Overland Build on a Budget
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacosteveo32811, Jan 20, 2020.
  1. Jan 20, 2020 at 3:56 PM
    tacosteveo32811
    tacosteveo32811 [OP] Well-Known Member
    2009 Tacoma TRD Offroad
    I'm new to the Taco world and also new to the overlanding world. Theres not much in my area for any extreme overlanding so I would like to do a basic 2" lift, on a budget. What are your recommendations as to what i should go with for a proper setup? Keep in mind this is my daily driver. Also keep in mind I am a noob.
  2. Jan 20, 2020 at 3:58 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Have you tried searching for this answer yet?
    whatstcp, tacoma2g, honda50r and 2 others like this.
  3. Jan 20, 2020 at 4:02 PM
    doorsidedown
    doorsidedown Well-Known Member
    Hey Steve, there’s a thousand+ combos out there but here’s my .02 since you asked... and I have no idea how you actually use your truck... but keeping budget (and a basic build) in mind I’d go with bilstein 5100 shocks on all four corners, OME coil springs, a progressive (3 leaf) AAL, and a softopper for the bed.
    tacosteveo32811[OP] likes this.
  4. Jan 20, 2020 at 4:05 PM
    tacosteveo32811
    Man I've looked at so many things I dont know where to begin. Just want to get the right bang for my buck.
  5. Jan 20, 2020 at 4:07 PM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    You could buy a used 3rd Gen suspension then add a one inch lift to the front. AAL to the rear.
    I buy everything from Craigslist, Facebook or here. Some stuff black Friday. Just be patient.
  6. Jan 20, 2020 at 4:53 PM
    kfs90
    kfs90 Well-Known Member
    BR, LA
    2013 Prerunner V6
    This is my vote, too. You can probably do all this under $200 if you install yourself which is pretty easy. You will also have less sag with an AAL, and the 3rd gen front OR suspension is great for what you need.
  7. Jan 20, 2020 at 7:33 PM
    Bunkin
    Bunkin Member
    2007 Tacoma
    I’m in the same boat. Planning 5100 in the front for now, ome leaf pack in the rear if I find I need it. DIY bed rack and tent. That’s all I think I’m gonna be able to afford this year
  8. Jan 20, 2020 at 8:18 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Was gonna be my suggestion too...
    I just bought 3rd gen suspension (shocks, front and rear springs, UCA's) with ~15k on them for $100. Not a huge "upgrade" necessarily but for my truck that has 190k miles on it I just got 4 new shocks, 2 new ball joints and a few suspension bushings all for $100 and even got a little lift out of it. Truth be told the truck had a 1.5" spacer (3" lift) that I then replaced with some $20 3/8" spacers (3/4" lift) in the front so this setup actually lowered my truck from where it sat when I bought it - but that's what I wanted. It also has a 1" block in the rear but eventually I'll probably swap out to an ALL or new leaf pack. Just gotta wait for the right deal on craigslist :)
  9. Jan 20, 2020 at 8:23 PM
    GI_Taco
    GI_Taco Well-Known Member
    Halann
    Maryland
    2019 Quicksand DCSB TRD OR MT
    3rd gen off-road suspension with a 1/2in spacer up front. 1” block out back. Or go with an OME nitro charger setup with AAL.
  10. Jan 21, 2020 at 3:25 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
  11. Jan 21, 2020 at 4:00 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    My $0.02, invest more and do it once. If you plan on slowly building your truck as an offroad vehicle that's likely will be weight loaded for overlanding, go with a quality setup that will handle the weight along with offering a smooth ride. Front COs and a rear leaf pack would be the route I would choose. You need the proper height to run a larger tire setup along with the added weight from equipment and possibly sliders, bumpers,winch, etc..later down the road. A 3rd gen oem setup or just 5100s would not handle it.
