P1300 & P1310
Discussion in '1st Gen. Tacomas (1995-2004)' started by Spencer4x4, Aug 9, 2020.
  1. Aug 9, 2020 at 7:06 PM
    Spencer4x4
    Spencer4x4 [OP] Member
    1998 Lifted Regular cab Tacoma 4x4
    I am building a 1998 Toyota Tacoma, and today was supposed to be first start up, but these two codes ruined that. I have no spark when cranking the engine over. It’s a 3RZ 2.7L. I’ve rebuilt the engine with all stock components so nothing crazy with the engine. Stock ECU, I also just replaced a coil pack with a new duralast one. The other coil pack is OEM because autozone only had one today.
  2. Aug 10, 2020 at 2:23 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    So just what are you trying to ask??
    Those are both Igniter circuit issues would be the reason you have no spark
    Either of those codes will shut off the fuel as well.
    Poor connections bent pins not playing well with the ECM
    Engine Harness and the Sensors and the ECM all from the same vehicle ??
  3. Aug 10, 2020 at 6:06 AM
    Spencer4x4
    Yes everything is stock on this truck. I just rebuilt the engine. I was getting fuel just no spark. I’m just trying to figure out if it’s a wiring issue or a ecm issue.
  4. Aug 10, 2020 at 10:18 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Just how are you seeing the injectors fire using Noid lights and seeing the pulse??
    Did your ECM get soaked with water or get a huge voltage spike about the only thing that will cause a ECM that was working to fail..
    where things sitting apart for a long period of time unseen corrosion is always a problem.
    poor ground connections can cause weird problems at times.
  5. Aug 10, 2020 at 10:22 AM
    Spencer4x4
    There was pressure at the regulator and the spark plugs smelled like gas when I pulled them. ECM never got wet, but the truck was sitting for probably 6 or 7 years before I got it. The truck was complete when it was sitting.
