Overhead Garage Door Opener Button
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BassFisher887, Apr 16, 2023.
  1. Apr 16, 2023 at 6:00 PM
    BassFisher887
    BassFisher887 [OP] Well-Known Member
    Near Chadds Ford PA
    2023 Tacoma TRD OR AC
    Inspired by the threads on installing an overhead garage door button, I decided to give it a go for my 2023 Tacoma OR.
    I used the following parts for the install.
    After removing the overhead console from the truck, the next step was to create the electrical assembly. First the FOB was disassembled. Using a soldering iron and solder sucker, I removed the three push buttons and battery connections from the PCB. The wiring harness from the AOB button was solder in the #1 button spot and the battery holder was soldered to the PCB. For my FOB, the negative lead from the battery had to be soldered onto the PCB in two places as the original battery terminal I had removed had created a bridge between two different contacts on the PCB.
    I used large clear shrink tubing to wrap the FOB, installed the battery, and connected the AOB switch using the connector I had soldered to the PCB. The assembly was taken to the garage and paired with the opener. At first the + and - battery leads were swapped, so after a quick fix with the soldering iron, back out to the garage and success. The green connector is for the button, and the white connector goes with the overhead harness to provide the illumination voltage for the button.
    The locker button and single button panel was removed. The two button panel was installed in the overhead unit, the locker button reinstalled, the FOB and battery holder were mounted with doubled sided tape to the top side of the console, the harness was connected, and the cables were routed as neatly as I could achieve. I secured the two wire connector from the harness with some doubled sided tape to avoid it rattling sometime down the road. The unit was now ready to be reinstalled in the truck.
    The button operates the garage door and illuminates with the rest of the buttons. The only downside is that when the battery dies, I'll need to pull the overhead unit down to replace it. But considering that the battery typically lasts 2 years or more, I don't expect that to happen too often.
    I'm happy with the final result and the fact that there is no longer a visor mounted FOB.
  2. Apr 16, 2023 at 6:03 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Nice work, clean install, I’d just be worried that it doesn’t turn off with the truck, allowing access to your garage/house. I guess if you never leave it out, no big deal, just don’t forget.
    BassFisher887[OP] and Gatafly like this.
  3. Apr 17, 2023 at 3:02 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Nice install. I looked at doing this a few years back in 2018 when I got my Tacoma. I did a new mirror from Bob's Mirrors because I have 3 doors to control. Nice install OP.
    BassFisher887[OP] likes this.
  4. Apr 17, 2023 at 3:07 AM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    That is pretty nice! Next time you drop the console you could wire it up instead of using the battery. That way you don't have to do it again.
  5. Apr 17, 2023 at 7:22 PM
    BassFisher887
    Near Chadds Ford PA
    Agreed. I would need a 12v to 3v convertor, something like this one, 12V to 3V Step-Down Converter. I would also need to find a 12V source in the console area. Though I'm sure with some probing about I'd be able to track on down.
    Regarding the security concerns, I appreciate the advice. I do keep my truck in the garage, so I'm good there. But it got me to thinking about the homelink enabled mirrors. I tested the one in my wife's Highlander and it operated the garage door regardless if the vehicle was running or not. Something to be aware of if you have that feature for operating a garage door.
    Chew likes this.
