P0420 code related to cold air intake
Discussion in '1st Gen. Tacomas (1995-2004)' started by Texas-Gorilla, Oct 31, 2023.
  1. Oct 31, 2023 at 7:56 PM
    Texas-Gorilla
    Texas-Gorilla [OP] Well-Known Member
    Thomas
    2016 Tacoma TRD OR
    A couple of weeks ago I decided to install a cold air intake on my 2001 prerunner and today the dreaded P0420 code popped up.
    I'm thinking it's related to the MAF sensor and the intake, so I plan to take that off and reinstall the stock airbox as the truck was running great with no issues before the air take install.
    My truck does have 185k miles on it so I'm really hoping it's just the MAF and related cold air intake and not the catalytic converters.
  2. Oct 31, 2023 at 8:11 PM
    SmoothTRD
    SmoothTRD Well-Known Member
    They are a complete waste of money
  3. Oct 31, 2023 at 8:55 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Installing the CAI itself did not cause the code. The ECU- MAF/Cats/o2 sensors probably all just aged together, and you upset that balance. I doubt reinstalling the stock intake would fix it. At 185k the cats are probably close anyway.. You also just need to do a complete systems check- particularly vacuum and exhaust leaks which could effect the sensor readings.
  4. Oct 31, 2023 at 8:57 PM
    Bishop84
    Bishop84 Well-Known Member
    P0420 is not related to intake, it simply sees the downstream sensor swinging with the upstream. Cat is worn. Check for exhaust leaks first.
    Texas-Gorilla[OP] likes this.
  5. Nov 1, 2023 at 7:20 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I just fixed my P0420 code by sealing up a small exhaust leak between the second cat and the rear O2 sensor. Definitely check for leaks before replacing cats.
  6. Nov 1, 2023 at 8:59 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your PO420 code just is not detecting enough change between the front and rear sensors.
    Exhaust leaks can cause this problem.
    Just bad timing on this happening.
    Good Luck
  7. Nov 1, 2023 at 4:09 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Put the airbox back on. In the long run you will be happy
    Texas-Gorilla[OP] and SmoothTRD like this.
  8. Nov 16, 2023 at 5:08 PM
    Texas-Gorilla
    Thomas
    2016 Tacoma TRD OR
    Check engine light came back on today after I reset it on 10/31. Code this time is P0450 Evaporative Emission Control System Pressure Sensor Malfunction.
    I reset the code and tightened the gas cap. It's probably the original cap and worthwhile to replace it. Anything else I should look into at this time?
  9. Nov 16, 2023 at 5:49 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Gas cap is no1 thing to replace or check...
    IF that's not it.....most likely a leak somewhere in/around the evap system...
    There's two valves that are fairly easy to check....vsv valves...
    the one closest to the firewall should be clicking on/off in rapid secession all the time the engine is running...
    the other one on the side of the canister is the pressure switch that controls the canister pressure...
    SOLVED P0446 diagnose repair charcoal canister Toyota Tacoma √ Fix it Angel - YouTube
    If its not any of that ....you may need to get/build a smoke machine to smoke the problem out...
    there a ton of trouble shooting vids out there.......p0420/p0450 is very common on older tacos....
  10. Nov 16, 2023 at 6:14 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    All that extra HP must've blew a seal somewhere
    SmoothTRD likes this.
  11. Nov 16, 2023 at 7:23 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Ha Ha Ha Ha^^^^
