Ozark Trail 73-Quart & 26-Quart High Performance Roto-Molded Coolers - "Real World" Test
Discussion in 'Product Reviews' started by dan0mite, May 23, 2016.
  1. May 30, 2016 at 7:29 PM
    #221
    dan0mite
    dan0mite [OP] #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    Here is my results/summary post. I've updated the first post of the thread with the same so you won't have to dig for this post...
    The Beginning
    So here's the deal...I bought a couple of the Ozark Trail HP Coolers based on some reviews I've read. My wallet is just over $300 lighter after buying BOTH coolers so I'm still doing better, cost-wise, than a Yeti, Brute Box, RTIC, etc. Now I want to test these myself but figured you lazy-asses would want to follow along.
    The Coolers:
    I filled both coolers with ice around 4pm on Monday, May 23, 2016 and then put some soda and water in them about 30 minutes later. To the top with ice only, the 73qt cooler took 80lbs of ice and the 26qt took about 25lbs of ice.
    Test Parameters
    • I didn't "pre-cool" the coolers because who the fuck actually does that?
    • I don't care about ambient temperature because it is what it is and it's a variable that I don't care to try and control. The coolers are outside on a 4th floor balcony and thats as good as it's going to get.
    • I max filled the coolers with ice to simulate preparing to take the coolers with ice on the road where ice isn't too available.
    • I will put as much drinks as I can in each cooler with the goal of not removing any ice. As ice begins to melt down and more room is made, more drinks will be added.
    • Everything that the coolers get stocked with will be at room/ambient temperature. Nothing is precooled.
    • I will not start to pull drinks out until the next morning to simulate preparing the coolers the night before a trip.
    • Beginning the next day, I will remove and replace drinks as I am thirsty to simulate actually using the coolers as you would on a trip. None of that opening once or twice a day bullshit here...
    • At the end of each day I'll take pictures of the ice retention and post them here.
    • If you have any questions, suggestions, criticisms, etc...keep them to yourself because nobody cares! Just kidding, I'm open to whatever as long as it's general bullshit and you're not trying to move this test away from its "real world" goals.
    Day 1
    Just opened the coolers for the first time since filling them at 4pm yesterday. I'll begin to open them regularly now but here are picture updates.
    I pulled out a bottle of water from the 73 but will begin to pull out something to drink from both coolers at the same time. The reason I'll open both coolers is to simulate using only one and to not artificially prolong the ice retention by alternating.
    End of Day 1
    I've been in the coolers about 5-6 times today and they haven't been restocked yet. Not much ice loss in the 73 but you can already see the difference in the 26 since this morning.
    73qt Day 1 Morning:
    73qt Day 1 Evening:
    26qt Day 1 Morning:
    26qt Day 1 Evening:
    Day 2
    Coolers were restocked last night. Was able to break up the ice in the 26 to get some drinks under the ice but also put some on top too. Without getting a BFH, I could only break a few inches of ice on top in the 73 so not a lot went into restocking it.
    The water in the 23 is just under that top layer of ice.
    End of Day 2
    The 26 had a ball of ice surrounded by all water this evening so I broke it up and restocked the cooler. The 73 was still solid ice but I was able to take a bottle of water and chip away at the edges. Couldn't break into the center of it though. I restocked the 73 as much as I could down the sides of the cooler where I was able to see a little water and on top of the ice block just enough so I could cover the drinks with ice. Obviously I could pile more cans and/or bottles in there but I didn't see the point since they would only be sitting on top and not really being chilled.
    73qt Day 2 Morning:
    73qt Day 2 Evening:
    26qt Day 2 Morning:
    26qt Day 2 Evening:
    Day 3
    The 73 is beginning to show signs of mortality now as the ice melts. I'd be willing to bet it'll go at least another 3 days.
    The 26 is mostly water now with a couple inches of ice floating on top. I think it'll keep things cold for the rest of the day but probably won't last the night.
    End of Day 3
    73qt Day 3 Morning:
    73qt Day 3 Evening:
    26qt Day 3 Morning:
    26qt Day 3 Evening:
    Day 4
    The 26 is done. No signs of ice other than the very cold water. I've moved all the drinks from the 26 to the 73.
