Over torqued oil canister
Discussion in '3rd Gen. Tacomas (2016-2023)' started by manfred twd, Nov 7, 2021.
  1. Nov 7, 2021 at 10:50 AM
    manfred twd
    manfred twd [OP] Active Member
    mike
    2021 trd takoma
    Anyone had a canister overtorqed at the dealership?
    I’m getting ready to do my first diy oil change and have seen some horror stories on YouTube
    I don’t want to go aluminum because I’d rather the plastic threads mess up than the ones in the block
    Thanks in advance
  2. Nov 7, 2021 at 10:56 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    If its over torqued, take it back to the dealer that did the oil change last and have them deal with it.
    Skydvrr likes this.
  3. Nov 7, 2021 at 10:58 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Then get a spare before you try and remove so your prepared/worst case. I’ve not had 1 issue with the plastic filter (but I’ve done all the changes myself AND I’ve torqued to spec each part). I also bought the aluminum as a spare because of the “horror” stories here but like I said never needed it
  4. Nov 7, 2021 at 11:04 AM
    manfred twd
    mike
    2021 trd takoma
    I'm trying to avoid the dealership as I just don't trust them.
    If I take it back to them because I can't remove it I'll be in the same spot next change'
    I bought the newest Motivx tool to remove it, doesn't have those fingers like the older model tool'
    I guess the old tool had slots rather than fingers.
    DAS Taco likes this.
  5. Nov 7, 2021 at 11:11 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Get a better oil wrench and get familiar how to set it on the housing. It will give some resistance at first (even if it was torque to specs), but comes off easy.
  6. Nov 7, 2021 at 11:14 AM
    manfred twd
    mike
    2021 trd takoma
  7. Nov 7, 2021 at 11:43 AM
    Provist
    Provist Well-Known Member
    2020-TRD-OR-4X4-AT-DCSB-QS
    Get the Lexus metal housing, 18'' or 24'' breaker bar and a metal removal tool. Makes it a joke.
    Never brought to a dealership.
    I always hand tighten with a 9'' or 12'' ratchet, just snug. Kinda of like an old spin on oil filter but a bit more :)
    Never overdo it, not the kind of stripping I want to see.
    Check after a drive for leaks, you good for 6 months.
  8. Nov 7, 2021 at 11:45 AM
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    Check to see if you can get the filter off before you drain the oil. That way if its stuck on you didn’t waste time and money draining the oil then refilling so you can drive somewhere to get it un-stuck
    outdoor frenzy and Junkhead like this.
  9. Nov 7, 2021 at 5:24 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Same here, except I use each filter holder, the plastic and aluminum alternately. As soon as I have removed the filter I have the other all prepped with the new filter and put it in and leave the cleaning for after I'm done changing the oil. It is a little thing but makes life a bit easier.
  10. Nov 7, 2021 at 5:44 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    OTT Tune, LED HLs&Fogs,TRDSkid, TalonCAT
    I bought this filter wrench:
    https://www.amazon.com/Capri-Tools-...t=&hvlocphy=9007492&hvtargid=pla-568238568630
    I have a Feb 2022 appointment at the dealership in Maryland I bought my TRD Sport from in Easton for 10K mile maintenance. My first experience was at a dealership here in Delaware and they did not resolve my concerns about the quality of work (over-torqued bolts and careless workmanship) even after speaking with the Service Manager.
    I'll be sure to brief the Service Manager in Maryland about my previous experience and make sure the bolts are not over-torqued and that I will be inspecting area worked prior to my departure.
    I'll have questions concerning the plastic filter and if it was over-torqued during removal.
    Ed
  11. Nov 7, 2021 at 9:20 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Same deal with the differentials, gotta make sure fill plug can be loosened first.
  12. Nov 7, 2021 at 9:22 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I am sure there are quite a few people out there that learned this the hard way, lol.
    Junkhead[QUOTED] and Bleep100 like this.
  13. Nov 7, 2021 at 9:28 PM
    Bishop84
    Bishop84 Well-Known Member
    Seriously? It's not that common. Don't plan for a chance of failure. Just freaking do it.
    I have to break one plastic cap off every 2 years, and I do hundreds of oil changes.
    Kev250R, skiploder, Sharpish and 2 others like this.
  14. Nov 7, 2021 at 9:37 PM
    theluharlifestyle
    theluharlifestyle Well-Known Member
    Parth
    SoCal
    2019 DCSB TRD OR
    I just changed my oil and broke my cap. Bought another one from the dealer for a pretty penny of 62$. Do yourself a favor and get a spare beforehand from Amazon and save some potential money
    Taco_mike73 likes this.
  15. Nov 7, 2021 at 9:47 PM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    On my previous 4runner the dealer overtorqued the cap enough to warp the plastic. (I think they used a impacted and fucking sent it) When I changed my own oil I had to beat the cap tool on and take it off then had to beat the cap out to get it off.
    Pretty upset tbh, however I was replacing it with an aluminum one that change so I had a new cap already.
    DAS Taco and theluharlifestyle like this.
  16. Nov 7, 2021 at 10:17 PM
    theluharlifestyle
    Parth
    SoCal
    2019 DCSB TRD OR
    Yeah, aluminum seems like the way to go. If I didn’t need the truck up and running that day I would have waited a day and had one shipped to me
  17. Nov 7, 2021 at 10:28 PM
    3JOH22A
    3JOH22A Toyota Gigolo
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The seal drag is pretty heavy from the factory. Mine has never been serviced by a dealer. I've done 6 oil changes myself and each time it takes a 17" breaker bar to loosen. Reinstalling the cap takes a 8" ratchet all the way until the cap flange meets the housing lip.
  18. Nov 8, 2021 at 3:29 AM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    I changed my oil last week. The change before that was at the dealer. And yes my filter cap was stupid tight. Like it twisted a little and the tool was stuck to it. I had to use a breaker bar to get it loose. Probably replace it next change.
  19. Nov 8, 2021 at 3:51 AM
    texas angler
    texas angler Well-Known Member
    Texas Hill Country
    20 OR
    Great post OP. I'm the only one to have changed oil/filter in my truck. Last oil change I could not get the damn metal piece at bottom to insert the Motivex tube to drain oil from filter. Ended up taking the entire filter housing off and oil splashed everywhere. Even with the housing off I could not budge the stupid metal piece....vice is no where to found in my shop. Stupid me. How the hell could that thing get so tight?
    You folks have this oil housing part number handy? Or the aluminum one mentioned in the post? Thank you
  20. Nov 8, 2021 at 4:34 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Also helps a bit with cooling the oil!
