Overfilled Oil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CenterKnurl, Feb 12, 2022.
  1. Feb 12, 2022 at 7:19 AM
    CenterKnurl
    CenterKnurl [OP] Well-Known Member
    Did my first DIY oil change. Drained the oil, drained filter, changed filter, put drain plug back in, added 6.2 quarts fresh oil. From what I've read online, 6.2 may actually be too much. I checked the dipstick several times but the stick is super annoying to use. I can't get a good read on it. Should I drain a few ounces out just to be safe?
  2. Feb 12, 2022 at 7:24 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Take your dipstick out. Get fine sandpaper, like 600 grit. Sand the stick from the tip to the area that shows oil level. All you have to do is scuff it really.
    Then, wipe off the stick and put it back and check your oil! You will be able to see the level clearly as the stick will not be too slick.
  3. Feb 12, 2022 at 7:25 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Warm engine. Let it sit 5 minutes. Pull stick and wipe. Reinsert and pull out. Lay sideways on blue or other paper towel. You will be able to see the oil mark on the paper towel next the unmoved dip stick.
    Hope this helps on your gen 3. I use this method on three other rigs at new oil change include my 2014.
    ETA: I like the above and will experiment with this next time.
  4. Feb 12, 2022 at 7:28 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I got a used 21 TRD off road with 3K miles a few days ago. I checked all fluids at dealer and of course the dip stick was hard to read. As soon as I got home I scuffed the stick. Works as intended. Takes 30 seconds.
  5. Feb 12, 2022 at 7:54 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Didnt have anything close to 600 handy so I did this with a green Scotchbrite pad . Then wiped the entire stick clean. Works as it should now.
  6. Feb 12, 2022 at 8:01 AM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    What's with all the dipstick talk? The engine has a very specific amount of oil it needs (6.2 qt as per owners manual).
    You put the correct amount in.
    kahanabob likes this.
  7. Feb 12, 2022 at 8:07 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    That's the capacity but when you drain there is always oil left in that you can't get out.
  8. Feb 12, 2022 at 8:26 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Uh oh, your first DIY oil change and then trouble reading the dipstick...is there any way possible that you drained tranny fluid instead? It's happened before..
  9. Feb 12, 2022 at 8:35 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    There's no need to drain any out. While it's true that overfilling can be bad, that amount would be in quarts not in fractions of a quart. You don't need to be that exacting. There's a reason there's something like a quart and a half difference between the "add" and "full" marks on the stick.
    And before someone freaks out, no, I wouldn't let my oil level get anywhere near the add mark before topping it off.:rolleyes:
    Edit: "Freaks out", does anyone use that expression anymore? Did I just date myself?:anonymous:
  10. Feb 12, 2022 at 8:40 AM
    Mhanz
    Mhanz Member
    Ruined...must sell as soon as possible. Preferably at 50% market value as the engine is ruined. By the way I buy ruined vehicles.
    Squirt, Gen2 Man, ULURU and 4 others like this.
  11. Feb 17, 2022 at 11:05 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    To get an accurate reading pull the dipstick and wipe it clean. Wait a few minutes, then insert it all the way down. Pull it back out, as straight as you can.
    Lay the dipstick flat on a paper towel and drag it towards you. It will leave oil residue on the paper towel (or toilet paper).
    This will indicate how far up the dipstick the oil is.
    Make sure you wipe the dipstick clean before re-inserting it (no paper towel residue).
  12. Feb 17, 2022 at 11:08 AM
    Mhanz
    Mhanz Member
  13. Feb 17, 2022 at 11:09 AM
    Mhanz
    Mhanz Member
    And that sounds like a PIA. Why not just pull it out....look at it, if it's close.... Good enough. A dipstick is not a precise measuring tool.
    usmc2msu and Blockhead like this.
  14. Feb 17, 2022 at 11:17 AM
    SSMTRDOR
    2020 TRD OR 4X4
    Read OP's original post. With clean oil it is hard to see the level. I have the same issue after an oil change.
    Lt. Dangle likes this.
  15. Feb 17, 2022 at 11:19 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    2 oz overfilled!!!! Everyone assume the crash position!
    TN1000, rhdsjhn, TacoPandaTRD and 9 others like this.
  16. Feb 17, 2022 at 11:34 AM
    Mhanz
    Mhanz Member
    I did. It's not rocket science. Yes it's sometimes difficult to see. Move it around in the light. If all else fails stick it in your mouth and if it tastes like oil then GTG.
  17. Feb 17, 2022 at 11:35 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    With a new engine yes. But when changing oil you never get all of the old oil out. If it calls for 6.2 quarts, I'd put in 6. Start the engine and drive it for a short distance, stop engine and give the oil a few minutes to settle then recheck. You have 2 lines on your dipstick. If the oil level is anywhere between those marks, you're good-to-go.
    No reason to add a partial quart. If 6 quarts is at, or below the minimum mark then add a full quart, that will get you up to the maximum level. If anywhere in between drive it and wait until it reaches the minimum level then add another full quart.
    If you're over the maximum level mark on the dipstick you might want to consider draining some out. It really depends on how much you're over. If less than 1/8" I'd not worry about it. If the oil on the dipstick is 1/4" or more above the max fill line I'd drain some out.
    Lenny Dykstradamus and Blockhead like this.
  18. Feb 17, 2022 at 11:40 AM
    Chukar Chaser
    Chukar Chaser Well-Known Member
    Pete
    So Cal
    2019 TRD OR 4X4 DCLB
    0.2 quarts is ~6 oz. I am pretty sure if you're +/- 6oz out of a total of ~6 quarts you're safe.
    soysauce021 likes this.
  19. Feb 17, 2022 at 12:14 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Try this. Scuff the stick as recommended above. Pull the stick out at night and leave it out all night. That lets the oil in the dipstick tube drain completely. That way it doesn't smear the meniscus and skew the stick reading the next morning. I've owned vehicles since 1972. This dipstick arrangement is the worst among all of them. Why, back in the old days when I was a kid, we pulled the dipstick ONE TIME...and by God, THAT was the reading. You hear me?! None of this finagling around, checking and re-checking oil levels like on these new fancy-schmancy dip sticks. No we didn't! And oil wudn't clear either! It was amber, and it looked like...oil. And we didn't have no fancy phone apps at $2.99/month to check our oil for us while we played Grand Theft Minecraft or whatever like you young whipper-snappers do today. No sir. We did it the hard way. The way it was meant to be! We did it ourselves! With a red shop rag that shoulda' been thrown away last week! Can you believe that?! And you know WHUT? WE LIKED IT THAT WAY! And then we'd go poke ourselves in the eye with a sharp stick! And you know whut? We liked that TOO!
    And our oil only had one number on it. Becuz one number WAS ENOUGH!
    And back then, sex was safe and racing was dangerous. And your grandma DAMN SURE LIKED IT THAT WAY!
    Bluebros, TexasTacoLT and rkd1119 like this.
  20. Feb 17, 2022 at 12:47 PM
    SSMTRDOR
    2020 TRD OR 4X4
    I'm sure you are used to sticking things in your mouth. But that doesn't help OP.
