Outer tie rod end replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Jul 10, 2022.
  1. Jul 10, 2022 at 8:08 AM
    OffroadToy
    OffroadToy [OP] old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Got torn boots and need to replace the outer tie rod ends. Got any tips other than counting the turns from the jam nut when backing off the rod? Also, are they identical parts for each side or do i need to order a left/right? Thinking about going with OEM... your thoughts?
  2. Jul 10, 2022 at 8:15 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Soak the suckers in penetrating oil.
    OffroadToy[OP] likes this.
  3. Jul 10, 2022 at 9:01 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Counting turns will get you close but you should still get an alignment when you're done
  4. Jul 10, 2022 at 9:09 AM
    avery0829
    avery0829 Well-Known Member
    Western Washington
    2005 Tacoma DCLB Sport
    Bilstein 5100, Trail edition wheels, 265/70/17 Falkens
    Depending on your mileage, I'd consider changing the inner tie rods as well.
    https://www.youtube.com/watch?v=YcydKXdydAA
    I bought Moog inner and outer tie rods from Rockauto. They appear to be quality parts and have a grease zerk on them.
    My originals lasted 180k so if the Moogs last half or more, I'd be happy.
  5. Jul 10, 2022 at 10:08 AM
    OffroadToy
    Just 33,340 miles...
  6. Jul 10, 2022 at 10:09 AM
    OffroadToy
    Will do... Thanks. :thumbsup:
  7. Jul 10, 2022 at 7:05 PM
    avery0829
    Western Washington
    In that case, Id just do the out and call it a day :thumbsup:
  8. Jul 10, 2022 at 10:42 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    count the turns, measure the front/rear tire spacing using tape measure, do the chalk test etc. All that if you're too cheap to just get an alignment. I trust a digital guy over my old eyeballs, the money you'll save replacing the tie rod will be well worth the peace of mind for a computurized alignment.
  9. Jul 10, 2022 at 10:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    And shake those inners real good when you have them disconnected. That's the best time to check if they're loose
    OffroadToy[OP] and 6 gearT444E like this.
