P0171 and traction control light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taniwha, Aug 20, 2020.
  1. Aug 20, 2020 at 8:04 AM
    Taniwha
    Taniwha [OP] Well-Known Member
    Dave
    Kamloops, B.C.
    2009 Taco 4cyl. 5 speed 4x4 Speedway Blue
    Looking for some wisdom please. My CEL and traction control light have been coming on together for a couple of days now. The code is P0171 and the trac light stays on solid. It already has a new fuel pump installed. Under a big load it will buck a bit til I back off the throttle. It's the trac light that has me wondering. Hopefully someone has experienced a similiar event? TIA Cheers, Dave
  2. Aug 20, 2020 at 8:12 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    For certain check engine lights the trac like will also come on. That code has a wide variety of things that could cause it. Did this start happening after the new fuel pump was installed?
    b_r_o likes this.
  3. Aug 20, 2020 at 8:28 AM
    Taniwha
    Dave
    Kamloops, B.C.
    Yes, after the new pump. I misdiagnosed the the original fuel pump as faulty when the chip key was intermittently not signalling the immobilizer to run the pump. Took the box off to replace, so pretty sure I didn't kink any hoses on the install. I seafoamed it in this time frame too. A whole can in a full tank of fuel. I'm going to test the fuel pressure tomorrow. Maybe the seafoam knocked something loose and is now in the fuel pressure regulator? It actually runs ok now, so I have some time to diagnose. I ASS U ME that the new pump is not part of the equation, but have had experiences where using new parts as troubleshooting tools has not worked out well ;-)
  4. Aug 20, 2020 at 1:18 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Here have you, I'd start with reading the voltage values on the A/F sensor, bank 1 is passenger side.
  5. Aug 20, 2020 at 1:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the problem started after the new fuel pump went in.. I'd be looking at fuel pressure and volume
  6. Aug 20, 2020 at 1:45 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    why just 1 bank then, would the pump affect both sides the same or maybe I’m misdiagnosing
  7. Aug 20, 2020 at 2:13 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Bank 2 may code eventually, maybe bank 1 was just the first side to recognize the problem.
    6 gearT444E[QUOTED] likes this.
  8. Aug 20, 2020 at 3:20 PM
    Taniwha
    Dave
    Kamloops, B.C.
    It's a 2.7 liter 4 cylinder. Does that make a difference? Cheers, Dave
    b_r_o likes this.
  9. Aug 20, 2020 at 4:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Nope, you still have a lean code :D
  10. Aug 20, 2020 at 7:54 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Haha, no, I meant the bank 1 and bank 2 thing!
  11. Aug 20, 2020 at 7:56 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    well now that you mention that, i'd say hook up a gauge to your fuel line and check the idle and pressure at WOT. Could be the pump or the resistor.
  12. Aug 20, 2020 at 7:56 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes, there's only one bank on a 4 cylinder, so it could be fuel, maf, vacuum leak and its harder to find.
  13. Aug 20, 2020 at 8:09 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    How long has it been since the MAF sensor was cleaned with the proper product -> CRC
  14. Aug 20, 2020 at 9:04 PM
    Taniwha
    Dave
    Kamloops, B.C.
    About 2 days!
  15. Aug 20, 2020 at 9:08 PM
    Lester Lugnut
    how did you clear the code?
  16. Aug 20, 2020 at 9:38 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Don't know if seafoam always plays well with o2 sensors. May need to check that and then do a routine tune up.
  17. Aug 21, 2020 at 2:04 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The 2.7 Liter 4 cylinder has no fuel pump resistor.
    You also want to check the fuel pressure with a tee fitting off the main fuel line. do not dead head as you will get an incorrect High Pressure. The regulator is on the fuel rail.
  18. Aug 21, 2020 at 8:23 AM
    Taniwha
    Dave
    Kamloops, B.C.
    OBD2 reader. Cleared it and was back again after a couple drives. Leaning towards fuel pressure, gonna test it today
  19. Aug 21, 2020 at 8:25 AM
    Taniwha
    Dave
    Kamloops, B.C.
    I've never heard anything about adverse effects on 02 sensors. It's pretty widely used as a 'tuneup in a can'
  20. Aug 21, 2020 at 1:09 PM
    Taniwha
    Dave
    Kamloops, B.C.
    I'm setting up for a fuel pump test. Would my FLAPS have the adapter for the Toyota fittings?
