P2433 CODE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nicademus98, Oct 27, 2023.
  1. Oct 27, 2023 at 3:31 AM
    nicademus98
    nicademus98 [OP] New Member
    Nick
    Long Island, NY
    2006 Black Tacoma Access cab 4 cyl AT
    2006 Tacoma Access Cab, 2.7L engine, A/T
    Check engine light on.
    Evap System leak??? Help!!
  2. Oct 27, 2023 at 11:43 AM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    Did you google the code? Seem kinda serious based on this video.
    https://www.youtube.com/watch?v=2p8LwxIfRcg
    I dont know thou.....
    I have an 06 but the v6. I don't think my truck has a secondary air injection system. Maybe yours does.
    https://www.youtube.com/watch?v=uG87HzkNzCI
    Any chance it's the gas cap? I once had an Evap leak code when I was first learning. The Autozone guy said to buy the gas cap and it worked.....
    Good Luck.
  3. Oct 27, 2023 at 5:11 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That code has nothing to do with the EVAP System, it's for the Secondary Air Injection System Pressure Sensor circuit.
    Make sure the sensor is plugged in, if it is you may have a wiring issue.
    If you have a scanner that can read live data for the SAIS you can see what the pressure sensor is reading.
