Oxidation or mold on window trim?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MudFlap, Apr 29, 2020.
  1. Apr 29, 2020 at 3:04 PM
    MudFlap
    MudFlap [OP] Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    Anyone know how to get this crap off?
    dpak likes this.
  2. Apr 29, 2020 at 3:43 PM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Would like to know also.
  3. Apr 29, 2020 at 3:58 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Looks like mold the way it branches out in circles, but can't be certain.
  4. Apr 29, 2020 at 4:04 PM
    Tacoma Mike
    Southern Maine
    I just cleaned mine up last weekend.
    No way near as bad.
    I used purple power full strength with a rag and lots of elbow grease.
    I then used meguiars back to black.
    Again with a cloth and rubbed really hard to embed it. Did it twice.
    I’ll get a pic for ya
    MudFlap[OP] likes this.
  5. Apr 29, 2020 at 4:07 PM
    Tacoma Mike
    Southern Maine
    Going to have to do it again.
    It was a PITA and 20% as bad as yours
    I don’t know, try something stronger like thinner or something?
  6. Apr 29, 2020 at 4:34 PM
    pyrite4t3
    pyrite4t3 Well-Known Member
    12 TRD OR AC
    DO NOT USE THINNER!!
    @Tacoma Mike no disrespect sir.
    I have yet to try it, but I've read that magic erasers work on this. I am experiencing the same problem on mine and just haven't had time to devote to it.
    DrFunker likes this.
  7. Apr 29, 2020 at 4:38 PM
    Tacoma Mike
    Southern Maine
    Oh hell none taken..
    I said I didn’t know but if you know something please share.
    Not prob man.....
    I remember someone said he was going to try it.
    Don’t remember anything after that..
  8. Apr 29, 2020 at 4:40 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Mines bad also. What do you think causes it? I was thinking some kind of rubber mold. I have tried vinegar, soap, rubbing alcohol, nothing really seems to work.
  9. Apr 29, 2020 at 4:41 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I've always killed that mossy mildew shit with vinegar, it wipes off after a minute to kill.
    SR-71A, spitdog, Skyway and 3 others like this.
  10. Apr 29, 2020 at 4:46 PM
    MudFlap
    Tim
    2012 TRD Off Road
    Well... I think I'll just try a magic eraser dipped in purple power. Haha!
    Thanks yall!
  11. Apr 29, 2020 at 4:53 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    303 aerospace protectant will help that out
  12. Apr 29, 2020 at 4:56 PM
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    Ajax and a toothbrush. Ajax has bleach in it that helps kill the mold.
  13. Apr 29, 2020 at 5:02 PM
    pyrite4t3
    12 TRD OR AC
    I shared what I had read on other parts of this forum. I also know that laquer thinner is fabulous for many things and detrimental to others. I've also seen the longer term effects on rubber and plastics and they generally aren't good. I'd hate to see ten of us need to replace that seal because we prematurely dried it out.
    I like the vinegar suggestion stated above and would definitely try that. Alcohol may work as well, but would need to see it work, and for me it didn't.
    As a detailer I always try to start with the least invasive method and work my way up the "intensity" scale to find a solution.
    If we knew for certain what causes many of us to have this same problem it would be easier to hone in on the solution. I would be willing to try some things this weekend, but unfortunately I won't have time prior to devote to this until then.
    Skyway likes this.
  14. Apr 29, 2020 at 5:15 PM
    Tacoma Mike
    Southern Maine
    I agree with your logic but a one time test in a hidden place for him might be warranted. That’s really bad.... I see this and I think it’s poss a UV breakdown? Just thinking out loud..
  15. Apr 29, 2020 at 5:24 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    we all have it, or gone get it at some point.
    for sure
    :cheers:
  16. Apr 29, 2020 at 5:28 PM
    spitdog
    After I get that crap off, I’m going to try rubbing in some silicone. Something that will stay awhile and seal the pours in the rubber.
  17. Apr 29, 2020 at 5:47 PM
    pyrite4t3
    12 TRD OR AC
    I agree with the potential for UV breakdown. I think it's a distinct possibility. The fact that so many of us from the dry hot, to the rainy, to the humid regions have it really support that.
    Rubber is porous so whatever is happening is really sinking in and being a real prick about removal. And the marks on the Op's pictures match what I see on my trim. Almost definitely mold, but I'm no chemist. :confused:
  18. Apr 29, 2020 at 5:57 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I've used the magic eraser on the black plastic trim with great results, but I've never tried it on the window trim. I'm likely to believe that it will work since it's abrasive. Just be careful of the paint. Maybe tape it off. Interested to see what works though.
    EdgemanVA and Skyway like this.
  19. Apr 29, 2020 at 6:12 PM
    spitdog
    How to Remove Mold From Rubber
    By RACHEAL AMBROSE Updated JULY 17, 2017
    When mold forms on rubber, it's important to kill and remove it quickly to prevent long-term damage. Because rubber is porous, the mold may penetrate the surface of the rubber. Eventually, this can cause the rubber to fall apart. Both vinegar and bleach are effective at killing mold. Bleach kills mold faster, but may discolor or weaken the rubber. Vinegar takes several hours to kill the mold, but will not damage the rubber.
    pyrite4t3, Tacoma Mike and Skyway like this.
  20. Apr 30, 2020 at 3:59 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I have that shit but thought it was because I lived in the humidity capitol of America. Interesting we all have it. None of my non Toyota cars have ever had this mold.
    Biscuits likes this.
