P0012 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacodriver1955, Dec 2, 2015.
  1. Dec 2, 2015 at 8:34 AM
    Tacodriver1955
    Tacodriver1955 [OP] Member
    Maxwell
    2015 Black Tacoma SR5
    None
    I have a 2015 4.0 liter Tacoma. Last month the CEL came on for two days and then turned off.
    Same thing happened in July. Dealer checked oil control valve and changed oil. Was fine until last month when it did the same thing. Now they want to change the cam gear actuator. Not thrilled at having a flat rate technician tearing into my new engine. I know that tech will have to hurry the job. I was a flat rate tech for 32 years at one Buick and two Chevrolet dealers.
    I got out four years ago. Disappointed at having trouble this soon.
  2. Dec 2, 2015 at 2:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Why not? They all use the Time Labor Manuals...
    You could always take it to another independent shop and have them take their time on a by the hour charge...
    Are you saying that you did shitty work for 32 years or what?
    I'm confused.
    desertrunner24 and Torspd like this.
  3. Dec 2, 2015 at 10:21 PM
    Tacodriver1955
    Maxwell
    None
    No. I am saying that the labor times keep being reduced and that encourages shitty work. Car dealers are only interested in speed not quality. More billable hours. I have seen plenty of hack mechanics. And plenty of good ones too. The good ones tend to turn less billable hours because they want to fix it right. Unless you have been or are a flat rate tech you won't understand.
    SR-71A and Rambo MARINE Recon like this.
  4. Dec 3, 2015 at 4:56 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    What I am saying is that there are good and bad in every field. Flat Rate Tech or not... I was pointing out that you more or less branded all dealer techs as wanting to get more hours over doing the job right...
    I don't think you were a crappy tech. I was only making a point.
  5. Dec 3, 2015 at 5:04 AM
    Large
    Large Red
    It's a 2015 .. let them fix it. If it breaks again, let them fix it again.
    Kyitty likes this.
  6. Dec 3, 2015 at 7:07 AM
    Tacodriver1955
    Maxwell
    None
    Thanks Jimmy. I did my best to be as professional as possible. Maybe not all dealers are the same. However I only hear complaints from the techs I know. Unfortunately it the ones that can turn the most billable hours that make the money. The "Fix it right the first time" ones generally do not from what I have seen.
    Plus Toyota won't cover my rental car while my truck is in for a warranty repair. I never saw that problem while working at the GM dealers. My truck has been running great so far. So I think I will cancel my appointment and see how it runs. I have a "free" oil change coming up next month so it's better to wait.
    Jimmyh likes this.
  7. Dec 3, 2015 at 7:54 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    ^ This
  8. Sep 2, 2017 at 11:59 AM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    I have got the P0012 code recently almost every driving time. I thought the reason for the P0012 code would be the Oil Control Valve or it´s filter, but the filter was perfectly clean and the valve works well and ohms are within specs. Checked the timing too, it was ok, not jumped and the chain was tight. Now with an other ECU it's same thing. So, anything else left than the VVT-i actuator? But it's completely mechanical unit and I don't understand what would be wrong there. I have changed the oil (5W-30 fully synthetic) and the filter (Toyota OEM) regularly, the engine looks clean inside when I took the valve covers off. About 125k in the odo.
    And the main question, how it can know that the camshaft timing is over retarded? There is no sensor for the camshafts if I have understood right.
  9. Jan 2, 2018 at 3:46 PM
    cdjudd
    cdjudd Member
    Cameron
    2015 Tacoma
    Leveling kit bed cap Bilstein suspension
    Sorry, I know I'm late chiming in. I had mine come on at 76k and couldn't figure out what it was. It showed code P0012. It turned out to be from too much moisture in the oil. As soon as I changed the oil, all dash lights shut off.
    PzTank likes this.
  10. Jan 2, 2018 at 6:54 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I would be nervous about ripping into the chains/front of the motor without REPLACING the vvt solenoid (little valve with the screens) first and driving it for a week or two. The solenoids are relatively cheap and very easy to slip in and out. The dealer said they "checked" them.. hmmm..
    The timing actuator (The adjustable gear are front of the camshaft) is a pretty serious job and it is expensive..
    Edit.. sorry I missed the part about the dealer doing it under warranty. I wonder if they swapped the solenoids side to side and the problem did not follow the solenoid to the other bank.. they could be right..
    If you're nervous, get some solenoids and out them in yourself. Make sure the oil level/condition is good, clear codes and see what happens. I would be skeptical of a actuator issue on such a new truck. Did you accidentally let the oil level run low?
  11. Jul 31, 2018 at 10:45 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Did you ever figure out what was causing this on your FJ, Finn?
    I have a 6spd 07 FJ as well and its throwing the same code.
  12. Aug 1, 2018 at 4:46 AM
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
  13. Oct 4, 2018 at 4:30 PM
    morelia
    morelia Well-Known Member
    conroeeee
    k&n intake. hid kit sound system
    I have the same code. 05 Tacoma 4.0 .bought the ocv valve. This came about after the mechanic did the head gasket job. Such a clusterfuck .
  14. Oct 4, 2018 at 7:30 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Did they waaaay over use FIPG when doing head gasket replacement? Like is there alot bulging out from Timing cover? If so chances are it's as bad on the inside. FIPG might be mucking up everything.
  15. Oct 4, 2018 at 8:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Move the ocv to the other bank and see if the code follows
    BassAckwards likes this.
  16. Oct 4, 2018 at 8:26 PM
    morelia
    conroeeee
    It doesn't look bulged. But I did change the oil on it right after . Code came back .bought the sensor. Going to install this weekend. I believe it's the vvt soleinoid?
  17. Oct 4, 2018 at 8:27 PM
    morelia
    conroeeee
    Isn't it a different part #? On bank 2?
    SR-71A likes this.
  18. Oct 4, 2018 at 9:09 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    morelia, does it idle kinda rough?
  19. Oct 4, 2018 at 10:15 PM
    morelia
    conroeeee
    Not at all .IdkId perfect. And p0012 is the only code
  20. Oct 4, 2018 at 10:18 PM
    Bishop84
    Bishop84 Well-Known Member
    It's actually an easy gear to change, the timing cover comes off without too much fight.
    I typically start with the OCV and a hot oil change first, it's really hard to test and sometimes the fault only happens at specific times.
    I understand your concern about the tech not taking their time, but it's pretty routine to do a VVT controller for us.
