P0303 code HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98_3RZ_NIC, Jan 19, 2023.
  1. Jan 19, 2023 at 7:10 AM
    98_3RZ_NIC
    98_3RZ_NIC [OP] Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    Had a local Toyota dealership diagnose my p0303 code and said it’s “probably” the injectors so I had them replace them with oem and I still get the code. Could it be valves? Rings? What could it be? I’m gonna take it back there and tell them diagnose it right this time.
    HondaGM likes this.
  2. Jan 19, 2023 at 7:13 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Which engine?
    HondaGM likes this.
  3. Jan 19, 2023 at 7:15 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    They diagnosed it...I would take it back
    Superdave1.0 and 98_3RZ_NIC[OP] like this.
  4. Jan 19, 2023 at 7:15 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    P0303 is a cylinder three misfire detected, so suggesting you should change your injectors is ridiculous. Cylinder 3 injector? Maybe... clearly they didn't do enough trouble-shooting. It could be a lot of things, but I would my first guess would be plug/wire/coil. How many miles since secondary ignition components were changed?
  5. Jan 19, 2023 at 7:17 AM
    98_3RZ_NIC
    2.7
  6. Jan 19, 2023 at 7:21 AM
    0xDEADBEEF
    Did they check valve clearances?
    tirediron likes this.
  7. Jan 19, 2023 at 7:21 AM
    98_3RZ_NIC
    Plugs and wires were replaced about 6 months ago. The dual coils I haven’t replaced yet. Maybe I should switch wires on the coil to see if I get a different code. If I get a different code then it’s not the coil right?
    Superdave1.0 likes this.
  8. Jan 19, 2023 at 7:51 AM
    98_3RZ_NIC
    Can I switch wires on my coil to see if I get the same code or a different code? Or will that mess with timing?
  9. Jan 19, 2023 at 8:04 AM
    tirediron
    Is this a waste-spark system? I thought it was coil-on-plug....
  10. Jan 19, 2023 at 8:08 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    You paid to get this fixed?
  11. Jan 19, 2023 at 8:31 AM
    98_3RZ_NIC
    it is a coil on plug
  12. Jan 19, 2023 at 8:32 AM
    98_3RZ_NIC
    yep. Not too happy either but at least I have new injectors.
  13. Jan 19, 2023 at 8:34 AM
    0xDEADBEEF
    Is there one coil per two cylinders? I thought coil per plug wasn’t till 2000
  14. Jan 19, 2023 at 8:41 AM
    98_3RZ_NIC
    yes. One coil per 2 cylinders
  15. Jan 19, 2023 at 8:48 AM
    0xDEADBEEF
    Ok I think that rules out the coils as the issues. Since it’s a wasted spark, if the coil were the issue you would expect a problem on both cylinders it fires.
    but you could swap coils just to be sure
  16. Jan 19, 2023 at 8:54 AM
    tirediron
    I would start by checking the plug, followed by the wire, and as suggested, swapping coils. Valve clearance could also be the culprit, but I would expect a multiple cylinder misfire were that the case, as valves generally wear more-or-less evenly. While I don't want to cause a panic, definitely have a good look at the plug and compare it to number 1; coolant leaks from failing head gaskets can also cause single-cylinder misfires. Do you have any idea of how much it's misfiring?
    0xDEADBEEF likes this.
  17. Jan 19, 2023 at 8:59 AM
    slodoug
    slodoug Well-Known Member
    look for cloudy oil in coolant first. gasket leak.
    98_3RZ_NIC[OP] likes this.
  18. Jan 19, 2023 at 9:05 AM
    98_3RZ_NIC
    I get the code maybe 2-3 times a day and a check engine light maybe 3 times a week. I have an ultra gauge plugged in that I clear the code with.
  19. Jan 19, 2023 at 9:06 AM
    tirediron
    Oil in the coolant, and coolant in the oil are both definite indicators, but in my experience, you often don't see that until it's a little more advanced. If you pull out #3 plug and when compared to #1 it looks clean/white-ish that's a good indication it's being 'steam-cleaned' by a very small coolant leak. If you have a boroscope you can slide that into the cylinder and have a look for drips while the plug is out.
  20. Jan 19, 2023 at 9:12 AM
    98_3RZ_NIC
