P2401 code? erase and forget about it 'til is comes back?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ffemt2987, Dec 6, 2011.
  1. Dec 6, 2011 at 11:21 AM
    ffemt2987
    ffemt2987 [OP] Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    The other day the check engine light in my 05 Tacoma with 65000 miles came on. The code was "P2401 Evaporative Emission System Leak Detection Pump Control Circuit Low". I haven't noticed any change in performance or fuel mileage. I erased the code and drove home from O'reilly's and it's still off. Should I just forget about it? Anyone had this issue? Thanks
  2. Dec 6, 2011 at 11:25 AM
    snoozeworm
    snoozeworm taco king
    wheeling,wv
    2004 regular cab 4x4 5 speed
    Extra leaf springs in rear Pioneer head unit fj cruiser wheels 1in coil spacers siren
    yeah, mine has been on for over 20,000 miles. The only problem i was having is that when i filled up my gas tank, or when my truck sat through a cold night and then a hot day without being started, the fumes from the gas tank would swell up and run backwards through the charcoal filter (or a related valve) and cause my truck to not start without cranking it forever. I just re-routed the gas tank vent line to another location and problem solved.
    **Because my check engine light is always on, i periodically scan the codes to make sure that nothing new has popped up. Otherwise you could have a new code and never know because you are so used to seeing that light on.
  3. Dec 6, 2011 at 12:01 PM
    ffemt2987
    Austin
    Golden
    Thanks for the reply. I wondered if it had to do with it being near 0F the other night. I guess I'll see if it comes back on, then maybe I'll look into that mod you did.
  4. Dec 6, 2011 at 12:07 PM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like you might need a new canister module since the malfunctioning pump is inside of it. Or it could just be the vsv for the purge.
  5. Dec 6, 2011 at 2:41 PM
    snoozeworm
    wheeling,wv
    I wouldn't reccomend doing that mod unless you have my specific problem, it seems to be a rare problem that does not occur with every case of that check engine code. Wait and see if you need it before you waste your time.
  6. Dec 7, 2011 at 1:25 PM
    ffemt2987
    Austin
    Golden
    Well, the light never came back on. I am thinking the gas cap may have been loose or it had to do with the 0degree temps. Another forum mentioned the cap. Thanks fellas
  7. Jan 5, 2012 at 4:27 PM
    brian65oh
    brian65oh Well-Known Member
    Brian
    Nor Cal (currently stationed in Jax beach FL)
    05 pre runner
    camburg long travel w/ race runner 2.5x8 co Deaver springs spintech race muffler kn cold air intake
    i just did the exact same thing, started by truck and the check engine light came on i have 74000 on an 05 and went to oreillys got the p2401 code cleared it and has not come back on all day, how has yours been since you posted a month ago?
  8. Jan 6, 2012 at 7:46 AM
    ffemt2987
    Austin
    Golden
    It came back on once. I cleared it again and I haven't had it come on. Nor have I had any issues that I have noticed. I think the weather had something to do with it the first time honestly. Being about 0* F that is.
