OZBoost turbo group buy 2TR-FE and 3RZ
Discussion in 'Group Buys' started by SUMMIT556, Jun 8, 2015.
  1. Jun 8, 2015 at 6:22 PM
    SUMMIT556
    SUMMIT556 [OP] FCK Lightbars sponsor
    09 Tacoma SR5 4-cyl
    Bilstein 5100 front, FOX 2.0 remote resi rear, 2in add a leaf, OME 885 coils, magnaflow exhaust, LCE header, Toyo ATII 285/75/r16, fck lightbars, retrofit headlights and more.
    Finally a turbo kit for the 2tr-fe!
    OzBoost is a company from Australia and specializing in turbo building for the 2tr-fe. They have the hilux with the 2tr but they have fitted the kit in the Tacoma. The engine is the same in both models.
    What OzBoost says:
    Turbo kit to suit 2.7 PETROL 2TR-FE engines. This kit suits 2WD & 4WD vehicles. Kit bolts on with all parts required. Can be upgraded with intercooler, injectors, and ecu. Skys the limit. Generic T28 turbo used. Dump pipe can be either 2 1/2 vband with 90 degree mandrel bend for custom exhaust or pipe to suit standard exhaust. We recommend 5PSI boost be set and the standard ECU, Injectors and airflow meter will run fine no tuning is required.
    Pricing:
    $1,487 for the entry level kit. With free shipping! Normally shipping woukd be $300+ but Only if we get 10+ people!
    we need 10 people for the discounts. Help get the word out on the turbo for the 2.7L. I will post updates and anything else. This is my first group buy so I'm sorry for any misses information.
    krustytaco, 06turd and mason33x like this.
  2. Jun 8, 2015 at 6:53 PM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    Update they have a 3rz kit. Pretty much the same as the 2tr kit but fitted for the 3rz. Pricing is also the same.
    krustytaco and Nedrolls like this.
  3. Jun 8, 2015 at 7:20 PM
    SilverJack
    SilverJack no one
    Depends on the environment and equipment. I do hope they mean Garrett not Generic for the turbo type. Garrett is a part of HTT and they make a good and durable turbine. Longevity means keeping the heat down since it has to live in an 1,500+ degree exhaust stream. Anyone not living in a cold climate needs to look at an oil cooler and inter-cooler. I'm also not thrilled to see it right next to the brake lines, coolant lines and firewall.
    Still an interesting design and low price point. i'm curious to know more.
  4. Jun 8, 2015 at 7:28 PM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    The price is realistic. Think of the cost of a turbo. Then the price of building a turbo manifold. Which no one makes for the 2tr. This is a realistic price. Not making 500% profit like other aftermarket products.
  5. Jun 8, 2015 at 7:33 PM
    Boring
    Boring This space unintentionally left blank.
    Arizona
    5-lug regular cab
    yarp
    Subscribed. I found their website a while back. That's as far as I got. Air filter box looks a little convoluted on the 1st gen system. Nice that they found the Tacoma too, but I already put an expensive LCE header on mine. I was thinking maybe the URD system some day after the warranty ran out. Will the first guinea pig please pull out your credit card! ;)
    Turdyota3000 and putmeintacoma like this.
  6. Jun 8, 2015 at 7:43 PM
    SilverJack
    SilverJack no one
    For a Garrett T28, you are right on the money. The rest is just pipe and fittings. I suppose if the R&D is already done, then a company could drop their price to open a new market. The basic kit has very little other than the turbo, intake and exhaust. It's also running at lower boost.
    That's why I'm curious to know more. Can something this cheap make good power without cooking itself?
  7. Jun 8, 2015 at 7:51 PM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    I believe it will do just fine. For running 5psi of boost the kit will not detonate the engine. This kit has been out for years over In Australia.
  8. Jun 8, 2015 at 8:34 PM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    This is what comes in the box. This shipment was sent to the US military in Ohio.
    putmeintacoma likes this.
