Overheating only when idling?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1998tacoma4x4, Oct 2, 2013.
  1. Oct 2, 2013 at 7:15 PM
    1998tacoma4x4
    1998tacoma4x4 [OP] Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
    When I am cruising down the road everything is normal, temp gauge is right in the middle but when i stop and idle at a light the temp gauge starts moving up quite quickly, within 30 seconds to a minute its nearing the red zone. This just started the other day out of no where. Radiator is a year old and thermostat and hoses too. Coolant looks good, no obvious leaks, so what could it be? Thanks!
  2. Oct 2, 2013 at 7:41 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Fan clutch
  3. Oct 3, 2013 at 12:47 AM
    runyun
    runyun Well-Known Member
    Irving/N. Grand Prairie
    02 Silver TRD DC
    ^ agreed.
    Pop your hood up and check out your fan (spinning fast, blowing good amount of air)
    When you're moving, air is being forced into your engine bay..thus cooling down your motor.
    But when you slow down (ie stop light, in traffic, etc) ~ there's no air being forced onto your engine, thus making it overheat.
    So thats the job of your fan
    (but, as always, there could be other problems..but that would be my best guess as well)
  4. Oct 3, 2013 at 8:40 AM
    1998tacoma4x4
    Orange County
    My thoughts too were on the fan clutch, but I've popped the hood to check the hoses while it was running and the fan was spinning. I had to avoid hitting my arm on the fan while i checked the lower radiator hose. Any other ideas?
  5. Oct 3, 2013 at 7:02 PM
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    Bad thermostat or install and or water pump bad? Is radiator new or used? Fins clean? Coolant topped off? Radiator cap good?
    I had an electric fan on my 02 that I would manually turn on/off. When not moving at idle fan off it would take a while for it to get hot enough to warrant turning it on. Definitely more than 30 sec to one min...
  6. Oct 3, 2013 at 7:36 PM
    Tmiller3063
    Tmiller3063 Active Member
    04 Prerunner Limited
    I would say fan clutch. Just because it's spinning does not mean the clutch is not bad and not allowing it to spin faster and bring in more air.
  7. Oct 3, 2013 at 9:23 PM
    2003TACO
    2003TACO Member
    Los Angeles
    03 Toyota tacoma double cab 2.7L
    My dads truck had a similar problem to yours. We installed a rebuilt engine V6 3vze purchased from Nippon motors into his 1990 toyota pickup with a new radiator and water pump and would overheat during idle. So we decided to play around with the idle (~8degrees) and all of a sudden the temp dropped below the half way mark (40%). We haven't had any problems ever since. This may not be the case for your truck, but worth a try.
  8. Oct 4, 2013 at 11:45 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    With the engine off, try to spin the fan with your hand. Is there any resistance or does it spin for 1 or 2 revolution?
    When the engine warms up, are both the upper and lower rad. hoses warm?
  9. Aug 20, 2014 at 11:30 PM
    coolbreeze
    coolbreeze New Member
    the OC
    2005 Tacoma 4x4
    I'm having this same problem. If I'm at a stop, I have to put it in neutral/park and rev it up above 1200 rpm to keep it cool. If its under 1200 rpm's even when moving then it will overheat. Also, this will only occur on very hot days when temps are above 90 degrees or on long trips. Any suggestions?
    Ooppss. Sorry. Wrong forum. This should've been in 2nd gen as my truck is a 2005.
  10. Aug 20, 2014 at 11:41 PM
    MoonCrawler
    MoonCrawler Well-Known Member
    Sacramento, CA
    2003 Tacoma V6 4x4 TRD
    that also sounds like a fan clutch. the fan is belt driven. but if the clutch is bad it slips even though the fan is trying to turn it. you have to rev your engine up, because only at those higher rpm's is there enough belt spin to get the fan moving enough to cool the system.
    you could also check your water pump. it is belt driven too.
    but whatever is failing in your truck is belt driven, hence the higher rpm's bringing it back to normal.
  11. Aug 20, 2014 at 11:43 PM
    MoonCrawler
    Sacramento, CA
    if the fan clutch is not working, when you stop at a light, the engine heat just collects under the hood. there is no fan to pull air through the radiator and cool it.
    when you are driving there is constant air through the radiator cooling it.
    the fan is supposed to come on at idle, when it's hot enough.
  12. Aug 21, 2014 at 6:28 AM
    BamaToy1997
    Bill
    Navarre, FL
    Along with checking the fan clutch, I would check coolant level in the radiator, and check the water pump. Low coolant levels and bad water pumps can cause the exact same issue. It seems to cool fine at higher speeds because with the engine running at a higher RPM, it will flow coolant better than at idle. Definitely check out the fan clutch though!
