p0402 Exhaust Gas Recirculation Flow (EGR) Excessive Detect - 99 Prerunner 2.7L HELP!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Waterfowl HD, Mar 18, 2014.
  1. Mar 18, 2014 at 5:29 PM
    Waterfowl HD
    Waterfowl HD [OP] New Member
    Johnathan
    North Carolina
    1999 Tacoma Prerunner 2.7L 4cl Single Cab
    Tinted Taillights Tinted Corner Lights LED Conversion 8k HIDS Thrush Glasspack Muffler Magnaflow High Flow Cat 31' BFG All Terrains KOs
    I have a 99 toyota Tacoma prerunner 2.7L with the code p0402 excessive Egr flow and I've had it for about a year now and I've replaced everything that has to deal with the Egr ; Egr valve,Egr valve vacuum modulater, Egr valve gaskets, VSV , Egr temp sensor, catalytic converter, PVC , PVC gormet, seafoam in gas, seafoam in brake booster and all vacuum ports please help can not get inspected until this code is gone...Any questions just ask
  2. Mar 20, 2014 at 7:15 PM
    Waterfowl HD
    Johnathan
    North Carolina
  3. Mar 20, 2014 at 7:17 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    U may have better luck with this in the 1st gen. If you'd like, I can move it there.
  4. Mar 21, 2014 at 6:10 AM
    Waterfowl HD
    Johnathan
    North Carolina
    Yes thats fine thank you
  5. Mar 21, 2014 at 6:26 AM
    micropiper
    micropiper Admiral of the JOLLY ROGER navy
    damion
    phoenix az
    Four cylinders of pure awesome
    k&n air filter in a modded intake, sliders, new horn, plenty o pinstripes, custom onboard air,cobra cb with custom skidplate,
    Had this exact same issue with mine. same year and engine. There is a vacuum switch that goes bad. Where the intake curves over the valve cover on the driver side. its inside the little "cave" it leaves. Had to get a switch from the stealership but it fixed the issue right away. It tells the egr to activate when its not needed and that's why it throws the code. If you need I can get a couple pics and post them so you can see where it is. Was a 10 minute fix once I had the switch.
  6. Mar 21, 2014 at 4:07 PM
    micropiper
    damion
    phoenix az
    Make sure to tell them you need the egr vacuum solenoid switch. There are a couple of them under the hood. They operate at different pressures and do different things. Hope this solves your problem!!
  7. Mar 21, 2014 at 7:07 PM
    T-Rex266
    Elon
    completed
  8. Mar 21, 2014 at 10:39 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Double-check the vacuum line connections. Maybe a couple got switched around, or one is split open.
