Overland Torque Tune (OTT) by Overland Tailor
Discussion in 'Performance and Tuning' started by JustDSM, Mar 20, 2022.
  1. Oct 25, 2022 at 1:04 PM
    #621
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Using the TRD S/C Assembly, below are parts of the custom fit kit I'm building out. There's already a guy over in the tundra s/c thread on a maggy making 504whp with a similar setup. https://www.tundras.com/threads/general-supercharger-thread.85513/
  2. Oct 25, 2022 at 1:06 PM
    #622
    JustDSM
    JustDSM [OP] Oderint Dum Metuant
    Justin
    Ogden, UT
    2023 Ford Raptor
    I think you're going to do well. I was hoping you weren't under the impression the stock setup w/ stock pulley was going to get you to the big "5".:amen:
    scootter82 likes this.
  3. Oct 26, 2022 at 4:05 AM
    #623
    2quik4u
    2quik4u Member
    2019 Voodoo Blue TRD Pro
    Add a set of headers to that list. I had a supercharged Tundra prior to my Taco and it picked up a good amount of power going from the stock manifolds and an aftermarket catback to headers, high flow cats and dual 3'' exhaust.
    scootter82[QUOTED] likes this.
  4. Oct 26, 2022 at 10:30 PM
    #624
    erok81
    erok81 Well-Known Member
    Imposter
    This is a bit old but I didn’t see an answer the last few pages after it was asked.
    Does that have any impact? I know OVT didn’t. I’d imagine this shouldn’t either because wouldn’t the checksum also be affected by dealer updates?
  5. Oct 27, 2022 at 6:56 AM
    #625
    JustDSM
    Justin
    Ogden, UT
    2023 Ford Raptor
    The Calibration ID remains stock on our tunes. The EROM 3G S/C cals start with a “V” but these have been CARB approved with the Magnuson tune.
    The Cal ID would be the most identifiable change for a smog shop/dealer to detect a change to the ECU.
    The CVN is the give away. A stock tune or an approved tune will have a unique CVN for the data that composes that file. Any change to that calibration, even just a .1 degree change in ignition timing in a single cell for example, would generate a different check sum and subsequent CVN. There’s no getting around that.
    At this time all CA SMOG stations we are aware of are (if at all) looking at the Cal ID only. They do not appear to have the library of CVN’s for every Cal ID for every ECU from every manufacture available for implementation so it seems.
    It could be tomorrow, it could never happen. It’s not something we’re privy too. But we can certainly keep you posted if you stay in touch.
    As with all of the tuning we offer, you can always flash back to stock anytime you need too.
    TacoTime55, bulalo, rip ej1 and 2 others like this.
  6. Oct 31, 2022 at 9:55 AM
    #626
    Northshorepro
    Northshorepro Member
    British Columbia
    2018 black TRD Pro
    Lights bd s2 pro, 33s, kb voodoo rack, smitty built tent, raptor lights, kc cyclones in engine, sound proofed cabin, power tailgate lock, alpine entire upgrade, meso puddle pods, etc …
    Forgive me, but is there a vancouver/ north shore tuner avail for this in British Columbia?
    thanks
  7. Oct 31, 2022 at 9:57 AM
    #627
    RCTuningFL
    RCTuningFL OTT Florida Tuner
    RC Tuning FL
    Melbourne / Brevard County, FL
    2020 Tacoma TRD Pro @rctuningflgarage
    OTT + Magnuson Supercharger - 5.29s etc etc.
    JustDSM[OP] likes this.
  8. Oct 31, 2022 at 1:16 PM
    #628
    Northshorepro
    British Columbia
    2018 black TRD Pro
    Spedo adjusted for 33s in this tune also? Thanks again
  9. Nov 1, 2022 at 11:53 AM
    #629
    JustDSM
    Justin
    Ogden, UT
    2023 Ford Raptor
    The speedo is not controlled by the ECU in this application, so there is no way to adjust your speedometer through the ECU calibration. You'll need to use a Rough Country/Hypertech speedometer calibrator to make any corrections needed to your speedometer.
