P2238 after disconnecting battery
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04Yoda, Jun 17, 2022.
  1. Jun 17, 2022 at 1:38 PM
    04Yoda
    04Yoda [OP] Well-Known Member
    04 Xtra 3.4 5-sp 4WD
    Disconnected battery to swap a bad stereo today. immediately after putting everything together and idling while I was programming the radio I kept throwing and clearing (scan gauge) an O2 sensor code (P2238). Battery voltage was running about 13.8v.
    I cleared the code and drove it for a while to let the alternator do its thing. So far the code has not returned.
    So I’m curious what the hive mind has to say. Was this likely just a temporary voltage issue or am I likely to see this return and find myself replacing a sensor?
    {04, V6, 75K miles}
  2. Jun 18, 2022 at 9:24 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You can only wait and see what happens .
    Might have been a temporary ground issue.
    04Yoda[OP] likes this.
  3. Jun 18, 2022 at 9:33 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I've had this same code pop up with a battery that was almost bad (died a few months later), and again with a newer battery after using it to jump a friend's car. Both times the code eventually cleared on it's own.
    I'm inclined to think it's a temporary voltage issue but see if it comes back
  4. Jun 18, 2022 at 12:23 PM
    04Yoda
    Seems the check engine light and P2238 code triggers if the truck is idling for a while. I don’t see it if I’m driving. AGM truck battery was recently installed and should be good, though I haven’t been running the truck much lately.
    I think I’ll try to pull the upstream O2 sensor and check for resistance on a multi-meter. The sensor is original to this ‘04, but the problem began so soon after disconnecting the battery, I assumed they were related. Occam’s razor and whatnot.
    eon_blue[QUOTED] likes this.
  5. Jun 21, 2022 at 3:01 PM
    04Yoda
    Pulled and replaced the upstream air sensor (Denso 234-9003 for my V6 manual, NAPA online $180). Grabbed a multimeter and checked resistance across the black wires. Open loop. So I guess it was a bad sensor after all.
    Learned:
    a) the Denso sensor comes with a gasket and I didn’t need to buy the $6 gasket separately.
    b) accessing the electrical connector on an ‘04 is a royal PITA. Wound up having to remove the rubber boot of the gear shifter from inside the truck and breaking a plastic clip to access the front of the connector.
    Thanks for sharing your experiences and opinions.
    turbodb and eon_blue like this.
  6. Jun 21, 2022 at 3:49 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Too late now. But I like to ask @turbodb when I have questions about stuff. A few others to. Dan is so thorough and likes to write a book about each repair. Lol! Definitely comes in handy.
    Here was his write up on few things including the upstream sensor.
    https://adventuretaco.com/chasing-the-p0171-engine-light/
    Same part number as yours. Through the top of the shifter.
    I had to replace mine but being an auto. It was easier.
    Glad you got it done
    04Yoda[OP] and turbodb like this.
  7. Jun 21, 2022 at 4:01 PM
    04Yoda
    For sure. Thanks! These photos would have been very helpful as I tried to pry the clip from its anchor point beneath the boot. My method was ultimately successful, but I reattached the clip with a zip tie and probably spent far more time swearing than someone who knew what the hell they were doing.
    Sicyota04[QUOTED] likes this.
