Overheating - which Rockauto radiator?
Discussion in '1st Gen. Tacomas (1995-2004)' started by greenseaman, Feb 14, 2018.
  1. Feb 14, 2018 at 1:50 AM
    greenseaman
    greenseaman [OP] Well-Known Member
    Scott
    Conway, SC
    2003 Tacoma Ltd Dbl Cab
    My 2003 Tacoma almost overheated on me in the drive thru but my ultragauge alarmed me when it got to 230 degrees. It usually stays at 203. I turned the heat on and pulled out of the line and it immediately cooled down, but I was able to add almost a gallon of water to the radiator and overflow tank. I haven’t seen any obvious leaks except maybe around the top of the radiator. Do you think I need a new radiator? If a new one is needed, Rockauto has them half the price of the local auto parts store for a standard one. Would you trust that one? Which one should I pick for my 3.4 l double cab limited? What do you guys think? Thanks in advance!
  2. Feb 14, 2018 at 4:19 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Your radiator is fine. Get a new fan clutch.
  3. Feb 14, 2018 at 5:20 AM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    How many miles? They are bad about the plastic cracking on top of radiator. I would prob be proactive and get a new radiator anyways. There are a few tests you can do for the fan clutch. Someone else can give input as I am not familiar with it...
  4. Feb 14, 2018 at 6:25 AM
    tony2018
    tony2018 Well-Known Member
    I would use this opport to buy an aluminum radiator. We had a thread about that a couple days/weeks ago.
  5. Feb 14, 2018 at 6:33 AM
    greenseaman
    Scott
    Conway, SC
    I’ll check out the aluminum radiator thread! Thanks!
  6. Feb 14, 2018 at 6:35 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've been running rock auto rads for years.
    The only issue is the shipper can damage them. I had to send a couple back.
  7. Feb 14, 2018 at 7:26 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Like a lot of TW members, mine started leaking from the top. There was a crack right behind the radiator fill cap.
    Ordered a new radiator from Gary (Camelback Toyota)
  8. Feb 14, 2018 at 7:26 AM
    Indy
    Indy Master of all I survey.
    Is the radiator leaking?
  9. Feb 14, 2018 at 7:54 AM
    greenseaman
    Scott
    Conway, SC
    I think there is some leakage around the seam on the top. The truck has about 230,000 miles on it!
  10. Feb 14, 2018 at 7:55 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I got a denso from rockauto a year ago and it has been fine. Paid like 129$ shipped for it.
  11. Feb 14, 2018 at 8:26 AM
    tony2018
  12. Feb 14, 2018 at 10:14 AM
    Glamisman
    Glamisman Well-Known Member
    as a bit of unsolicited advice... put a pressure tester on it after you replace the radiator and let it sit for a while. I will bet that most of the hoses are original, especially the pain in the rear ones off of the IAC valve. Little leaks just might pop up and I am sure that you want to fix it the first time and not have to keep going back. Some radiators do not come with caps, get a new one if it doesnt.
  13. Feb 14, 2018 at 12:52 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Champion Tacoma radiator.....
    ToyRyd04 likes this.
  14. Feb 14, 2018 at 4:34 PM
    greenseaman
    Scott
    Conway, SC
    I ordered one!! We’ll see how it does!
  15. Feb 14, 2018 at 4:35 PM
    greenseaman
    Scott
    Conway, SC
    I’ll definitely check the hoses. Thanks for th input!
  16. Feb 14, 2018 at 4:39 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Buy a new radiator, hoses, t stat, fan clutch
    When was the water pump done ?
  17. Feb 14, 2018 at 4:57 PM
    greenseaman
    Scott
    Conway, SC
    The water pump and timing belt was done at about 190000. About 40000 miles ago
  18. Feb 14, 2018 at 5:09 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    You need to pressure test the cooling system. The water doesn't simply evaporate. If the radiator has a crack or a leak it would almost certainly be noticeable once the system was under pressure. Try a different radiator cap since they are cheap and pressure test the system before you start throwing money away.
    For the record my truck runs between 184-190 typically and I can see some slight discoloration at the top of the radiator around the cap.
  19. Feb 14, 2018 at 5:48 PM
    greenseaman
    Scott
    Conway, SC
    The radiator is leaking around the plastic top on the seam. I definitely do not want to just throw money at it!!
  20. Feb 14, 2018 at 6:19 PM
    tony2018
    I think what everyone wants you to do is confirm that you don't have a blown headgasket. Putting in another radiator might not solve your overheating problem. Thats all.
    fortiz619 and Jackstraw13 like this.
