P 0504 Code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brother Lu, Aug 28, 2015.
  1. Aug 28, 2015 at 7:41 AM
    Brother Lu
    Brother Lu [OP] Member
    Lu
    Vancouver,Canada
    2009 BSP X-RUNNER
    AFE CAI,Satellite Radio,Door Speakers,18x9 American Racing Torq Thrust M Gunmetal Wheels,275-40 ZR18 Pilot Sport A/S Tires,Tundra Racing Drop,Recessed Grill,Coupe Shift Ball
    Both my ABS and traction control light come on intermittently. If I turn off and restart the truck both lights are out,sometimes for minutes,sometimes for days. Brake lights work fine. What should I check/replace first. Code reader says P0504 Brake Switch A/B Correlation.
  2. Aug 28, 2015 at 7:50 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    How is your battery. Electronics can get wonky when the battery starts to go.
  3. Aug 28, 2015 at 7:52 AM
    Brother Lu
    Lu
    Vancouver,Canada
    2009 BSP X-RUNNER
    Battery is a couple of months new. Terminals nice and clean.
  4. Aug 28, 2015 at 8:08 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Wouldn't hurt to have the battery load tested. Don't bother with checking the voltage with a VOM as that test only has value if you read below 12.6V
    From the FSM that's available here - P0504:
  5. Aug 28, 2015 at 8:47 AM
    Brother Lu
    Lu
    Vancouver,Canada
    2009 BSP X-RUNNER
    ^^^ Thank you,that PDF is going to help.
  6. Aug 28, 2015 at 4:03 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Opps! I guess I should have looked at the attachment above.
    You probably have a defective brake switch.
    DTC P0504 Brake Switch "A" / "B" Correlation
    DESCRIPTION
    The stop light switch is a duplex system that transmits two signals: STP and ST1-. These two signals are used by the ECM to monitor whether or not the brake system is working properly. If the signals, which indicate the brake pedal is being depressed and released, are detected simultaneously, the ECM interprets this as a malfunction in the stop light switch and sets the DTC.
    HINT: The normal conditions are as shown in the table below. The signals can be read using an intelligent tester.
    With the brake pedal released the STP is Off and the STP1- is On. The opposite is true when the brake pedal is depressed. If the system senses both on or off it throws this code.
    Conditions
    (a), (b) and (c) continue for 0.5 seconds or more (1 trip detection logic)
    (a) Ignition switch ON
    (b) Brake pedal released
    (c) STP signal OFF when ST1- signal OFF
    Causes:
    • Short in stop light switch signal circuit
    • STOP fuse
    • Stop light switch
    • ECM
    1MK likes this.
  7. Aug 28, 2015 at 4:05 PM
    1MK
    1MK Desert Explorer
    Southern California
    I'd say faulty brake light switch. It's fairly common for them to intermittently work.
  8. Aug 28, 2015 at 5:25 PM
    Brother Lu
    Lu
    Vancouver,Canada
    2009 BSP X-RUNNER
    Thanks guys,I checked the brake switch today,I wish I was a leprechaun:)
