P0171 and p2195 I'm stuck and don't know
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyoJoJo, Aug 5, 2022.
  1. Aug 5, 2022 at 9:35 AM
    ToyoJoJo
    ToyoJoJo [OP] Well-Known Member
    Jo
    2008 Toyota Tacoma 2.7 4cylinder
    So I've got a 2008 Tacoma 4 cylinder that I've redone all the intake on to fix possible vacuum leaks and replaced the pcv valve and the air fuel sensor and it's still giving me a system to lean code and the 2195 saying sensor stuck in lean position. Does anyone have any idea what I might check next? Also the short term fuel trim and long term fuel trim are running at 20% at idle???
  2. Aug 5, 2022 at 10:09 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Fuel pressure and MAF sensor would be the first things I'd check.
    Can't remember the fuel pressure spec but MAF should be about 2.7 G/s at a hot idle for a 2.7l.
    ToyoJoJo[OP] likes this.
  3. Aug 5, 2022 at 10:26 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Have you checked/replaced the O2 sensor(s) itself?
  4. Aug 5, 2022 at 10:36 AM
    ToyoJoJo
    Jo
    Thanks and ya I replaced the maf recently I'll put the scanner on it again and check the live data on the maf I want to say it was reading somewhere around 3 but it's got the k&n cold air intake so im not sure if that's standard for it or not. I'll see what's going on with the fuel pressure to. I think all my problems are in cylinder 1 so I'll check that injector also. Thanks again.
  5. Aug 5, 2022 at 10:50 AM
    ToyoJoJo
    Jo
    Yes I did the voltage is reading around 5
  6. Aug 5, 2022 at 11:25 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    2.7 Fuel pressure is 41 psi
    I wouldn’t worry if it’s +/- a couple psi.
  7. Aug 5, 2022 at 11:32 AM
    DrabT100
    DrabT100 Ex-Lexus Tech
    East Coast
    1997 T100 Turbo
    Turbo
    Clean your MAF
  8. Aug 5, 2022 at 11:35 AM
    ToyoJoJo
    Jo
    Did that a few times already
  9. Aug 5, 2022 at 11:37 AM
    ToyoJoJo
    Jo
  10. Aug 5, 2022 at 11:37 AM
    ToyoJoJo
    Jo
  11. Aug 5, 2022 at 11:38 AM
    ToyoJoJo
    Jo
  12. Aug 5, 2022 at 11:38 AM
    ToyoJoJo
    Jo
  13. Aug 5, 2022 at 11:39 AM
    ToyoJoJo
    Jo
  14. Aug 5, 2022 at 11:39 AM
    ToyoJoJo
    Jo
  15. Aug 5, 2022 at 11:40 AM
    TnShooter
    Deogee
    STOCK
    Your truck isn’t up to operating temp.
    It needs to be 170f or more to get a good reading.
  16. Aug 5, 2022 at 11:40 AM
    ToyoJoJo
    Jo
    Ill check the fuel pressure next
  17. Aug 5, 2022 at 11:41 AM
    ToyoJoJo
    Jo
    Oh okay I'll let it warm up and take some more photos. Thanks
  18. Aug 5, 2022 at 11:42 AM
    ToyoJoJo
    Jo
    Shouldn't the fuel trim be at 0 at idle weather it's warm or not?
  19. Aug 5, 2022 at 11:51 AM
    TnShooter
    Deogee
    STOCK
    Not in Open Loop.
    But your truck is in Closed Loop.
    So yes, it should be -10/+10 Total when warm (ST+LT=Total)
  20. Aug 5, 2022 at 11:55 AM
    ToyoJoJo
    Jo
    Alright so I just unhooked the battery so it would reset then let it warm up until the engine light came back on so here's the data of the freeze frame info which is what the readings are at the time the codes were triggered for the engine light
