 27, 2020 at 2:01 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Someone (who will remain anonymous) told me that seals only go out because something is out of round....... this can't truly be the case. Seals fail from dirt and just age......
  16. Oct 27, 2020 at 2:03 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    The lower line is wet but it is from oil being blown back. The whole underside of the truck is coated. Only active leak i see is when it is running, coming out from the Bell housing cover.
    T-yoda[QUOTED] likes this.
  17. Oct 27, 2020 at 2:30 PM
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Mind me asking how the frame is? Was it replaced ? Asking so you don’t throw money as something that is not solid
  18. Oct 27, 2020 at 2:40 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Frame is Grrrrrrrreat! Replaced 5 or 6 years ago. Hell the body is even great. Interior is better than I would expect having 2 kids and a dog.
  19. Oct 27, 2020 at 3:14 PM
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Ok well ya got a sound truck, just needs some upkeep... I’d say gather some quotes and see what happens
  20. Oct 27, 2020 at 3:20 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I second this. New trucks also means new truck payments. Just the first one is likely more than this repair will cost
