P2238 CEL
Discussion in 'Technical Chat' started by boshak, Apr 23, 2012.
  1. Apr 23, 2012 at 7:58 PM
    boshak
    boshak [OP] Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    I've cleared this code about 3 times over the past month. It's a definite problem.
    Any recommendations on checking for causes. Any definite or successful fixes?
    Heres what I read in the FSM of probable causes...
    - Open in A/F sensor circuit
    - A/F sensor
    - A/F sensor heater
    - EFI main relay
  2. Apr 23, 2012 at 8:05 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Most likely cause is the A/F sensor. You need to ohm out the wires on the sensor with a multi meter. 2 of the wires should have an ohm reading. All other wires on the sensor should not. If all the wires show open then the sensor is bad.
    Edit: there should be 4 wires on the sensor (if I remember correctly).
  3. Apr 23, 2012 at 8:25 PM
    boshak
    AG
    CA
    Thanks Nelson. If I replace the AFR sensor, should I replace the o2 sensor also?
  4. Apr 24, 2012 at 3:15 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) You may want to hold off on getting that AFR sensor before you do your O2 sensor. My book shows that P2238 code is : O2 sensor positive current control circuit low, bank 1 sensor 1. This is your front O2 sensor on your driver's side before the catalytic convertor, and I believe this is your problem.
    I don't like the idea of throwing parts at a problem, and you can test the O2 to make sure it is bad, but I believe that the O2 sensor is bad and throwing your code. Testing requires back probing the sensor as the truck runs and this may not be easy to do. If the O2 sensor has never been replaced, you may want to do that before buying the AFR sensor.
    This is just my opinion and I am sure there will be others, so read them all and decide your course of action. Good Luck.
  5. Apr 24, 2012 at 6:26 AM
    NelsonTacoma
    Tucson, AZ
    An O2 sensor is the same thing as an A/F sensor. FYI :)
    http://www.autoshop101.com/forms/h37.pdf
  6. Apr 24, 2012 at 6:31 AM
    NelsonTacoma
    Tucson, AZ
    No. If it was needed there would be a code for that also. Let us know how it turns out.
  7. Apr 24, 2012 at 10:05 AM
    boshak
    AG
    CA
    What the... My parts guy at the dealer is asking $180 for the part. Says the California o2's cost more.
    Anybody know where I can get it cheaper?
  8. Apr 24, 2012 at 11:44 AM
    Ga tacoguy
    Rudy
    Augusta Ga.
    :) I live in Ga., But I looked on Autozone and they want 118 for the Bosch Brand sensor. I hope the one in cali.should not cost more, but you may want to check for one. You do not need to go to the dealer, as there are alternatives, so you may want to check all your local auto parts places. Good Luck
    P.S. you may want to start spraying some kind of rust penetrant on the bolts that hold the O2 sensor and let them start to soak. Those bolts can be tough to take out.
  9. Apr 24, 2012 at 12:07 PM
    boshak
    AG
    CA
    Thanks for the info. Ill spray some pb blaster for now and swap it out over the weekend.
    I found the connection... Easy to find under the shifter boots inside the truck. I was able to remove it from the clip holding it to the top of the tranny. How do I disconnect? Do I squeeze with pliers or is there a slot for a small screwdriver?
  10. Apr 24, 2012 at 12:33 PM
    Ga tacoguy
    Rudy
    Augusta Ga.
    :) Good Luck, here is a link to pictoral on changing out the sensor. http://autodiyonline.com/toyota-diys/toyota-tacoma-diys/toyota-tacoma-1995-2004-3-4l-oxygen-sensor-replacment-diy/
    They recommend breaking the plastic clip that holds the wire to the transmission and then unplugging the wire. I would guess that you will need to squeeze the plastic clip on the transmission side of the wires. Be careful, as those wire connectors will be old and the plastic will be fragile.
    The PB buster is a fine choice for a penetrant. I hope this is a easy job for you, you sound like you have turned a few wrenchs before.
  11. Jun 23, 2018 at 5:46 AM
    k5amu1
    k5amu1 Member
    2003 Tacoma Double Cab 4x4
    Camper Shell
    Will the P2238 code prevent the truck from starting/running? Mine just came on and I've cleared it 3 times but the truck runs fine.
  12. Jun 24, 2018 at 4:29 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    No the code will not prevent the truck from running, there are very very very few codes that if set will do that. P2238 is emission related, thus its not going to effect how the trucks runs, at least not to any extant you should notice.
    k5amu1[QUOTED] likes this.
  13. Jun 24, 2018 at 5:25 AM
    k5amu1
    k5amu1 Member
    Camper Shell
    Thanks man, I'm not going to worry about then since my state doesn't have inspections. The light came on during a road trip, ended up averaging 22mpg so I knew it must not be too bad.
  14. Jun 24, 2018 at 5:51 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Go with a Denso sensor. They are OEM. Lot of folks have had issues with the Bosch ones.
    More than likely you can get the part on Amazon and have it in your hands in a couple of days.
    k5amu1 likes this.
