Overthought spare tire mod.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cricket-0, Apr 9, 2022.
  1. Apr 9, 2022 at 8:39 PM
    Cricket-0
    Cricket-0 [OP] Well-Known Member
    I searched for something like this and couldn't find it, I combined some ideas from multiples users and thought I would share for other people trying to do what I did.
    I wanted to fit a full size 285/70/17 spare tire, and have it be part of my 5 wheel rotation. Two problems i've seen personally from mine or my friend's trucks.
    1.) The wheel getting scratched underneath the truck, either from debris, the spare tire holder or the crossmember in the bed frame.
    2.) The tire getting indented from the crossmember pushing constantly.
    First I stole Hodakguy's chain hoist relocation.
    https://www.tacomaworld.com/threads...to-new-adventures.528480/page-5#post-17311994
    Painted and clear coated. That yellow you see is cosmoline.
    Next I wrapped the hoist chuck with foam pads, https://www.amazon.com/dp/B071R4DR1R?ref=ppx_yo2ov_dt_b_product_details
    On second thought, this wasn't necessary because its along the backside of the wheel, I had the stuff laying around and figured it wouldn't hurt.
    Lastly, I wanted to protect the top of the wheel from being indented by the crossmember. I purchased this from a tractory supply/cals ranch/ farm store
    https://www.tractorsupply.com/tsc/p...t-black-4-ft-x-3-ft-x--frac12-in?cm_vc=-10005
    Cut it to the wheel and hoisted it up, it was WAAAY to big in diameter. So i cut it down signifcantly smaller.
    Everything seems to be protected, most likely overkill, but my little brain likes it.
  2. Apr 9, 2022 at 8:45 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    Very thorough and you really saw this one through to the end. I recently dropped my spare tire on my 2018 for the first time just to make sure I know how to do it. Lubed everything up while I was at it. Hopefully it will be another 4 years before that wheel touches ground again.
  3. Apr 9, 2022 at 8:51 PM
    Cricket-0
    Thanks! Did your spare have any indents on the tire? Definately don't want to be trying to figure out how to use your chain hoist on the side of a freeway haha.
  4. Apr 9, 2022 at 9:04 PM
    Tacomaryan18
    It didn’t have any indents that I noticed. I was surprised to learn my spare rim is a blacked out version of my Limited rim. I guess I thought it would either be a matching wheel or a black steelie.
    Malvolio likes this.
  5. Apr 10, 2022 at 5:57 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    The Limited rim is the same rim with a "skin".
  6. Apr 10, 2022 at 7:22 AM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    To address concerns like those of the OP, I just carry the spare in the bed of the truck. Underneath the vehicle is probably the worst place to carry it, for a variety of reasons.
    RIX TUX and AmateurTaco1313 like this.
  7. Apr 10, 2022 at 7:04 PM
    Cricket-0
    That would be my choice as well if I didn’t use my truck bed daily.
    musicisevil likes this.
  8. Apr 10, 2022 at 7:34 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Don’t wait 4 years to drop it... check it annually for proper air pressure.
  9. Apr 10, 2022 at 7:36 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    I just moved the hanger.
  10. Apr 10, 2022 at 7:40 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    l use a few squares of sheet rubber on top of the tire, keeps it from getting any indents.
  11. Apr 10, 2022 at 9:17 PM
    05 4x4
    05 4x4 Well-Known Member
    recently heard a clank and a non flat tire feeling on my 2nd gen. pulled over and had a flat tire on the front. On the side of the freeway I swapped my larger k02 for the spare which ive kept an eye on pressure over the years. No issues getting to a tire shop to get it fixed before a 4x4 camping trip. Keep it filled and it should be fine stock....
  12. Apr 10, 2022 at 9:29 PM
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    I too was concerned about permanent sidewall dents with the crossmember, but my solution was waaaaaay less neat than yours. I hacked circles out of the middle of some foam exercise tiles and just chucked 'em on top. Seems to be working a couple years later...
  13. Apr 10, 2022 at 10:10 PM
    DustyTacosOnTuesday
    DustyTacosOnTuesday Member
    JB
    22 Tacoma TRD Off Road
    the hoist chain just sort of dangles under the spare -- any creative ideas for how to tidy that up?
  14. Apr 10, 2022 at 10:20 PM
    Cricket-0
    Love it! Basically what I did, I’ll be removing mine from time to time for the 5th wheel rotation so i wanted something I could reset easily. Otherwise I probably would have done the exact same.
  15. Apr 10, 2022 at 10:22 PM
    Cricket-0
    I was curious on this as well, but the problem fixed itself with the rubber circle. The slack part of the chain now rests on top of the rubber pad and below the cross member and rests there. Doesn’t touch the wheel, doesn’t dangle and make sound.
  16. Apr 11, 2022 at 4:16 PM
    Cricket-0
    Another piece of the puzzle for the lifted truck. I put together two pieces of wood attached them together then put a bolt through to line up with the stock jack. Everything goes back under the seat as it should without any rattling.
    Next up is wrapping the exhaust pipe near the spare tire.
  17. Apr 11, 2022 at 10:32 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    I lucked out and found a never used spare with a new bfg tire on FB for 40 dolls that I put in the bed if I go scary places
    AmateurTaco1313 and shakerhood like this.
  18. Apr 12, 2022 at 5:29 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Ziptie.
  19. Apr 12, 2022 at 6:27 AM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    Ironically, I read this thread yesterday, pulled out of my garage to head to work and the left rear, driver side tire was completely flat. Thought the engine was shuttering...thank gosh it was just the tire. First time in ages I changed a flat. It was a nice refresher course. Probably a lot easier in my driveway than on the road somewhere. Nice thin flat piece of metal through the tire. Ordered a new stock OR tire for $220. Not sure if that's a good price or not.
    CusterFan likes this.
  20. Apr 13, 2022 at 12:47 PM
    Cricket-0
    Added the exhaust wrap, I have about a 1/2” between pipe and tire. I found out I suck at wrapping exhausts.
