P0102 code, truck won't start without gas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Evildcustoms, Dec 6, 2010.
  1. Dec 6, 2010 at 6:54 PM
    Evildcustoms
    Evildcustoms [OP] Member
    Well after installing a system in my truck, i reattach the battery and start my truck only to have it die on me, i restart it again this time putting my foot on the gas to keep it running, once it started the check engine lights on with code P0102. I searched and tried cleaning the maf like people said to do, i also sprayed electrical cleaner in the connector of the maf sensor and i cleaned my air filter to make sure thats clean.
    Anyone have any other ideas, i found tsb eg020-06 but before i go to dealer and have them rape me for something stupid i rather see if anyone else dealt with this issue.
    My truck is an 06 Tacoma DC 4.0L
    I don't see any reason for radio install to cause this as the radio is not really part of the same circuit as the engine.
  2. Dec 6, 2010 at 7:06 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    sounds to me like a massive vacuum leak. did you pull any hoses loose when routing any wires? if it is, its getting alot of un-metered air, which is why you can keep it running with your foot on the gas.
    had the same issue after installing another members SC because we forgot to transfer the intake gasket to the plenum.
    The truck would still run without a Maf, but would go into limp mode.
    Good luck
    Justin
  3. Dec 6, 2010 at 7:22 PM
    Evildcustoms
    I dont remember touching or seeing any vacumn lines at all, i ran the power wire through a grommet right on the driver side. I will double check tomorrow regardless.
  4. Dec 7, 2010 at 4:40 AM
    Evildcustoms
    another thing i noticed is when i clear the code, engine not running key on, when the scanner rescans the code is instantly there without me ever even starting the engine, so i guess that would mean that it ain't vacumn lines since engine aint running and its throwing the code already
  5. Dec 7, 2010 at 4:59 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    blow any fuses?
  6. Dec 7, 2010 at 5:20 AM
    Evildcustoms
    i only popped a radio fuse when taking radio out then realized to disconnect battery, i replaced that fuse. I will check my efi fuse when i get home, but i would think that the truck wouldnt run at all if that fuse popped. Once i give it the truck gas and it runs i take for a drive and it seems low end power is off a little, but when i give it more throttle the trans don't seem to want to down shift and when it does the car just has no top end power whatsoever
  7. Dec 7, 2010 at 5:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2
    Check EFI 2 fuse.
  8. Dec 7, 2010 at 5:32 AM
    danteisme
    South Western PA
    it almost sounds like its in "limp mode"
  9. Dec 7, 2010 at 5:37 AM
    98tacoma27
    Ben
    Not Beech Creek
    There are two EFI fuses. The #2 fuse is a 10 amp and controls the MAF, AFR, and O2 sensor.
  10. Dec 7, 2010 at 7:28 AM
    littletaco
    littletaco Member
    Tennessee
    2020 OR 4x4,2005 Pontiac GTO
    ^ P0102 is a MAF code, check the fuse.
  11. Dec 7, 2010 at 12:49 PM
    Evildcustoms
    k, found EFI 2 fuse was popped, i had the fog light mod going to that and the connection loosened up, so i said the hell with it and just put a new 10a fuse in it and took out fog light mod, no point in that if car don't run haha. Now i can finally try out the new system while driving the truck.
    Thanks guys
  12. Dec 7, 2010 at 12:51 PM
    98tacoma27
    Ben
    Not Beech Creek
  13. Dec 7, 2010 at 4:02 PM
    bmwtech330
    bmwtech330 Member
    winston salem
    2011 TRD SPORT DC 4x4
    6 bed D-rings, 35% front tint, X-PEL threshold, tailgate anti-theft screw clamps and nitrogen in the tires.
    I have a solara and when i disconnected the battery on it while replacing the battery cable ends, the car would not idle. It would sputter at 200 rpm and then die. I can't remember what the code was that was set, BUT i did place my foot on the accelerator pedal for about 5 minutes and it seems to raise the idle very very slowly until it finally idled correctly. I am a BMW tech but i don't know why my car or why your truck is doing this, but the solara did what you are describing on 3 occasions that i had the battery disconnected. I am glad I figured out what my car was doing cause I thought the only reliable vehicle i had was gonna quit! :D
  14. Oct 25, 2024 at 6:44 PM
    livpool14
    livpool14 Well-Known Member
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    aFe CAI Momentum GT Power Package, aFe POWER 76mm Throttle Body, aFe headers, aFe Y-Pipe, TRD Exhaust, VFTune, LCEngineering Dual Comp Clutch - Kevlar, Tilton 6000 Series HRB, URD quickshift, Icon Stage II, Icon Delta Joint UCAs, ECGS bushing, Cooper Discoverer at3 255/75/r17 115T, FN f(x) Pro 17" Matte Black, Ice Gray Katzkin, RCI front skid, Optima Yellow Battery, StopTech Sport Slotted Cryo rotors w/ TRD Brake Pads, Morimoto XB HYBRID LED HEADLIGHTS AMBER DRL, Anzo L Bar Taillights, BAKFlip MX4, 3rd Gen Side Decals, Plasti Dip badges, Cab LEDs, redline hood struts
    @danteisme @98tacoma27 @littletaco @Evildcustoms
    Hopefully be able to revive this. I have codes p0102 and p0430. Anyone mind helping me figure out how to locate the specific fuse you are talking about here and where would you buy a replacement? Thanks!
    (The #2 fuse is a 10 amp and controls the MAF, AFR, and O2 sensor)
  15. Oct 25, 2024 at 7:02 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It's labeled EFI on a 15 model, if it was blown I would expect you to have multiple other codes though as it feeds much more than the MAF sensor.
    livpool14[QUOTED] likes this.
  16. Oct 25, 2024 at 7:14 PM
    livpool14
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    @Dm93 i jumped the gun saying it was running silky smooth on my other thread after putting the oem TB back on. It's still having intermittent issues. Idle is rough, almost like its going to die but doesn't. Stutters during acceleration occasionally. I did eliminate a few codes so I do know the TB was contributing, but it's not the only issue. If it's not the fuse I'm thinking I'll just throw a MAF at it and if that doesn't fix it I'm assuming the wiring / harness?
    Cant imagine it's my air filter... Last thing I'll take it in and have a leak test done i guess