  9. Jun 8, 2015 at 10:33 PM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    Here is the parts list for the kit.
    2TR-FE PARTS LIST
    BLOW OFF VALVE
    TURBO BOOT
    2 X WATER T-PIECES
    FUEL REGULATOR & BLOCK OFF PLATE
    BOOST GAUGE AND BRACKET
    BRADED OIL AND WATER LINE KIT
    DUMP PIPE
    TURBO
    4 LOCKING NUTS & STUDS
    MANIFOLD
    3 INCH STRAIT SILICONE
    INSTRUCTION PICTURES
    3 X 6MM NUTS AND BOLTS
    5 X DUMP PIPE BOLTS
    PLASTIC T-PIECES 2 OF EACH SIZE
    VACUUM HOSE 4 METERS
    FUEL HOSE 8MM 1 METER
    AIR POD FILTER
    AIR FLOW METER CUSTOM PART
    2 X RESISTORS
    MINI POD FILTER FOR ROCKER COVER BREATHER
    2 X CUSTOM INTAKE SILICONE
    2 X TURBO GASKETS
    7 SMALL HOSE CLAMPS FOR FUEL WATER
    5 X 11-23MM HOSE CLAMP
    2 X 17-38MM HOSE CLAMP
    1 X 60-68MM HOSE CLAMP
    2 X 79-87MM HOSE CLAMP
    1 X 74-79 MM VLAND HOSE CLAMP
    BEANIE-STICKER-USB OPTIONAL
    t1m829 likes this.
  10. Jun 9, 2015 at 3:46 AM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    anyway to get this kit without the turbo? all i really want is the manifold n dump pipe lol
  11. Jun 9, 2015 at 5:25 AM
    SilverJack
    SilverJack no one
    Is that a Garrett turbo in there? I can't tell from the boxes, since most look like Chinese aftermarket stuff. Before anyone risks turbine failure and destroys their engine, it's important to know where the parts come from and how much test data exists. Saying "it's been sold in Australia for years" is not test data, it just means they have a lot of spare engines around.
    The website is very vague and keeps mentioning "generic" T28 turbos. A turbo spins around 100,000 rpm in a 1,500 degree F environment. The turbo is connected to the engine's oil system (and coolant system in this kit). So a turbo failure can quickly drain engine oil and coolant while sending white hot turbine chunks down the engine intake. I still think this could be a good kit, but a "generic" turbo isn't going to cut it.
  12. Jun 9, 2015 at 6:07 AM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    You can get the turbo manifold for around 400 I think and I'm not sure about the dump pipe I will ask.
  13. Jun 9, 2015 at 6:09 AM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    Let me ask what they run. I know most ball bearing turbos require oil and coolant.
  14. Jun 9, 2015 at 12:24 PM
    JAL4
    JAL4 Well-Known Member
    AJ
    Colorado
    All Black 4x4
    Leer Topper and Black Tacoma wheels
    I am very intrigued...... But what scares me is they say that there are options for a intercooler, But on their website doesn't even list what is in the kit..... Or how to get a intercooler with their kit.
    I would want someone who has had this on a hilux chime in and tell us they have at least not blown their engine using it.
    Do they have a warranty associated in case if this does blow your engine? Or at least a warranty for the parts that are going into your truck? I would guarantee this will void your entire powertrain/engine warranty
  15. Jun 9, 2015 at 12:43 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Hat's off to Ozboost.
    SUMMIT556[OP] likes this.
  16. Jun 9, 2015 at 12:56 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    You foresee a lot of people over boosting their turbos because they don't know what they are doing? Maybe. Id like to say a well made $1K+ turbo wouldn't have failed in the same situation but I'd probably be wrong. May not have exploded but would def fail. Edit, Nvmind, that video was of a Garrett GT4088.
    The cheap turbos will be fine in any power range you'd look to get with the TRD S/C and even beyond. I wouldn't skimp on the waste gate though (I wouldn't be surprised if the guy in the video had a bad WG cause the turbo to over boost.).
    The Hunter likes this.
  17. Jun 9, 2015 at 4:43 PM
    SUMMIT556
    09 Tacoma SR5 4-cyl
    Why not all 3?
  18. Jun 9, 2015 at 4:49 PM
    JAL4
    AJ
    Colorado
    All Black 4x4
    I found something cheap fast and reliable:turtleride:
  19. Jun 9, 2015 at 5:01 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  20. Jun 9, 2015 at 7:05 PM
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    I'd be interested... wonder how hard/easy the install would be. Hilux is not completely the same as Taco... have you installed one on a Tacoma before? Question to the OP.