    The 73 is still going strong with a solid block of ice that formed itself in the beginning. I've been restocking around the edges and am debating on breaking up the ice block. I'm leaning towards breaking it up tonight when I restock it again.
    End of Day 4
    The 73 is hanging tough.
    Day 4 Morning:
    Day 4 Evening:
    Day 5
    I feel the 72 is going to last at least a few more days. When I went to open it this morning, I noticed the hardware on the lid holding the latch was loose so I ended up tightening all the hardware as it all needed it. Now I'm not sure it was right to begin with as I didn't check. Everything is snug now so I'll report back at the end of this test as to whether everything stayed tight or not.
    End of Day 5
    This cooler is still kicking ass with ice retention.
    Day 5 Morning:
    Day 5 Evening:
    Day 6
    I stocked the cooler this morning with 12 cans at room temp.
    Unstocked:
    Stocked:
    End of Day 6
    There's still a little bit of ice left but I don't think enough to last until morning. Pretty sure the restock I did this morning did it in.
    Day 6 Morning:
    Day 6 Evening:
    Day 7
    I was surprised to still find ice this morning...so the test continues.
    End of Day 7
    The 73 was done around 5pm today. There were a couple stray ice cubes but not enough to make a difference.
    Day 7 Morning:
    Day 7 Evening:
    Results Based on My Test Parameters
    The 26qt lasted approximately 3.5 days with everyday use.
    The 73qt lasted approximately 7 days with everyday use.
    Manual For 73qt
    Issues
    While the 73 cooler was in direct sunlight, the top deformed a bit then went back after being back in the shade. This is something I'll have to keep an eye on because I wonder if it'll end up cracking. The 26 doesn't have this problem...
    Here are pics of what I was referring to regrading the top of the cooler. Took these with the weather showing 81 degrees.
    Again, it goes back down to normal after being in the shade.
    I hope this isn't something that affects all the large coolers and if it does, the 5 year warranty will get exercised quite a bit I feel.
    Post from @ramonortiz55 about the issues he had with the 26qt he bought:
    Filled with Ice on Friday noon..
    Was good until Saturday afternoon:
    Replacement Parts
    Thanks to @tomwil for finding this post which verifies replacement parts for the Ozark Trail cooler!!
    http://www.expeditionportal.com/for...ce-quot-cooler-any-good?p=2085050#post2085050
    Final Thoughts
    I feel these Ozark Trail coolers are a great alternative to the higher priced high performance coolers out there such as Yeti. Once these become more readily available at all Walmart's, I feel these will be the go-to cooler until RTIC catches up with fulfilling orders, even more so since you'll be able to grab these Ozark Trail coolers at any Walmart.
    I am on the fence on keeping the Ozark Trail coolers because of the problems mentioned in the above "Issues" section. Busted latches and lid skins deforming in sunlight on an 81 degree day on brand new coolers, even at this price point, is unacceptable. I will exchange the 73qt for another with hopes that it was an isolated issue with the cooler I currently have. If the 26qt I have busts latches like Ramon's did, I will just return it and order an RTIC like he did.
    The 5 year warranty sounds like a great one; however, you have to return the cooler to Ozark Trail in Canada. I don't even want to think about the cost of shipping a 73qt cooler to Canada for warranty work. Something to think about as well...
    EDIT: @tomwil pointed out that there are verified replacement parts available for the Ozark Trail coolers from Gander Mountain. I've added this fact above in its own section. Now the only concern for me is the issue with the lid on the 73qt. Hopefully it's an isolated issue to this cooler.
  2. May 30, 2016 at 7:37 PM
    #222
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Cool test.
    The ice retention between the 2 did not surprise me.
    Totally sucks about the lid and latches.
    huachuca likes this.
  3. May 30, 2016 at 7:44 PM
    #223
    dan0mite
    Dan
    SC
    d00kie
    Definitely does suck. The lid skin expanding really wasn't an issue but makes you wonder how it'll hold up when it's 20 degrees hotter outside and/or if it'll crack/split over time. The latches breaking on Ramon's cooler...unacceptable because you can't even use the cooler after that.
    Full disclosure: I didn't have any issues with the latches on either of my coolers and I pulled on them to open the lids on both coolers after unlatching. :notsure:
    1rooster and jmaack[QUOTED] like this.