    However, we do make specific changes within the tune for gear and tire size run.
  10. Nov 7, 2022 at 4:08 AM
    #630
    CT_DC2
    CT_DC2 Taco_NotaPro
    @Taco_NotAPro
    LEGO
    I received the KDmaxx tune last year and had some throttle issues. It made my truck lurch forward a few times when I lifted off throttle. Similar to a stuck throttle cable/vac leak. Allan Hish, heard my feedback on the issue and was able to correct it with the OTT map.
    First impression: smoother reactive feel to the throttle while on or off the throttle. No weird power dip/like it was in the wrong lower gear when you let off throttle. I felt as if it was similar to my Lexus GS.
    Allan Hish- +1(732)890-8225
    He works within the North East Tri-state area. NY, NJ, and PA.
    He will ask you a set of questions to understand how you drive, and will match it with the throttle sensitivity. So be honest with him and you'll be happy with the results.
    - Cuong
  11. Nov 7, 2022 at 7:18 PM
    #631
    erok81
    Imposter
    So…I need to update my ECU to latest ECU ID (04B04). Other than going to the dealer is there a way to do this?
    I have VF Tuner. I swear I used to some sort of techstream but it’s been a few years and a couple laptops and I can’t remember. :help:
  12. Nov 7, 2022 at 7:48 PM
    #632
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yes, you use Techstream. Go over to this thread to update your ECU so we can keep this one clean.
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
    JustDSM[OP] and erok81[QUOTED] like this.
  13. Nov 9, 2022 at 8:45 PM
    #633
    junkyarddogg
    junkyarddogg Well-Known Member
    New Jersey
    2021 TRD Off Road
    Where can I get this tune in NJ?
  14. Nov 9, 2022 at 8:49 PM
    #634
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    '22 MGM DCLB TRD OR
  15. Nov 12, 2022 at 10:04 AM
    #635
    CavalryTRD
    CavalryTRD Well-Known Member
    Frankie
    Cavalry blue TRD
    Just got this done in Rock Hill South Carolina on my 19' 6sp manual. Big difference at take off. I can't speak to anything but that as I've only driven 1/4 tank of gas. So far no noticeable mileage change. But at idle after coming to a stop from the 1 hour+ drive home it was so quiet and smooth I thought I had already cut the engine off. I know these can be loud at idle so I was really surprised by this. I'll post an update as reading these comments helped me make the decision to try it. I still have a slight hesitation about 1,700rpm that I had which might be exacerbated because the throttle is more sensitive. But I granny shift like crazy and have it at lower rpm than necessary or practical to be honest.
    JustDSM[OP] and cemented like this.
  16. Nov 13, 2022 at 4:14 PM
    #636
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Do you mind sending me the contact of who did it for you. I have a 2.7 waiting for vf tuner to update for us 4cyl guys but i am in charlotte would be nice to have a contact for when an update drops
    CavalryTRD[QUOTED] likes this.
  17. Nov 13, 2022 at 4:48 PM
    #637
    CavalryTRD
    Frankie
    Cavalry blue TRD
    His name is Matt Cook. I found him on Facebook but his email is
    mc2tuningllc@gmail.com
    aturk likes this.
  18. Nov 13, 2022 at 4:51 PM
    #638
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I’m the Charlotte guy.
    2021 2.7L isn’t supported yet :(
    aturk, BortisYeltzen and CavalryTRD like this.
  19. Nov 13, 2022 at 4:52 PM
    #639
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    BortisYeltzen likes this.
  20. Nov 13, 2022 at 5:14 PM
    #640
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Allan also covers Delaware. There's a couple of us (if not more) that meet up near Wilmington for updates.
    CT_DC2[QUOTED] likes this.
