p0172 too rich bank 1 5vz-fe
Discussion in '1st Gen. Tacomas (1995-2004)' started by Empty_Lord, Feb 8, 2019.
  1. Feb 8, 2019 at 8:28 AM
    Empty_Lord
    Empty_Lord [OP] Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Got a 99 4runner ive been slowly fixin for a buddy. Had a leaky injector so i replaced all 6 with new denso injectors. Well get done. drive it for a few days and p0172 pops up.long term Fuel trims are -30% roughly. I have replaced the MAF and A/F to no improvement (use known working parts)
    Just looking for ideas.. about to swap the injectors with my trucks old ones next friday and see if the code stays away...
  2. Feb 8, 2019 at 3:15 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    The oil is not fuel contaminated is it?
  3. Feb 8, 2019 at 5:06 PM
    Empty_Lord
    Dan
    No
  4. Feb 9, 2019 at 5:37 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Evap purge valve leaking or FP regulator. Defective injector.
  5. Feb 9, 2019 at 7:29 AM
    Empty_Lord
    Dan
    I’m leaning towards the injector honestly. Well see Friday when I swap em what happens
  6. Feb 9, 2019 at 8:40 AM
    Glamisman
    Glamisman Well-Known Member
    check the air intake temp senssor as well as the engine coolant temp sensor readings... does your OBDII scanner have live data streaming? The AF sensor can show a false lean and that can force the fuel trims to try to compensate also. Disconnect the AF sensor and see if it normalizes.
  7. Feb 9, 2019 at 10:01 AM
    Empty_Lord
    Dan
    Everything on my scanner looks normal honestly. I have a snap on modis. Graphiing it everything looks good. A/f is right where it’s suppose to be. Pretty sure it’s fuel system related.
  8. Feb 9, 2019 at 10:03 AM
    Bishop84
    Bishop84 Well-Known Member
    Pinch off the purge hose from the canister and monitor fuel trim.
    May need to check fuel pressure but its an asshole with those trucks, we usually cut scrap fuel lines to make a pressure tester hose for them.
  9. Feb 9, 2019 at 10:04 AM
    Empty_Lord
    Dan
    Fuel pressure is my Next test.(I have the factory adapter) I’ll check pinching the hose too. Honestly never had issues like this with a 3.4. And I’ve done plenty of injectors and stuff on these
  10. Feb 9, 2019 at 10:05 AM
    Empty_Lord
    Dan
    Funny thing is it’s not burning through gas and the light comes on and goes out. Doesn’t feel sluggish or anything
  11. Feb 9, 2019 at 10:08 AM
    Bishop84
    We've recently seen regulator failures causing long cranks, but rich is usually MAF or leaking injectors.
    Also! I've seen shit Napa injectors leak from new.
  12. Feb 9, 2019 at 1:18 PM
    Empty_Lord
    Dan
    New Denso injectors. But they can still be bad
  13. Feb 9, 2019 at 6:20 PM
    Glamisman
    New, he he ... New = Never ever worked.
    mechanicjon likes this.
  14. Feb 9, 2019 at 8:06 PM
    Empty_Lord
    Dan
    Ain’t that the truth sometimes.
    I had a brand new Toyota torque converter. Put the car together and find out the damn stator pump was machines wrong and didn’t pump...
    I was not a happy person. And my field rep was dumbfounded. Lol
  15. Sep 21, 2019 at 10:52 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Any remedy for this. I replaced all 6 injectors with factory injectors and I.a.c valve. cleaned tb and maf still getting a high idle and p0172
  16. Sep 21, 2019 at 12:29 PM
    Empty_Lord
    Dan
    Resolved the issue with another set of injectors. From Toyota.
    desertrunner24 and CS_AR like this.
  17. Sep 21, 2019 at 12:46 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    When I bought new injectors last spring, I sent them to a place in FL for testing. It turned out that two were under performing that would have caused lean conditions.
    I got into the practice of sending injectors out for "only testing" for $7 each a few years ago. Once in a while, it can save a headache and rework.
  18. Sep 21, 2019 at 12:54 PM
    Empty_Lord
    Dan
    i pulled the ones i had in the engine out and compared the spray to my good ones from my tacoma engine... they were DUMPING fuel.
    CS_AR[QUOTED] likes this.
  19. Sep 21, 2019 at 1:05 PM
    CS_AR
    Wow.. Uncontrollable flooding.
  20. Sep 21, 2019 at 1:42 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    This must be what I'm experiencing. Had a #4 misfire. Replaced all 6 injectors now I'm chasing the p0172 code. Thanks for replying. :thumbsup:
