P0770 Code UPDATED 11/18/16
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jerry311SD, Nov 15, 2016.
  1. Nov 15, 2016 at 5:20 AM
    Jerry311SD
    Jerry311SD [OP] Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    WTF
    So 2001 TRD super charged V6 Auto trans
    I have been getting the P0770 Code, Lock up solenoid.
    I was able to get the money together and go the kit with a lock up solenoid and two shift solenoid,filter and gasket. 4 qts of toyota ATF, Also got new plugs and wires.
    Everthing was clean in the trans or the pan, no metal nothing
    Wow my truck runs great!!:burnrubber: pulls hard, idles smooth shifts smooth and everything feels like a new truck. 50 miles later the Check engine light comes on :annoyed: Same effin code, WTF do I do now.
    I have read a few places that one of the fixes might be the coolant temp sensor on the back of the block?
    I am not sure what else to do to fix it . I cant pass stupid Califonia smog with the check engine light, but the truck run perfect.
    Any info or help would be great.
    Brie likes this.
  2. Nov 15, 2016 at 6:37 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
  3. Nov 15, 2016 at 6:49 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    sounds like the torque converter lock up clutch is your issue. also could be a clogged valve body. the test for the solenoid is to apply compressed air into it and see if it leaks air. the other is to apply battery voltage to the solenoid to see if it opens. new parts can be bad too. then if all is good there check valve body for blockage. it that is fine then new torque converter is needed.
    Brie and Jerry311SD[OP] like this.
  4. Nov 15, 2016 at 11:47 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    Bummer I really dont feel like taking the trans out agian. I just took it out a month ago to replace a cracked flexplate.
    Brie likes this.
  5. Nov 15, 2016 at 12:30 PM
    jammer
    Ben
    Bentonville, AR
    Jerry you may have already seen this, but it mentions not only what Doublld mentioned but also the coolant sensor. Hope it works out for ya.
    http://www.transmissionrepaircostguide.com/topic/tacoma-with-p0770-code/
  6. Nov 15, 2016 at 1:16 PM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    I did read that last night. That sounds totaly stupid but I'm going to try that out next it's the cheapest thing to try next.
    Brie likes this.
  7. Nov 16, 2016 at 5:05 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    Driving the truck home lastnight I had the OD off. no check eng light.
    As soon as I turned the OD on. The check eng light came on.
    Gonna do the coolant temp sen this weekend.
    Brie likes this.
  8. Nov 16, 2016 at 6:33 AM
    jammer
    Ben
    Bentonville, AR
    Thanks for the update. Let us know the outcome.
    Jerry311SD[OP] likes this.
  9. Nov 17, 2016 at 5:49 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    Question
    To take out the valve body. Can the trans be in the tuck?
    Or do i need to take the trans out and set it up side down.
    I dont want a bunch of shit falling out if I have to remove the valve body. I'm going to try replaceing the speed sensor and coolant temp sensor first, and go from there.
  10. Nov 17, 2016 at 9:31 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    you can do it in the truck pieces may fall out tho. you can use trans assembly lube to put them back in there holes to keep them there when you put the valve body back in.
  11. Nov 28, 2016 at 5:23 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    This dam truck!
    Ive replace the torque converter solenoid - temp sensor-BOTH speed sensor's input and out put. One of them was 350$
    The truck drives fine but I'm still getting the damm P0770 code. WTF
  12. Nov 28, 2016 at 5:47 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    did you do the diag sequence i sent you?
  13. Nov 28, 2016 at 5:53 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    I did the driving thing several times this weekend.
    The only thing left to do is take out the valve body but i'm just worried about all of the crap that going to fall out of the trans when I do.
  14. Nov 28, 2016 at 5:54 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    did you test the solenoid with air? and check the solenoid with power applied?
  15. Nov 28, 2016 at 6:03 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    I didnt check the new one i put in.
    I'll check the old one tonight.
  16. May 1, 2019 at 3:43 AM
    Alwaysdaily
    Alwaysdaily Active Member
    Ty
    97 Tacoma 2.7l DLX
    Did you ever figure out the problem?
  17. May 1, 2019 at 5:21 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    No
    I sold the truck. at 200K miles supercharged I was done messing with it. The trans was going out as well as the Torque converter.
    I bought a Tundra More room more power. Best truck I've ever owned ...
  18. May 1, 2019 at 8:30 AM
    Alwaysdaily
    Ty
    97 Tacoma 2.7l DLX
    Okay, well thanks for responding.
    Looks nice
  19. Apr 18, 2022 at 8:34 AM
    Brie
    Brie Well-Known Member
    Brieanna
    CA
    2001 Tacoma TRD, Prerunner
    Did YOU ever figure this out?
  20. Apr 18, 2022 at 8:40 AM
    Brie
    Brieanna
    CA
    This is a major clue because this also happened in my case. I barely touched the button and immediately turned it off but shortly afterwards the damn CEL came on.
