Ozium Air Sanitizer Spray?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jessejsalmon, Mar 15, 2024.
  1. Mar 15, 2024 at 6:24 PM
    jessejsalmon
    jessejsalmon [OP] Active Member
    Greetings,
    Has anyone used Ozium Air Sanitizer?
    Pretty sure there is a mouse nest somewhere in the air system of my 2000 Tacoma. AC/heat blows out mouse nest smell. Has been this way for 6 months. Smell not horrible but it's there. Considering running Ozium through air intake. Alternative is paying someone $1100 to tear apart the dash.
    Thanks
  2. Mar 15, 2024 at 6:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ozone generator
    hucklebarry likes this.
  3. Mar 15, 2024 at 8:44 PM
    Glamisman
    Glamisman Well-Known Member
    The squirrel cage comes out really easy... you can get to some of the housing from there.
  4. Mar 15, 2024 at 10:10 PM
    phoforbreakfast
    phoforbreakfast Well-Known Member
    100%, kills organic matter and makes your car smell like fresh electronics.
  5. Mar 15, 2024 at 11:33 PM
    jessejsalmon
    I'm not following.
  6. Mar 16, 2024 at 7:56 AM
    1blink
    1blink Well-Known Member
    Storm Mtn, CO
    2000 3.4 manual SR5
    Squirrel cage, aka blower fan. Pull out the blower fan, see if your deadmous is there. Look up the piping from that point once you remove it for other debris that can be reached
  7. Mar 16, 2024 at 7:58 AM
    RobotTheDog
    RobotTheDog Well-Known Member
    AZ
    21 TRD OR DCSB CEMENT
    All encompassing layer of dust
    Peppermint will have them headed for the hills, albeit not in a Tacoma
  8. Mar 16, 2024 at 8:26 AM
    jessejsalmon
    ok, ya did that. Got a little nest material out with a shop vac, but none of it was actually in the blower motor, where I was lucky enough to find a different nest years ago.
  9. Mar 16, 2024 at 8:38 AM
    blind cowboy
    blind cowboy Well-Known Member
    Don
    Auburn CA
    2002 TRD XC 5sp
    Many years ago I knew a kid who said he was friends with the son of the guy who invented Ozium. Son said his Dad developed it for use in morgues so think it would work on a dead mouse smell.
  10. Mar 16, 2024 at 8:42 AM
    hucklebarry
    hucklebarry Well-Known Member
    casey
    02 tacoma
    arb bumper, warn 8000 winch, arb air pump, arb front locker, and old man emu lift
    Once you have the fan out, you can access a lot of the system from there.
  11. Mar 17, 2024 at 7:35 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I've been using it for about 20 years now. It's the best way to kill weird smells.
  12. Mar 17, 2024 at 1:43 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Have you tried cleaning out the AC drip tray. They sell foams that you shoot up the AC drain tube and clean out the gunk. Sometimes mouse pee will get caught in there and make weird smells.
  13. Mar 17, 2024 at 2:40 PM
    FixMyTaco
    FixMyTaco Well-Known Member
    Lee
    Alaska
    96 ext cab 4wd mt 3rz 400k mi.
    Rebuilding seats with leather from furniture and extra padding. Might put leather on the dash and other interior parts.
    Could always tell when someone was smoking weed in the dorms cuz it smelled like ozium.
    When I got my taco it did not smell like something that didn't have a butthole. I used an ozone generator for a couple days and a can of lysol. Now my taco smells like not a butthole.
    O3 not good for rubber stuff, so maybe not use that alot. It was a Peet boot dryer add-on to unstink shoes.
    Center dash cover comes off pretty easy, just 2 screws, gives some access to ducting.
