P0420 and P0446 code help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Akruspe, Nov 20, 2020.
  1. Nov 20, 2020 at 12:00 PM
    Akruspe
    Akruspe [OP] Well-Known Member
    02 pre runner sr5 v6
    So i have an 02 3.4 that has both p0446 and p0420 codes i need advice where to start with diagnosing the issue and it also im having issues with idle. When i start it first thing in the morning it idles at about 800-1000 where it should and when it warms up it idles at about 12-1500rpm.
  2. Nov 20, 2020 at 12:17 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Try a new (OEM) gas cap if you haven't already, those two codes together sometimes point to a faulty gas cap. Could be other things too but thats a cheap and easy place to start
  3. Nov 20, 2020 at 12:21 PM
    Akruspe
    Ok i will try that but that wouldnt cause my idle issue im having would it?
  4. Nov 30, 2020 at 10:01 AM
    brandonstocool
    brandonstocool Well-Known Member
    Brandon
    California
    2001 Silver Tacoma Double Cab TRD
    Camburg LT Kit King 2.5 8" Coilover Mcneil Fiberglass 6"&Hood Billstein 5100 OME Leaf Spring Fiberwerx 4.5" Bedside
    I had just gotten these two errors together this past weekend. New gas cap did not help me.
  5. Nov 30, 2020 at 10:06 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    The 0420 is likely a result of the 0446 which is pointing to your evap cannister vent/purge valves. A new gas cap may fix it, but in my experience, it's almost never that easy (But hey... people do win the lottery...). Start by using some tape to seal your gas cap tight to the filler neck. Clear the codes and if they stay cleared, you got lucky and a new gas cap should do it. If it doesn't then track down a wiring diagram and check your vent & purge valves. Likely one of them has failed.
  6. Dec 1, 2020 at 10:45 AM
    Akruspe
    Ok yes i will try that then. The new gas cap did not solve my issue as i expected that it wouldnt. I was thinking i have a vacuum leak somewhere because my idle is also the opposite of what it should be although i dont know that would cause those codes or not.
  7. Dec 1, 2020 at 6:17 PM
    Thomas670
    Thomas670 Well-Known Member
    2002 Taco Regular 5 speed
    a bad or faulty oxygen sensor typically the bank 1 sensor can cause a p0420 code and also an idling problem
  8. Dec 1, 2020 at 7:02 PM
    cast718
    cast718 Well-Known Member
    New Jersey
    2004 4WD Standard Cab 4 Banger
    I've been meaning to do a write up on this since i successfully solved both of these codes fairly painlessly and mostly on my own. The short version, is that my 0420 code was a hole in my exhaust intermediate pipe right by the muffler. had a shop weld a new intermediate pipe in, along with a new 02 sensor. Problem solved. For the 0446, I slowly and methodically took out each purge valve (2 or 3 under the hood and 1 on the charcoal canister) and checked them for continuity with a multimeter and checked them, I dunno, to see if they were dead, with a pair of leads and a 9V battery. First off, with the battery test, if the valve is dead then you just buy a new one. If its NOT dead, then you gotta follow the FSM and blow into them and see if they are operating properly. This is a super simple test and identified that the valve on my charcoal canister was dead. I bought the new one at my Toyota dealer (these arent things you go aftermarket IMO) for like $70. Problem solved. That valve on the canister is pretty easy to get to but I wrecked the bracket it was on so i just zip tied the new one back on to a good piece of metal up there. All good now.
    This was $74 on the McGeorge site, but my dealer matches the online prices when he can. FYI, from what I've learned, the charcoal canister SHOULD BE a lifetime part. They can go bad IF someone fucks up like by overfilling the gas tank multiple times. But with normal conditions, it should last, so i was looking to avoid replacing the whole canister. I also incorrectly read on here, maybe it was old threads, that you couldnt just buy this valve, only the entire canister assembly. That is false. Stay tuned for the write up, but would be happy to answer questions in the meantime.
    tirediron likes this.
  9. Dec 7, 2020 at 5:15 PM
    jrdriver8
    jrdriver8 Active Member
    Ma
    2002 Tacoma PreRunner
    Stock
    My 02 V6 Prerunner with 180k just tossed a P0420 three weeks ago. I used my shop vac on exhaust and taped it to the rear exhaust pipe. Blowing air into the pipes I then sprayed soapy water along the joints at the rear 02 where I found a hole at the attaching flange and also the joints with the flange. I wound up with a new intermediate pipe, muffler and tail. So far this seems to have solved the code.
  10. Dec 7, 2020 at 7:37 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    Is that valve on the charcoal cannister under the bed of the truck? I have the 446 code. Tested the one under the hood which seems to be working.
    what's weird is the code takes four to six months to come up again once I reset it.
  11. Dec 7, 2020 at 8:52 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Sounds like the Purge Selnoid or Fuel tank pressure sensor may be working intermittently.
  12. Dec 7, 2020 at 9:21 PM
    SellyKlater
    Ponce Inlet, Fl
    I applied 12v to the purge valve under the hood and it clicked every time... But your saying it might not work everytime in normal use? There seems to be no other issues besides the check engine... Idle is smooth, acceleration feels normal, starts normal.
  13. Dec 7, 2020 at 9:36 PM
    Glamisman
    Glamisman Well-Known Member
    the valve solenoid can click but if the seal does not seal and it leaks vacuum a code will be thrown. we are talking a very small amount of vacuum that the tank pressure sensor senses.
    cast718 and Black DOG Lila like this.
  14. Dec 8, 2020 at 5:30 AM
    Black DOG Lila
    Virginia
    The click indicates the Selnoid is working. Circuit continuity and flow must also be tested.
    SellyKlater[QUOTED] likes this.
  15. Dec 8, 2020 at 2:03 PM
    SellyKlater
    Ponce Inlet, Fl
    Thank you. I'll have to do some more Testing.
  16. Dec 21, 2020 at 1:52 PM
    cast718
    New Jersey
    yes, thats the valve, under the bed.
    like others above said, connecting 12 or 9v to the valve to test is just step 1. if its not dead, you then need to blow through it to check and see if its operating effectively. mine clicked, but the seal was blown.
  17. Dec 25, 2020 at 9:40 AM
    Akruspe
    Update. So i have ran a cycle of cata clean highly recommended and it has now cleared the 0446 evap code so now i only have 0420. Could it be as simple as an 02 sensor. I would really rather not waste money on a stupid cat. But i need my CEL off to get inspection. Also i have a 0505 which is IACV. Where should i start with solving that issue.
  18. Dec 25, 2020 at 9:47 AM
    Black DOG Lila
    Virginia
    Cataclean help clean the catalytic converter which is the P0420 Catalytic converter efficiency below predetermined performance.
    P0446 is EVAP code Inability to regulate flow of fuel vapor from tank.
    Are you saying Cataclean cleared an EVAP code P0446?
  19. Dec 25, 2020 at 9:51 AM
    Black DOG Lila
    Virginia
    B1S1 is Air/fuel sensor
    B1S2 O2 sensor monitors Cat= P0420
  20. Dec 28, 2020 at 6:29 AM
    Akruspe
    Yes which made no sense to me. So i replaced a coil pack i was assuming was throwing the misfire code and those are now clear as well. So now the only codes i have left are p0420 still even after the cataclean and the p0505
