"P0100" "P0110" & "P0420" CODES
Discussion in '1st Gen. Tacomas (1995-2004)' started by REDeye jedi, Jul 20, 2021.
  1. Jul 20, 2021 at 11:05 AM
    REDeye jedi
    REDeye jedi [OP] Well-Known Member
    Brendan
    Palm Springs
    2001 Tacoma prerunner 3.4l
    Hey guys and gals. My 20-year-old beauty is throwing some codes. A little history. About a month ago. It started throwing the "P0100" & "P0110" codes. So I cleaned the MAF sensor and it still threw the code. I bought a new MAF sensor and it is still throwing the code. I visually checked the prongs and harness and all seem to be fine. A couple of days ago, my check engine light came on, and it's now throwing the "P0420" code as well. I'm reading that this code can have something to do w the first 2 codes. Any thoughts? Suggestions? Thank you in advance. This group always pulls through.
  2. Jul 20, 2021 at 11:43 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Did you replace your air filter?
    Also just get the URD O2 sensor simulator for the P0420.
  3. Jul 20, 2021 at 12:03 PM
    REDeye jedi
    Brendan
    Palm Springs
    No, I haven't replaced the air filter recent bud def within the time you usually replace them. Ill go get one today.
    So is it my 02 sensors? i replaced the front one half a year ago. You think the back one is dying? Wouldnt it be better to replace the 02 sensors instead of the simulator? Just wondering.
  4. Jul 20, 2021 at 12:13 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    B1S1 is an air/fuel sensor, has nothing to do with cat.
    B1S2 is the cat nanny.
  5. Jul 20, 2021 at 12:13 PM
    Glamisman
    Glamisman Well-Known Member
    check for opens and shorts in the wires that go to/from the MAF. I can see a P0110 (air temp sensor) causing a P0420 as this is one of the inputs used to calculate fuel volume based on air temp.
    Is the replacement MAF aftermarket or Toyota?
    REDeye jedi[OP] likes this.
  6. Jul 20, 2021 at 12:15 PM
    REDeye jedi
    Brendan
    Palm Springs
    it was Toyota.
  7. Jul 20, 2021 at 12:17 PM
    REDeye jedi
    Brendan
    Palm Springs
    ok. It says one of the fixes could be one 02 sensor being lazy and not relating w the other 02 sensor. It is literally giving like 12 possible fixes so was just trying to narrow it down.
  8. Jul 20, 2021 at 12:25 PM
    Black DOG Lila
    Virginia
    You have to differentiate information on sensor performance as to what sensor (s) are on the vehicle.
    Your 01 3.4 has one a/f and one O2.
    Older models had 2 O2 sensors that compared the amount of Oxygen before and after catalytic converter.
  9. Jul 20, 2021 at 12:31 PM
    REDeye jedi
    Brendan
    Palm Springs
    ok, in my model. Where is the a/f sensor? There is definitely a sensor before and after my cat. I know the one before is O2 as I've already changed it. I was thinking the one after my cat was an O2 as well. Is that wrong?
  10. Jul 20, 2021 at 12:40 PM
    Black DOG Lila
    Virginia
    Sicyota04 likes this.
  11. Jul 20, 2021 at 12:41 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    P0420 is due to the O2 sensor and its readings. Is it the sensor at the rear of the two. The front one is A/F.
  12. Jul 20, 2021 at 12:47 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Regarding your question about replacing rather than using a sim, that depends. Usually if your O2 sensor is malfunctioning, you would get a different code. You could try to clean the O2 sensor first, to see if the readings are perhaps off due to gunk in the sensor. But most likely on your 20 year old truck, the cats are dying, and therefore are not cleaning the air as well. There are aftermarket cats that can be had for <$500, but may not even get rid of the code, or you could spend $1500+ for new OEM cats. Or you could spend $120 on a simulator and run it if you don't have emissions testing or if you know you'll still pass a "sniffer" test. For my case, I'm almost certain I will still pass a sniffer test. However I would NOT pass with a CEL. Therefore the simulator was the obvious, and far less expensive, solution.
  13. Jul 20, 2021 at 1:01 PM
    REDeye jedi
    Brendan
    Palm Springs
    ok, so I guess the one I replaced last year must have been the a/f. It is the one in front of the cat. So the back one is the O2? Should I buy a new one to see if that's the problem or do you think cleaning it would be suffice? I live in CA so we have emissions. Thank for your help.
  14. Jul 20, 2021 at 1:07 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You would have to ask someone from CA. I would try to clean it first. But if that doesn't work then I'd expect to either replace the cats or use a sim. Someone who has a sim and lives in CA may be able to help more with respect to passing or not
  15. Jul 20, 2021 at 1:18 PM
    Black DOG Lila
    Virginia
    Replacing your O2 sensor will not improve cat performance. P0420 = catalytic converter below performance threshold.
    Bad sensors have their own code #s.
    Solve the P0100 and P0110 and the P0420 may disappear.
    You may have an exhaust leak before the catalytic converter which will throw a P0420. An exhaust shop can heat test the cats and check for leaks cheaply.
    REDeye jedi[OP] and ThunderOne like this.
  16. Jul 20, 2021 at 4:40 PM
    REDeye jedi
    Brendan
    Palm Springs
    I just cleaned my air filter ( which was pretty dirty), so waiting for that to dry. If its still throwing code, what would you suggest next? stripping the tape off the wire and tracing it back to see any rips?
  17. Jul 20, 2021 at 6:45 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
  18. Jul 20, 2021 at 6:54 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Normally I'd say it's the cats, but with those two sensor codes on top it might be related to them. Id try and fix those two codes first and hope the P0420 follows
  19. Jul 20, 2021 at 7:30 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Do you have a washable filter?
  20. Jul 20, 2021 at 7:44 PM
    REDeye jedi
    Brendan
    Palm Springs
    yes, its drying right now
    ThunderOne[QUOTED] likes this.
