P0351 CODE
Discussion in '1st Gen. Tacomas (1995-2004)' started by BBJ285, Mar 31, 2012.
  1. Mar 31, 2012 at 10:34 AM
    BBJ285
    BBJ285 [OP] Well-Known Member
    Scurry, TX
    03 Pre-Runner
    SnugTop cap, "SuperSpring" helperspring, flowmaster muff,K&N CAI, CB, small amp & 2 6x9s in the bed on a toggles switch for nights at the drive-in...
    I was driving home and my truck just died. No running rough of anything...just died. So we pushed it home, tried starting and nothing. I could hear a high pitched humming coming from the throtle body. So I thought mabye that was the problem. I happened to have one to try and swap to see....nope, same thing. So I brought home a code reader and got the P0351 code (Coil A malffunction). I put a coil in it and still nothing, even tried and igniter. Things are pointing towards a faulty ECU. None of the wires appear to be chewed(by mice) or broken. i guess we will see if the ECU fixes the problem.
  2. Mar 31, 2012 at 10:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Use an Ohm meter and test the wires goin gto the coil
  3. Mar 31, 2012 at 11:02 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you reset the code? What coil did you replace?
  4. Apr 5, 2012 at 11:36 AM
    BBJ285
    Scurry, TX
    03 Pre-Runner
    Turned out to be a broken wire on the harness that goes to the igniter.
  5. Jan 18, 2015 at 8:37 PM
    Jrakk
    Jrakk Member
    New Brunswick, Canada
    04 Quad-Cab Tacoma 4WD Supercharged
    Supercharged, TRD 7th injector, 2" body lift, 3" suspension, 33's
    My truck is having the same issue and (without going outside to look under the hood) I believe it was a green wire coming out of the igniter plug that has been spliced/repaired. Could you tell me how you found which wire was broken, and where it was broken? I may be having the same problem all over again.. Im also getting a P0340 code, but I will address these two codes one at a time...
