P0430 Troubleshooting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snpower, Jan 8, 2018.
  1. Jan 8, 2018 at 12:44 PM
    snpower
    snpower [OP] Well-Known Member
    Central Virginia
    06 Tacoma SR5 Double Cab
    I am working my way through this (hopefully). I did a few basic things... ensured that there was no corrosion on the battery terminals, installed a new air filter, electronics cleaner on the MAF...
    I reset the light once and it stayed off for two weeks. It is back on, and today I pulled the rear O2 sensor. I want to make sure I am checking it correctly per the maintenance manual. If I am doing it correctly [see image with terminals marked, below] I am getting 15.8 ohms between terminal 1 and 2. I am reading 0 ohms between terminal 1 and 4, leading me to believe it is bad.
    Just want to confirm I am reading the MM content correctly (i.e. I checked the right terminals). Also, should I pull the upstream sensor and check as well, or replace this one first and see if the CEL light goes out?
    The more I read, the more it sounds like a bad CAT problem though...
  2. Jan 8, 2018 at 2:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    IAW the manual as you stated the sensor is defective pin 1 to pin 4 should not read zero ohms it should read 10,000 ohms or higher on pin 1 to pin 4.
    wilcam47 likes this.
  3. Jan 8, 2018 at 3:37 PM
    snpower
    Central Virginia
    Pin 1 and 4 on the new sensor read 0 just like the old one ?? Pin 1 to 2 reads 16.
  4. Jan 8, 2018 at 3:44 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    usually its the O2 sensor, not the cat. Im not saying cats dont go bad, just typically its not the first thing to go bad.
  5. Jan 8, 2018 at 11:47 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The manual must be wrong.
  6. Feb 18, 2018 at 3:04 PM
    jakemellow
    jakemellow Member
    jake
    Morin heights, Quebec
    2016 TRD sport crewcab longbed
    Level lift, 30", black softopper
    2006 trd sport, cc v6 auto. 250000km
    Having the same trouble, but trying to get a
    little more info before pulling out the old credit card.
    Here are screen shots from my obd2 scanner. Does any of this info help diagnose a bad 02 sensor?
    It's a nice tool, just haven't figured out everything about it yet.
  7. Feb 18, 2018 at 3:16 PM
    Bishop84
    Bishop84 Well-Known Member
    Rarely is a P0430 a 02 problem, the sensors are working and thus verifying the cat has failed.
    The downstream O2 starts to swing fast up and down with the upstream and triggers the code. If the sensors were bad they would be slow or not reading at all, this would be the opposite of a P0420/430.
    Measuring resistance in the automotive field is a greasy beast, it can mislead and cause a lot of wasted money on sensors of all variety's.
    You need a bank 2 cat.
    Bebop and jakemellow like this.
  8. Feb 18, 2018 at 3:55 PM
    jakemellow
    jakemellow Member
    jake
    As they say around these parts. Merci beaucoup.
  9. Feb 26, 2018 at 9:24 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Any progress? I just got this code
  10. Feb 26, 2018 at 9:34 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Replace the cat. Don't buy a cheap one either.
  11. Feb 26, 2018 at 3:16 PM
    kidthatsirish
    I suppose I should correct and say I'm getting the P0420....but mine is a 4 cylinder. Regardless its the same signal to the computer. I'm going to have to try and go with the Exhaust leak path first....followed by a bench test of the O2 sensor, and I'm thinking of investing in a thermometer gun...but I'm not sure it will be necessary.
    Mine is a 2006...so a 12 year old truck with a 152k miles on it...well, I suppose its about time for some exhaust work.
