p0120 Throttle Body Code Keeps Recurring After Cleaning
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Jun 3, 2017.
  1. Jun 3, 2017 at 4:43 PM
    prerunnerSD
    prerunnerSD [OP] Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    I have a 2001 Toyota Tacoma 4X4 V6 and I keep getting a recurring code of P0120 regarding the throttle body.
    I recently cleaned the throttle position sensor and also did a seafoam treatment in the gas tank and in the motor oil reservoir also through the vacuum lines and sprayed carb cleaner in the throttle body and the check engine light was off for like 3 weeks but recently it came back on. However yesterday it had turned off for part of the day but now its back on.
    Could it be that I need to replace the throttle position sensor? Or maybe I need to take the actual throttle body off and clean more completely and not just spray in past the throttle butterfly opening?
    Any one have any experience with this issue that comes back after being solved for awhile?
    Also can anyone recogmend a good model of front brakes and rotors for my truck my mechanic says I need new front brakes.
    Thanks for any help
    -PrerunnerSD
    http://divesummit.com
  2. Jun 5, 2017 at 2:14 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Front brakes GO TUNDRA UPGRADE!!
    Possible there's some gunk that got into TPS. I attached a file that might help.
  3. Jun 9, 2017 at 10:54 AM
    prerunnerSD
    USA
    Thanks a lot for the PDF this will provide a great insight.
    Can you please explain what you mean by Tundra upgrade regarding the brakes. Do you have a model number or other info? Thanks
    PrerunnerSD
  4. Jun 9, 2017 at 12:08 PM
    Glamisman
    Glamisman Well-Known Member
    Tundra brake calipers/rotors "should" bolt on with little modification and are worth the cost and effort. The big issue is rim fitment... more than likely have to change to 16" wheels.
  5. Jun 9, 2017 at 12:30 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I had a TPS just fail at about 180,000 miles they do wear out .
    New one from Toyota cured the Problem
  6. Mar 28, 2019 at 12:06 PM
    Dufus
    Dufus Well-Known Member
    Located in Colorado
    99 Taco 3.4L manual 4x4 SR5 - Imperial Jade Mica
    Mods: bent frame and sun weathered roof paint.
    Have any luck fixing this? I'm having the same issue on my 99 taco 3.4. Truck is tip top...cleaned the MAF, change air filter, cleaned throttle body, cleaned TPS. Haven't tried using fuel injector cleaner, but my check engine light keeps returning. I don't have the correct tools to know if my voltages for the throttle valve are operating correctly, so I'm going to now just try replacing the TPS with a new one. If that doesn't work it must be my connections or ECM?
    greengaint97 likes this.
  7. Apr 23, 2019 at 8:03 PM
    greengaint97
    greengaint97 Well-Known Member
    Al
    Colorado's Western Slope
    SOLD: 01' TRD xtra cab 3.4L five speeder
    Bump.
    Similar issue and have tried same as @Dufus. I have an 01 with the 5VZ. Am curious if a new TPS is the answer...
  8. Apr 24, 2019 at 1:02 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Be nice to know just what code your pulling when you check .
    THE TPS is simple to check a multi meter and code reader are pretty much a must have if working on OBD II vehicles the way I look at things.
  9. Apr 24, 2019 at 1:19 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I know P0120 is for the TPS but on my truck when the IAC gets dirty & starts sticking my truck will throw a P0120 code. I never get a code for IAC. I clean the IAC & it will be fine for 2-3 yrs. I know when when my IAC starts to get sticky cause my remote start won't work when cold cause of the IAC & cold idle.
  10. Apr 24, 2019 at 9:13 AM
    Glamisman
    ^^^ excellant info. Other manufacturers coding for OBDII and the TPS system the PCM will monitor the TPS voltage, the MAF(mass air flow) and an MAP(manifold absolute pressure), if equipped, and compare the three. If the MAF and MAP change dramatically and the TPS shows the same voltage it will trigger a P0120. It makes sense, the TPS voltage IS below what it should be given the other 2 inputs. I can not locate in writting if the programming for the Tacoma uses the MAF reading with the TPS voltage to trigger a P0120 but your observation is leading me to believe so. If replacing the TPS doesnt solve the P0120 I would look at the MAF and clean it. If the voltage change in the TPS is not smooth and linear that will triggere a P0120 also. This can be checked with a multimeter but a graphing multimeter will show the spike instantly.
    DLtaco02 and zero4 like this.
  11. Apr 24, 2019 at 7:51 PM
    greengaint97
    Al
    I do appreciate the replies. After some searching on TW I just opted to replace the TPS. It was ~70 bucks at NAPA (cheaper online, but I didn't want to wait). The took care of the CEL. 50 miles and still all good. Truck seems to be running better as well. More power, less lag and the throttle doesn't seem to be sticking (I gave the throttle body a good cleaning the night before last).
    I'm unfamiliar with how to clean the IAC. Is it a part of the throttle body?
    Thanks
  12. Apr 25, 2019 at 6:46 PM
    Glamisman
    it is bolted under the throttle body.
  13. Apr 26, 2019 at 6:58 AM
    greengaint97
    Al
    Thanks. It's attached with 4 Phillips screws, and it has a sensor, too, correct?
    I gave that a good cleaning when I did the TB. It's hard to really get into it. Used a lot of sea foam deep creep and some q-tips.
  14. Apr 26, 2019 at 10:56 AM
    Dufus
    Located in Colorado
    I cleaned my TPS a second time with throttle body cleaner and it worked for me, no more check engine light. I opted to clean it again instead of paying $70 for a new one because I had nothing to lose at that point. Saved some money. No CEL for a month now (fingers crossed).
  15. Apr 26, 2019 at 2:36 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Interesting, curious, what do you clean on a TPS? It shouldn't be susceptible to getting dirty like a MAF or IAC. I use to work in automotive & I've not once ever had to clean a TPS.
  16. Apr 26, 2019 at 3:54 PM
    Dufus
    Located in Colorado
    I saw a little bit of dust in the crevices, other than that I just gave it a liberal spraying with throttle body cleaner and gave it ample time to dry. No brushing or anything. This truck was abused and an after-market air intake was in use before I got a hold of her. I believe a lot of excess debris was taken into the manifold. She's purrs like a kitten now though.
  17. Apr 26, 2019 at 4:13 PM
    greengaint97
    Al
    I bought my 01 with an aftermarket K&N air intake. Makes me wonder if I should try to find a stock air intake?
  18. Apr 26, 2019 at 4:16 PM
    Dufus
    Located in Colorado
    I'm definitely not a fan of K&N. I got a stock one at my local pick and pay for pretty cheap.
  19. Apr 26, 2019 at 4:19 PM
    greengaint97
    Al
    I'll have to look around. I asked the PO if he had any parts when I bought it and he said no. It's crazy to imagine he just threw them out!
  20. Apr 26, 2019 at 4:22 PM
    Dufus
    Located in Colorado
    If all else fails locally, Yoda Jims in Denver is sure to have one.
    greengaint97[QUOTED] likes this.