  4. May 30, 2016 at 8:12 PM
    #224
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    DrFunker and dan0mite[OP] like this.
  5. May 30, 2016 at 8:18 PM
    #225
    dan0mite
    Dan
    SC
    d00kie
  6. May 31, 2016 at 2:00 AM
    #226
    DrFunker
    DrFunker Well-Known Member
    Nice write up Dan! :thumbsup:
    Thanks.
    dan0mite[OP] likes this.
  7. May 31, 2016 at 4:27 AM
    #227
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Great Job Dan!!!!
    dan0mite[OP], DrFunker and JimboAnz like this.
  8. May 31, 2016 at 4:34 AM
    #228
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Agreed, great job Dan-O, thanks for your time and great documentation on this one :thumbsup:
    dan0mite[OP], DrFunker and SC2SC like this.
  9. May 31, 2016 at 4:49 AM
    #229
    SC2SC
    SC2SC Likes Pineapple on Pizza
    Jonathan
    South of Charlotte
    2014 DCSB MGM TRD OR 4X4
    Icon Custom Build Custom Exhaust • SOS Sliders• RokBlokz
    @dan0mite great write up and summary. Its nice that you included other peoples issues and parts solutions! :)
  10. May 31, 2016 at 4:52 AM
    #230
    IPNPULZ
    going to be fun!
    Now if we can just find one!
  11. May 31, 2016 at 6:10 AM
    #231
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    what is a K2?
  12. May 31, 2016 at 6:32 AM
    #232
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    Nice summary!
  13. May 31, 2016 at 6:34 AM
    #233
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    http://www.k2-coolers.com/
    basically rotomolded coolers, just another brand like Yeti, Engel, Ozark, Iceytek, etc
    dtopgun515[QUOTED] likes this.
  14. Jun 2, 2016 at 8:32 AM
    #234
    CamFromCI
    CamFromCI Member
    Cameron
    Hey Everyone awesome thread!
    I work for the company that designs and produces the Ozark Trail Roto molded coolers for WalMart. Part of my job is to keep an eye out for folks who are not completely satisfied with our product and have not yet contacted our customer service.
    Long story short, awesome to see that you guys are testing them out, reviewing them and sticking by us as we iron out any initial start-up bumps in the road. I'll definitely forward the results of your testing to our design team, so thank you for the time you've put into this assessment of our coolers.
    We can take the latch replacement part of this situation offline (email us your address and we'll get latches sent right out) but let's not stop there…tell us more so that we can get to the bottom of these latch issues and the shell bowing that you are experiencing.
    For any part replacement request feel free message me here, or our service team at: service@ca-innovations.com
    Thanks again,
    Cam
  15. Jun 2, 2016 at 8:33 AM
    #235
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    when will these be in Walmarts in Charlotte NC?
    CamFromCI[QUOTED] likes this.
  16. Jun 2, 2016 at 8:35 AM
    #236
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    Access cab 2nd gen/DCSB 3rd gen
    That's some bombass customer service. Might have to get one now
  17. Jun 2, 2016 at 8:50 AM
    #237
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
    No doubt.
    CamFromCI likes this.
  18. Jun 2, 2016 at 9:01 AM
    #238
    conifers4
    conifers4 Tired and Broke
    Brian
    Long Island, NY
    2010 DCLB 4X4
    Thanks for coming aboard Cameron
  19. Jun 2, 2016 at 9:04 AM
    #239
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Not a major problem, but I have had the 26 quart cooler for a few months now. Besides the latches showing some wear quickly, like stated above, one thing I have noticed is the handle sometimes is really difficult to move back in place after being in the down position. Sometimes I have pulled up on it so hard to try to latch it back it place, that it feels like I'm going to break it off. Not sure how it could be fixed or if it can but that sucker is really in there good because I have put a lot of strain on it trying to move it back into carrying position.
  20. Jun 2, 2016 at 9:07 AM
    #240
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    +1. I love seeing all the awesome customer service we get here on tw, even from a company who has nothing to do with tacomas.
    @CamFromCI - any idea when these will get restocked at walmart? I'm definitely looking at a 52 or 73.
    DrFunker, CamFromCI and JimboAnz like this.
