oversize oil filter
Discussion in '4 Cylinder' started by 09sr5, May 22, 2013.
  1. May 22, 2013 at 8:26 PM
    09sr5
    09sr5 [OP] gonna be a long ride
    East Tennessee
    2009 sr5 2.7 4x4 AC
    265/75 AT3's on stock wheels. 5100's@1.75". Trail Gear sliders. Toytec AAL
    I have heard that some 4cyl owners use oil filters from a v6 or v8 Tacoma/ tundra because they are longer, ..are any of you guys? If so , what's the part number? Thanks
  2. May 22, 2013 at 8:32 PM
    09sr5
    East Tennessee
    2009 sr5 2.7 4x4 AC
    Yeah, it is fine for me too. A while back I was reading on this and I couldn't find it a sec ago. Something about it being the same price for more filtration because the filter was taller. I'll ask Toyota Saturday..I'm going to buy a box of OEM filters
  3. May 22, 2013 at 8:57 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  4. May 22, 2013 at 9:15 PM
    TRDSport10
    TRDSport10 Well-Known Member
    Rhode Island & Virginia
    '10 AC TRD Sport 4x4 - Silver
    TRD Exhaust, Tube Steps, Towing Hitch, Paint Protection Film, Bed Mat, Wheel Locks, Spare Tire Lock, First Aid Kit, Ashtray Cup, TRD Air Filter, TRD Oil Cap, TRD Radiator Cap, FJ TRD Hub Caps, FJ TRD Shift Knob, BackFlip F1, TSB Rear Springs, Coupe TRD Battery Hold Down Bar, KatzKin Leather Seats with W.E.T. Seat Heaters, WeatherTech: FloorLiners DigitalFit, Side Window Deflectors, ClearCover License, LampGard
  5. May 23, 2013 at 6:10 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Both the 90915-YZZD1 and the 90915-YZZD3 are listed for the 05+ 4cyl (2TR-FE). A few months ago when I bought my last oil filter from my local dealer they gave me the YZZD1. Yesterday, I went to buy another filter at the same dealer and they gave me a YZZD3. As mentioned, the YZZD3 is a larger filter, and I feel better running the larger filter at 5K oil change intervals. :cool:
  6. Jul 2, 2020 at 3:56 PM
    BillyWest12
    BillyWest12 Active Member
    2012 Blue Tacoma PreRunner Access Cab 4 cylinder
    2012 2.7L Tacoma Prerunner. I use a PL 20195 oil filter. A mid-line Purolator One oil filter good for 10,000 miles... I will change it before then. I had to remove 12mm bolt holding center brake line clamp for it to fit.
  7. Jul 2, 2020 at 7:02 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    we all know ' Size Matters ' !!!
    anyone know the ' micron filter spec '
    bypass psi matters
    the oil at 10300 wasnt dirty
    hadnt started to darken
    yet
    may have been filtering metal shavings from break in all along
    so if anyone has the specs moreso than just the size
    speak up
  8. Jul 8, 2020 at 10:15 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The filter for 2003 Mustang V6 and 1989 Aerostar V6 have the same threads, base gasket and bypass pressure as the spec'd filter for my 2006 2.7 but the can is about 1 inch longer. (I don't have the specs handy but I did the research and found the only difference is the length of the canister and amount of filter media.) Currently I'm running Motorcraft FL400S and WIX 51516. These are equivalent (in size) to the PL20195 above, but the PL is a high-end filter where the Motorcraft and WIX are considered standard replacement... high quality filters, but standard equipment category.
