P0012 code vvt solenoid location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mccallart, Sep 17, 2020.
  1. Sep 17, 2020 at 8:57 AM
    mccallart
    mccallart [OP] New Member
    2011 Toyota Tacoma 4.0
    Need help locating the two vvt solenoids. I have had a problem with a knocking noise after long distance driving. It's not real bad and dosent last long, I finally had a check engine light come on and came up with the error code p0012 retard cam position and they were telling me that it was one of the vvt solenoids. Does anyone know where this is located, will it make your engine knock a little on rare occasions, is it an easy fix?
    This is on a 2011 Tacoma 4.0 with 180,000 miles.
  2. Sep 17, 2020 at 9:03 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    There are a couple of threads on here with pictures that will help.
  3. Sep 17, 2020 at 9:19 AM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    https://www.tacomaworld.com/threads/vvt-replacement.685602/unread
    Look through this thread
  4. Sep 17, 2020 at 8:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This should help:
    Here:
    The filter plug will look like a bolt drain plug:
    mav and SR-71A like this.
