P0441 and P0455 in 2005 v6. Help plz
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zth25, Jul 24, 2015.
  1. Jul 24, 2015 at 7:03 PM
    zth25
    zth25 [OP] Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    Hey guys. So I just got an 05 tacoma w/ 121k on it about 2 weeks ago. Put about 500 miles on it and the CEL came on. I scanned it and it came up with p0441 and p0455. I erased the code and about 300 miles later (today) it came back on. Both times it came on when starting my truck at first in the morning. Today when it came on I looked at the gas cap and then noticed the plastic notched ring that holds the cap was not on correctly so I put it on correctly and then went to the gas station and filled the tank. Then after I filled the tank I drove home and the truck sat for about 20 minutes and when I went to start it it just kept cranking, but the second time I tried to start it fired right up. I didn't erase the code and it didn't go off after fixing the plastic ring thing.
    I've done a little research on the code but found nothing conclusive. If anyone could point me in the right direction it would be appriciated.
  2. Jul 26, 2015 at 9:38 PM
    zth25
    Zach
    Bumpps
  3. Jul 26, 2015 at 9:49 PM
    kendragon
    kendragon Member
    Ken
    2003 White Tacoma Prerunner 4cyl 2wd
    I had the same code. Changed the carbon canister and gas cap which didn't fix it. Turned out to be the vapor purge valve.
  4. Jul 26, 2015 at 11:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The P0441 leads down a complicated troubleshooting area, but with the P0455 Code it leads to a Gross Leakage and the likely trouble areas are reduced to the below listed from the service manual:
    P0455 leads to these Areas:
    EVAP gross leak:
    • Fuel cap (loose)
    • Leakage from EVAP line (Canister - Fuel tank)
    • Leakage from EVAP line (Purge VSV - Canister)
    • Canister pump module
    • Leakage from fuel tank
    • Leakage from canister
    Get a good garage to do a smoke test of the evap system. This should pinpoint the leak for you.
    The P0441 leads to these:
    Purge VSV (Vacuum Switching Valve) stuck open.
    • Purge VSV
    • Connector/wire harness (Purge VSV - ECM)
    • ECM
    • Leakage from EVAP system
    Purge VSV (Vacuum Switching Valve) stuck closed.
    • Purge VSV
    • ECM
    Purge flow.
    • Purge VSV
    • Leakage from EVAP line (Purge VSV - Intake manifold)
    • ECM
    foampile and zth25[OP] like this.
  5. Aug 28, 2015 at 10:35 AM
    wrfforgotten
    wrfforgotten New Member
    If you are having problems starting your truck after fueling up, your problem is most likely that the purge valve is stuck open. If it sticks open it will suck fuel through the EVAP system with a full tank. Happened to me.
  6. May 7, 2016 at 3:47 PM
    foampile
    foampile Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    Where exactly is the "purge valve"? Is it the solenoid controlled rod in the back of the intake manifold?
