P2420 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ashe21, Sep 21, 2023.
  1. Sep 21, 2023 at 5:20 AM
    ashe21
    ashe21 [OP] Member
    2013-build date 2/13. P2420 code only. Gas cap was really suspect, replaced with a new OEM one. After clearing "Check Engine" Trac Off" MIL light, and driving a short time it still shows a "P2420 Permanent" & "P2420 Pending". Looks like the Vapor Canister is self enclosed with several non repairable internal parts including the Switching Valve which triggers the P2420 code. If it not a wiring/voltage problem, what else other than the Vapor Canister unit might log the lone P2420 code? (there are 2 different Vapor Canisters for the 2013 model, depends on your build date)
  2. Sep 21, 2023 at 8:57 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It could also be a broken wire on the vent valve control circuit, you need to check the vent valve circuit.
    Pin 5 (Blue/White) should have battery voltage with the key on and the PCM should ground Pin 1 (Violet/White) when the vent valve is commanded on (you would need a bi-directional scan tool to do this).
    Wiring diagram attached below assuming you have the 4.0L engine.
    ashe21[OP] and Kolter45 like this.
  3. Sep 21, 2023 at 9:00 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Did you get the OEM one from a dealer? If so, it's probably good. If you got it from Amazon or elsewhere, you might try one from a dealer. My daughter lost one on the 4Runner and the Amazon one I got didn't fix it, dealer one did.
  4. Sep 21, 2023 at 12:48 PM
    ashe21
    ashe21 [OP] Member
    Thanks, I just scrolled through 455 pages of schematics looking for what you narrowed down to 20 pages!
  5. Sep 21, 2023 at 1:00 PM
    ashe21
    ashe21 [OP] Member
    I'm thinking that exactly what's happening. I bought the supposedly OEM cap from Amazon, now certain it's black market and bad. This afternoon the P2420 code has disappeared an now a P0441 and P0455. I'm almost certain I have 2 bad gas caps, and have a new one on order to pickup tomorrow from the local Toyota dealership. (i thought I could find a place to test gas caps for free, NOT!)
  6. Sep 21, 2023 at 1:51 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yeah, the one I got looked pretty legit. It was like $17, and I think the OEM one from the dealer was $38. Definitely worth the extra dollars, it cleared the code within a day.
    Not saying that is your problem, but it's something to rule out.
  7. Sep 21, 2023 at 2:00 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    Not that this has anything to do with your issue but how many miles and where are you located (Climate). I have a 2013 as well. Thanks.
  8. Sep 21, 2023 at 2:01 PM
    ashe21
    ashe21 [OP] Member
    I took the seal off the Amazon cap and installed it on the original cap, and so far it appears to be a drastic improvement. Really not wanting to be laying under the bed of the truck to test/disconnect/reinstall a new vapor cannister $$$
  9. Sep 21, 2023 at 2:03 PM
    ashe21
    ashe21 [OP] Member
    170 K, SouthEast USA
  10. Sep 23, 2023 at 11:27 AM
    ashe21
    ashe21 [OP] Member
    832F8496-D394-4CD8-9451-306B9078EAF6.jpg Original bad gas cap, bad first replacement gas cap, and nothing to do with the 500$ Vapor Canister.
