Outer tread on front tire wearing out...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by forana, Feb 28, 2018.
  1. Feb 28, 2018 at 11:09 AM
    forana
    forana [OP] Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Hi All, yesterday I noticed that the outer tread on my front passenger tire is wearing out faster than the inside. All other tires look fine. I get alignment done 1 or 2 times a year, I think last alignment was 9 months ago.
    Is this just an alignment issue or is it something else?
  2. Feb 28, 2018 at 11:42 AM
    CaliforniaTacoTuesday
    CaliforniaTacoTuesday Well-Known Member
    How drastic of a difference is it? Seems like you would notice some sort of wobble when driving.
    Definitely sounds like an alignment problem.
  3. Feb 28, 2018 at 11:44 AM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Have the alignment checked. If it’s correct then it’s a defective tire. A steel band proably broke
  4. Feb 28, 2018 at 11:46 AM
    forana
    Kaneohe, Hawaii
    I'll take a pic when I get a chance.
  5. Feb 28, 2018 at 1:31 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Either too much toe or too much positive camber.
  6. Feb 28, 2018 at 1:47 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Remember, you can wipe out a fresh alignment on the way out of the shop if you hit something big enough. I'd get the alignment - and all front end components - checked ASAP.
  7. Feb 28, 2018 at 1:49 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    That part of the tire normally wears faster. Most people take corners to the left faster than to the right because they can see better. This wears out the outside of the right front tire faster. This is why we rotate. But without a pic to see just how much more wear it is hard to say.
  8. Feb 28, 2018 at 2:18 PM
    Too Stroked
    Tom
    I don't quite know how to say this, but you must be kidding.
  9. Feb 28, 2018 at 4:26 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Most of time if you have excessive wear on outside of tire. Problem is in alignment, inside wear is problem with parts with excessive wear.
  10. Feb 28, 2018 at 4:58 PM
    Unless OP is a professsional Tacoma drifter that specializes in left turn drifting, I’m calling BS on that one. If that has any truth to it, the variance between the two front tires of the average driver would be so negligible that I doubt it’d even be visible to the naked eye.
    The fact that you’d point to something like that over a simple alignment issue is crazy.
    Do you have any sources on that claim?
    2016Tacoman likes this.
  11. Mar 1, 2018 at 1:22 PM
    forana
    Kaneohe, Hawaii
    I do not drift with my truck.
    GaryLaurenLogan and ChadsPride like this.
  12. Mar 1, 2018 at 1:47 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Looks like your toe is off or your frame may be bent?
    gunn_runner likes this.
  13. Mar 1, 2018 at 1:48 PM
    forana
    Kaneohe, Hawaii
    I doubt a bent frame, truck is babied
  14. Mar 1, 2018 at 2:24 PM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    Is that your normal parking place? Looks like an extremely abrasive surface. I suspect that you are left turning form the street on to this driveway a lot and the tire is getting ground down? Do you turn you steering wheel before the truck is moving? This will also grind/wear the tire. Just a wild guess since that is not normal toe in or off camber wear.
  15. Mar 1, 2018 at 2:31 PM
    forana
    Kaneohe, Hawaii
    I do park on a curb at home. I was thinking I should make sure I park on the flat part. I initially ruled this our because the rear tire is totally fine. My last set of tires never had this issue.
    I'll rotate and align and see if it goes away.
  16. Mar 1, 2018 at 3:10 PM
    Too Stroked
    Tom
    Based on that wear pattern, I'd get the alignment checked. Based on the pictures, I'd also check your inflation pressure because based on the sidewall bulge, it could be low. Remember though, even if you find the cause and fix it, that wear pattern is permanent. (Some people incorrectly think fixing an alignment issue will fix a tire wear issue. All it will do is prevent it from getting worse.)
  17. Mar 1, 2018 at 3:13 PM
    Too Stroked
    Tom
    Turning the steering wheel when a vehicle is not moving will cause (almost insignificant) wear in one spot - not around the whole circumference of the tire.
  18. Mar 1, 2018 at 3:38 PM
    forana
    Kaneohe, Hawaii
    Thanks!
  19. Mar 1, 2018 at 4:04 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Did your alignment shop change with the new tires?
    Not all shops do alignments properly. I’m no expert but having a old school spring shop doing my alignments yielded awesome tire wear. Tire kingdom/ntb now well I could see the outsides of both fronts wearing more than the inners. Actually have this now I should get an alignment soon. I rotate swap wheels fairly often seems to help.
  20. Mar 1, 2018 at 4:10 PM
    forana
    Kaneohe, Hawaii
    The alignment shop did not do the tires. I have the lifetime alignment from firestone, which is awesome, but they do a terrible job sometimes. Like telling me they rotated the tires when they clearly didn't. Then when they rotate the tires they make no effort to realign until I asked about it. They clearly knew they had to do alignment again after rotating the tires but tried to sneak one by me. But, it's free. I try to align and rotate often to offset the poor service. So like you, I'm over due to do my truck.
    Jeffch likes this.