  12. Jan 21, 2020 at 4:28 AM
    tacosteveo32811
    Appreciate all the feedback fellas. Hopefully I can get the right setup together. Since this is my first Taco I really dont want to go too extreme, especially with the mileage it has now. Get this paid off in about 3 years or less and then move up to a 3rd gen with less miles. I work at a steel mill in Virginia working 48 hour shifts so I should be able to accomplish it financially just have to plan the installs during my 4 days off in between rotations without taking the truck off the road and not driveable for a day or so.
  13. Jan 21, 2020 at 5:14 AM
    grrck
    grrck Reluctant Wizard
    Garrick
    Woodbridge, VA
    2015 Super White SR 2.7 5SPD 4WD
    Question is, what does anyone "need" in order to "overland"?
    Most of the fancy kit you see people loading their trucks down with is unnecessary. All you "need" is decent tires, some form of simple recovery in case you get in over you head, and storage to keep all your crap in. RTT's, armor, winches, big lifts, are all extra that I won't fault anyone for wanting, but remain mostly overkill.
    If you're not rock crawling and mudding, a stock ride height 4x4 Taco with decent tires will go anywhere you will need/want in a vehicle you are still making payments on. Remember, this craze was started by people looking at Land Cruisers and Defenders with zero upgrades rolling around Africa with a couple of Jerry cans for weeks on end. As capable as those vehicles are stock, are they that much better than a Tacoma at getting around?
    It's a truck, throw a tent and sleeping bag in the bed, load up your cooler, and go for a spin out in the George Washington and Jefferson National Forests (since your in VA, I live in NoVA). Bring a buddy with another truck, hang some hammocks in between them and have a blast. Do that a few times and figure out what YOU need and were missing during the trip, and upgrade accordingly.
  14. Jan 21, 2020 at 5:40 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    How the hell do you work 48 hours straight??
  15. Jan 21, 2020 at 7:04 AM
    kfs90
    BR, LA
    2013 Prerunner V6
    This and only this.
  16. Jan 21, 2020 at 7:05 AM
    tacosteveo32811
    We work 4 twelve hour days then off 4 days straight then 4 twelve hour nights then off 4 days straight and so on.
  17. Jan 21, 2020 at 7:07 AM
    tacosteveo32811
    Hence me saying I am a noob and I am looking for recommendations for what I should get. Mainly all I really want to do is lift it, throw on some good wheels and tires, get a rack and roof top tent and have a decent recovery system. I was just fishing for the varieties of suggestions from everyone here lol.
  18. Jan 21, 2020 at 7:26 AM
    grrck
    Garrick
    Woodbridge, VA
    Plus size your tires with something meatier, get a cap or cover to keep your gear safe and out of the elements (plus a nice option to sleep under), and find someone else with a roof top tent that you can try out for a few trips. I find RTT's to be a pain in the ass, and the only way I would rock one is if I built a dedicated trailer to mount it on. The suggestions for a cheap lift that were listed above are great, I've been contemplating doing the 5100's and a AAL myself, but I really like my ride height for daily driving where it is now with the slightly taller tires. For recovery, try some recover straps and ratchets, and practice with them so you know how to use them when the need arises. Be safe.
  19. Jan 21, 2020 at 9:31 AM
    clenkeit
    Colin
    Lakewood, CA
    Like the OP said I'd start simple and go from there. No sense in spending thousands only to find you wish you would have done it differently. Upgraded tires would be a great idea, a little lift isn't a bad idea. Then some basic tools, perhaps a small portable compressor, a come-along. I'd definitely start with a regular tent rather than RTT. Those things are expensive. I personally haven't used one but I don't like the idea that once you're setup you would have to breakdown and pack up if you want to use the truck. For my uses I'd rather make camp then hop in the truck to go explore. Seems that with an RTT once you're setup you really are limited to walking wherever you want to go unless you pack up the RTT.
  20. Jan 23, 2020 at 12:31 PM
    PrinceDrammy
    PrinceDrammy Well-Known Member
