P0606 code help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by benjamin1031, Mar 28, 2019.
  1. Mar 28, 2019 at 1:47 PM
    benjamin1031
    benjamin1031 [OP] Active Member
    Ben
    2005 Tacoma DCSB TRD OR SR5
    2" spacer lift, ARB winch bumper, Dick Cepek 16x8 wheels with 285 75 R16 Cooper Tires
    Ok, I've looked through everything I could find on TW and (in the words of Bono) still haven't found what I'm looking for.
    I replaced both O2 sensors on my 2005 DCSB TRD Off Road (with a 4.0). After that and new spark plugs I cleared the P0430 code that it had before with the bad sensors.
    Now, after the engine warms up it throws a P0606 code. My research has told me that it's probably the new O2 sensors but I haven't seen any "fix" for this other than new O2 sensors. I'm trying to find a way to fix this issue that doesn't involve me spending any more money.
    If I have to spend more money the check engine light will just have to stay on with it's P0606 code. Is there any hope to fix this without dropping more coin?? TIA
  2. Mar 28, 2019 at 3:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Whats the code description? "pcm processor fault"?
  3. Mar 28, 2019 at 5:57 PM
    benjamin1031
    Ben
    Correct, that’s the only fault code.
  4. Mar 28, 2019 at 8:24 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Sounds like a bad electrical connection somewhere. I'd probably start by just going over the work you have already done and make sure all of the connections you touched are clean and making good contact. Have you done any other electrical mods, like LED lights or anything? Are all of your lights working properly?
  5. Mar 28, 2019 at 9:12 PM
    benjamin1031
    Ben
    I haven’t done any electrical mods. In the morning I’ll hit the connectors to the o2 sensors with contact cleaner and see if that helps. I just really hate check engine lights...
  6. Mar 28, 2019 at 9:21 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I feel you, I'm fighting with a totally random P0430 that pops up out of no where every so often with no ryhm or reason.
  7. Mar 28, 2019 at 9:58 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Thats not a good sign for the pcm, probably needs a new one.
    Diagnosing a pcm failure when the vehicle still runs can be a little tricky. All you can really do is check all the power inputs and grounds. if they are good then you have to take the code description at face value, in this case its trying to tell you that something internal is fried
  8. Mar 29, 2019 at 12:09 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I don't think this will be easy to trace, but I Honestly don't think the pcm failed.
    I don't think I ever heard of this code being thrown specifically on a Tacoma for a filament on a tail light, but have heard of other Toyota's with dual filament tail lights getting P0606 when one of the filaments in the dual filament bulb started getting weak.
    If you decide it's the pcm, which I doubt, at least maybe consider spending the $5 for some new bulbs before buying a new pcm.
    Good luck bro, keep us posted
  9. Mar 29, 2019 at 6:32 AM
    benjamin1031
    Ben
    That code was easy... new o2 sensors...
    Did I mention it just got a new frame?? I’ll be poking around it today with a can of contact cleaner checking lights and o2 connectors and maybe inadequate grounds on the new frame... stay tuned... and thanks for the insight guys!!
    lynyrd3 likes this.
  10. Mar 29, 2019 at 6:41 PM
    benjamin1031
    Ben
    Update...
    I cleared the code cleaned the o2 connectors and polished the ground to the chassis from the neg terminal. Went for a test ride and no code this far...
    Hope springs eternal!
    PzTank and jboudreaux1965 like this.
  11. Mar 29, 2019 at 7:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What kind of 02 sensor did you use?
    Did the connector look ok on the sensor? Ive seen people file down the plastic ridges to try to get the connector to fit something it shouldn't.
  12. Mar 30, 2019 at 6:27 AM
    benjamin1031
    Ben
    b_r_o likes this.
  13. Mar 30, 2019 at 9:01 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Personally, you should've stuck with Denso O2 sensors which are OEM. This may be throwing your codes.
  14. Mar 30, 2019 at 9:32 AM
    benjamin1031
    Ben
    Would have if I could have afforded it. Unfortunately I had to go with the best price instead of the best reputation.
  15. Apr 15, 2019 at 6:58 AM
    benjamin1031
    Ben
    Code came back. Lasted for about 10-15miles before code came back... truck runs great, I just really hate check engine lights... When I can I guess I’ll order the fancier denso sensors...
  16. Apr 15, 2019 at 7:06 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Partstrain.com sells the Densos. Give them a call, try to get credit for the ones you already bought.
  17. Apr 18, 2019 at 3:33 PM
    benjamin1031
    Ben
    It wouldn’t matter if they did. I knew the risk when I ordered. Everything is functioning fine I’m just going to deal with the check engine light until I have the fundage to replace the cheap O2 sensors...
    I really appreciate everyone’s help though!!
  18. Jan 13, 2020 at 12:31 PM
    Boostntsi
    Boostntsi Well-Known Member
    Las Vegas, NV
    2013 Tacoma Double cab 4x4
    Icon suspension all around and some other stuff
    Old thread I know, sorry. Any updates OP as my Taco has the same code
    P0606:annoyed:
