P0345 Any suggestions?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRmach1, Jul 19, 2021.
  1. Jul 19, 2021 at 11:52 AM
    TRmach1
    TRmach1 [OP] Member
    Ivan
    2017 Tacoma
    P0345: Camshaft Position Sensor A / Circuit bank 2
    I am chasing this issue with the truck, she has around 80k+ miles, she has never had a problem until now. The truck will randomly throw a code, the trac off light and will begin to buckle and jerk, it gets to the point that it goes into limp mode and goes at a snails pace. Sometimes it can drive ok with no issues, I changed one cam sensor and was ok for a week then it acted up again, I checked the crankshaft sensor and replaced it and still nothing.
    I looked around for any wires that might be cut and nothing, I probably need to look under the manifold to see if there is anything that a rodent might have gotten to. Oil level is good. I took it to toyota and of course the truck did not act up so they did not do anything to it and based on the codes in the history they still did not know what to do.
    I'm running out of Ideas and need the truck up and running again, it is unsafe to drive, luckily we have another vehicle, so for now she's just been parked.
    Any help would be greatly appreciated!!
  2. Jul 19, 2021 at 12:00 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Almost certainly either a faulty cam sensor or faulty wiring. You need a schematic and a DVOM or labscope to troubleshoot this. It's not difficult, just need to know what the specs are for the senor, and what inputs & grounds it should be getting. Start at the sensor, if it checks out, but you're missing power or ground, then just keep working upstream until you find out where they went.
    TRmach1[OP] likes this.
  3. Jul 19, 2021 at 12:02 PM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    P034531
    A missing VVT sensor (for intake camshaft of bank 2) signal despite the crankshaft position sensor inputs being normal at an engine speed of 600 rpm or higher (1 trip detection logic).
    • Open or short in VVT sensor (for intake camshaft of bank 2) circuit
    • VVT sensor (for intake camshaft of bank 2)
    • Intake camshaft
    • Valve timing
    • ECM
    This is what TIS has to say about the code. Here is the wiring diagram sensor signal voltage is 5V
    TRmach1[OP] and tirediron like this.
  4. Jul 19, 2021 at 12:15 PM
    tirediron
    Doesn't get much simpler than that.
  5. Jul 19, 2021 at 12:23 PM
    TRmach1
    TRmach1 [OP] Member
    Ivan
    2017 Tacoma
    Thank you guys, I'll chase it down!
  6. Jul 19, 2021 at 12:26 PM
    rolled93slc
    Jerry
    Lynchburg VA
    OP is there any numbers after the P0345? P034511, P034515, P034531? That would narrow it down further.
  7. Jul 19, 2021 at 12:27 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    What's the maintenance history? If it is nothing obvious, you will need to get a tech who can determine the health of the cam phaser and also rule out chain stretch. A skilled tech can make this diagnosis.
  8. Jul 19, 2021 at 12:32 PM
    rolled93slc
    Jerry
    Lynchburg VA
    Here's a little more info for you to go
    TESTER CONNECTION SWITCH CONDITION SPECIFIED CONDITION
    V17-3 (VC) - Body ground Ignition switch ON 4.5 to 5.5 V
    V15-3 (VC) - Body ground Ignition switch ON 4.5 to 5.5 V
    TESTER CONNECTION CONDITION SPECIFIED CONDITION
    V17-1 (VVR+) - E9-31 (VV1+) Always Below 1 Ω
    V17-2 (VVR-) - E9-21 (VV1-) Always Below 1 Ω
    V15-1 (VVL+) - E9-19 (VV2+) Always Below 1 Ω
    V15-2 (VVL-) - E9-28 (VV2-) Always Below 1 Ω
    V17-1 (VVR+) or E9-31 (VV1+) - Body ground and other terminals Always 10 kΩ or higher
    V17-2 (VVR-) or E9-21 (VV1-) - Body ground and other terminals Always
    10 kΩ or higher
    V15-1 (VVL+) or E9-19 (VV2+) - Body ground and other terminals Always
    10 kΩ or higher
    V15-2 (VVL-) or E9-28 (VV2-) - Body ground and other terminals Always
    10 kΩ or higher
    G8R_Taco, TRmach1[OP] and tirediron like this.
  9. Jul 22, 2021 at 10:08 AM
    TRmach1
    TRmach1 [OP] Member
    Ivan
    2017 Tacoma
    Unfortunately there isn't. I have two separate code readers and mine only show what I posted. When I took it to Toyota they were pretty much useless, they charged to check it out and nothing came of it.
  10. Jul 22, 2021 at 10:13 AM
    TRmach1
    TRmach1 [OP] Member
    Ivan
    2017 Tacoma
    Just regular maintenance, she has never had an issue up until now.
  11. Jul 22, 2021 at 10:14 AM
    TRmach1
    TRmach1 [OP] Member
    Ivan
    2017 Tacoma
    Thanks, I have been out of state so I have not been able to do anything to her. I will get on it once I get back.
  12. Jul 22, 2021 at 10:15 AM
    Bishop84
    Bishop84 Well-Known Member
    I have seen batteries cause crank sensor codes on 2GR FKS models. Even if it starts fine a failing battery causes issues on these, maybe have it tested as a precaution.
