P0113 code High voltoage MAF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotagang, Jun 13, 2022.
  1. Jun 13, 2022 at 6:44 PM
    Toyotagang
    Toyotagang [OP] Well-Known Member
    Kainoa
    2005 black Toyota Tacoma 4cyl 4x4
    How’s it I have p0113 code, I got a new air filter got a new MAF and code still won’t go away any other tips or ideas? I have 2trfe my IAC is built in with the MAF
  2. Jun 13, 2022 at 7:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like either the signal wire (Pin 4 Red/Blue) is broken somewhere between the sensor and PCM or the sensor ground wire (Pin 5 Brown) is broken, has a bad connection at connector IF1, or has a bad ground (although your would likely have other codes as well if that ground was bad).
    Get yourself some backprobes and check voltages on pins 4 and 5 of the MAF sensor with it plugged in, Pin 5 (Brown) should be 0v at all times, Pin 4 (Red/Blue) should be somewhere between 0.2v and 4.8v depending on ambient temperature. If voltage checks good at the sensor you will need to find the break in the Red/Blue wire between the sensor and PCM, I saw you had another thread where you said this started after an engine install so checking all the engine wiring for damage would be a good start.
    b_r_o and TnShooter like this.
  3. Jun 13, 2022 at 8:19 PM
    Toyotagang
    Kainoa
    Thanks a lot I was curious about the pins and voltage, I’ll double check the wire it looked good to me but I’ll recheck everything
  4. Jun 14, 2022 at 11:38 AM
    Toyotagang
    Kainoa
    Just wanted to let you know and anyone else that might have this problem, even tho I got a brandnew MAF mine was faulty I had go out and buy a new one. Thanks for the help
    Dm93[QUOTED] and SR-71A like this.
  5. Jun 14, 2022 at 11:58 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    In todays parts market that is not a suprise at all especially with aftermarket parts, we have the same issue at the shop with the constant stream of faulty parts.
