p2109 code after cleaning throttle body, rough idling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MarkNap128, Mar 10, 2023.
  1. Mar 10, 2023 at 10:19 AM
    MarkNap128
    MarkNap128 [OP] Well-Known Member
    Mark
    West Warwick RI
    2013 Black Tacoma TRD Sport 4x4 dbl cab
    None
    Hey guys.
    i’ve been having some issues and getting lots of codes related to my MAF and Throttle body and lean codes on bank 1 and 2. While investigating I found my air filter box is all effed up and not closing tightly along with missing one of those spring clamps. I ordered a new air intake assembly and in the meantime I cleaned the MAF which is fairly new (maybe a year and a half old denso) and that cleared some issues with the MAFs codes. A day later (last night) I cleaned the throttle body. it was filthy and took some time. After getting it all put back together the idle was at 2k rpm (normal right?) and then this morning it was rough idling bouncing up and down. I ran a scan and noticed code P2109 and then went through the steps to reset the sensor. Now it’s hanging around 11-1200 rpm when it’s usually around 750 or 800. if I turn the ac on, it cycles between 800 and 11 or 1200 changing every 4 or 5 seconds. I ran the scan again and i’m still seeing the p2109 code Throttle Position Sensor. Any suggestions?
    appreciate you guys as always
    Mark
    HondaGM likes this.
  2. Mar 10, 2023 at 10:22 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Was there any codes before any work was done?
  3. Mar 10, 2023 at 10:37 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    What did you use to clean the throttle body? Did you allow the ECU to go through the idle relearn process?
    HondaGM likes this.
  4. Mar 10, 2023 at 12:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d pull intake air tube and see if the throttle blade is closing fully.
    Also be sure that the intake tube is attached fully and not allowing air in after the MAF. If you have a scan tool, you might want to see what the MAF is reading engine Off, On, and idling.
    Next, reset the learned ISC.
    Remove the EFI and ETCS fuses at the same time, wait 60 seconds or more, and then reinstall the fuses to reset the ISC learned value.
    Dm93 and HondaGM like this.
  5. Mar 10, 2023 at 1:31 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    The only codes that did not clear are the lean codes for bank 1 and 2 as well as the throttle position sensor code P2109 that I mentioned. These others cleared after cleaning the MAF sensor and Throttle Body. I did not clear the CEL after cleaning them, incorrect purge flow (that valve is somewhat new as is the MAF sensor itself)
    also, I used the CRC throttle body cleaner and a lint free towel and soft bristle toothbrush.
  6. Mar 10, 2023 at 1:33 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    crc throttle body cleaner and yes I believe so I went through the process twice. should I have disconnected the battery because I did not while I was cleaning the TB
  7. Mar 10, 2023 at 1:34 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    I will do this and report back! thanks
  8. Mar 10, 2023 at 1:35 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    You think it maybe has a vacuum leak?
    TnShooter likes this.
  9. Mar 10, 2023 at 1:52 PM
    TnShooter
    Deogee
    STOCK
    With the engine off, and key On.
    What does the MAF read?
    What are your LT Fuel Trims?
  10. Mar 10, 2023 at 5:49 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I think you have a vacuum leak, P2109 and P0101 are rationality codes and being you also have lean codes and a high/unstable Idle the first thing I would be looking for is a vacuum leak.
    The P1605 has the wrong description in your scan tool, it's for rough/unstable idle not a knock sensor.
    The EVAP codes are likely unrelated to the idle problem unless the Purge valve is leaking. Easy enough to check that by unplugging the electrical connector (this will set a circuit code but it can be cleared after reconnecting) and the hose going to the tank and see if there's vacuum present at the port on the valve, if there is the valve is bad.
    Taco 422, winkel, b_r_o and 1 other person like this.
  11. Mar 11, 2023 at 12:21 AM
    MarkNap128
    Mark
    West Warwick RI
    None
  12. Mar 11, 2023 at 12:23 AM
    MarkNap128
    Mark
    West Warwick RI
    None
    I only have a shit scanner - I had recently purchased a bi directional scanner that had live data but it was the one from harbor freight and the first one wouldn’t connect to the truck or any vehicle for that matter and I brought it back and the second scanner I had to hold in an awkward position to get a good connection - those are complete shit
    TnShooter[QUOTED] likes this.
  13. Mar 11, 2023 at 10:46 AM
    MarkNap128
    Mark
    West Warwick RI
    None
    So the idle is solid now. Resting at about 800RPMs. I still have the two lean codes (i’m
    hoping are from unregulated air seeping in where the air filters housing isn’t connected tightly at all but will soon be fixed) and the code that read for the P1605 has cleared and is staying clear. I’ll check the purge valve now to see if there’s a vacuum or not.
    Dm93[QUOTED], winkel and TnShooter like this.
  14. Mar 11, 2023 at 2:57 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    Did you reconnect (on the pass. side) the short hose that goes to the manifold from the back of the air box?
  15. Mar 11, 2023 at 8:29 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    I am not sure which hose that is
    this one?
  16. Mar 12, 2023 at 10:56 AM
    ZMan2k2
    Richard
    ‘Berta
    Nope. Pass. side, up between the firewall and where the filter goes into the air box.
  17. Mar 14, 2023 at 1:49 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    is that supposed to connect to where that small tiny hole is at the back of the air filter housing? there’s a small round hole in the plastic to the left of where the large air hose connects with that phillips head tightening clamp.
    oh jeeze
  18. Mar 14, 2023 at 3:06 PM
    ZMan2k2
    Richard
    ‘Berta
    Yup. There’s a nipple on the back of the air box. Easiest way I found, connect it to the fitting on the manifold, install air box, then attach it to the box. Definite PITA, but doable.
  19. Mar 15, 2023 at 10:59 AM
    MarkNap128
    Mark
    West Warwick RI
    None
    mine is actually connected
    i’m going to test the purge valve as these are the numbers. I’m pulling from a live test.
  20. Mar 16, 2023 at 3:50 PM
    MarkNap128
    Mark
    West Warwick RI
    None
    thanks btw for showing me that. I had to climb up on a stool and use my headlamp to see it.
